MusicCabinet - artist radio, genre radio & related artists
Re: MusicCabinet - artist radio, genre radio & related artis
Postby precipitous » Thu Jul 05, 2012 2:14 pm
@hakko: Thank you for getting back to me... I was not able to find anything in the log files that helped me figure out why my theme is not working. I would love it if you would take a look at the files and see if you can find anything. You can get them here: http://www.mediafire.com/download.php?3fta40zi7p45eiw Feel free to make any edits you like. Since I have not been able to use it I am not 100% certain all of the colors are as they should be, etc...
precipitous
Postby hakko » Thu Jul 05, 2012 3:49 pm
Maybe I'm missing something but shouldn't there be a genres.png, a radio.png and an enqueue.png as well? just looked quickly now before putting it together.
MusicCabinet developer
hakko
Postby precipitous » Thu Jul 05, 2012 4:04 pm
hakko wrote:Maybe I'm missing something but shouldn't there be a genres.png, a radio.png and an enqueue.png as well? just looked quickly now before putting it together.
When I made the icons I went through the ones you had in the sonic_white icon folder and inverted the colors for them using Gimp. I am assuming I must have missed genres, radio and enqueue... When I get home from work I will create those and try again.
I am curious, thought, as to whether missing icons would cause the theme to not be available... Do you know?
Thank you for looking at what I have done so far...
precipitous
Postby hakko » Thu Jul 05, 2012 4:15 pm
Did you look in (...)/jetty/0.6.2/webapp/icons/sonic_white? these are the new ones so there might have been another sonic_white folder on your system from a previous version or so.
Missing images shouldn't cause any trouble though, you can actually use all the existing themes just now, they'll just lack the new icons in the top menu.
hakko
Postby precipitous » Thu Jul 05, 2012 4:30 pm
hakko wrote:Did you look in (...)/jetty/0.6.2/webapp/icons/sonic_white? these are the new ones so there might have been another sonic_white folder on your system from a previous version or so.
I feel like such an idiot. I think I figured out all of the problems I reported... I had copied, edited and re-saved all of the files and icons in (...)/jetty/####/webapp/(...) (from the original install of Subsonic), instead of using (...)/jetty/0.6.2/webapp/(...).
Ughhhhh.
precipitous
Postby hakko » Thu Jul 05, 2012 7:53 pm
Oh no problem. I've spent so much time messing with this code so I kind of forget that everyone's not as familiar with it. Let me know when you've finished the last icons and we'll put something together!
hakko
Postby precipitous » Fri Jul 06, 2012 5:40 am
@hakko: I got the new Sonic_Black theme finished and working correctly... Thank you for all of your help. In case you (or anyone else is interested) it looks like this: http://ubuntuone.com/7SsGmKiVyLJCB31fBYQV3X
If you (or anyone else) would like to download the files they are available here: http://ubuntuone.com/38StPGDTrmoWB3M9Ib1WxL
precipitous
Postby hakko » Fri Jul 06, 2012 5:42 am
Looking good! I might even switch myself. I'll definitely include this in future releases so that others can benefit from your work on it. Thanks!
hakko
Postby Ultraviolet » Fri Jul 06, 2012 7:59 pm
I just wanted to chime in and say how much I am enjoying this mod/branch/whatever it is becoming. I have discovered more new music in the last couple weeks than I have in the last couple years--really fun. I did do a complete reinstall of Subsonic and musiccabinet to drop down to a less experimental version--the autospawning players disappeared after that.
I did have a question and a couple of suggestions. Will this new tag based version of musiccabinet negate the need for artist parent folders? I have made a copy of my music collection and generated parent artist folders and am currently using that in Subsonic, but it does have it's limitations. I know you have the work around of using "_" for artists that end in symbols windows doesn't like, but I've also run into severe Windows file name length problems with my classical collection. Additionally, there are some collections that I like to keep separate from the rest of the artist like The Hanssler Bach Collection, Beethoven Complete Works or The Blues Collection. The last one is actually 90 different artists. In all cases though, the parent folder isn't an artist folder. Again, you aren't designing MusicCabinet to my specific needs, I was just curious what your plans were. I'm deriving so much enjoyment from this that I will do my best to tailor my organization structure to your requirements--I just wanted a clearer idea of what those were.
Additionally, you mentioned something about the Album Artist tag before (which I don't currently utilize). Is that the secret to getting Various Artist/Soundtrack albums to show something other than artist info for the first track? Last.fm does allow you to view the info for something like "Ghostbusters". I didn't know if there was something currently in place that would also allow me to display that in Subsonic.
Thanks again for the great work.
Ultraviolet
Postby hakko » Fri Jul 06, 2012 8:52 pm
I'm glad you're enjoying it!
I've been working the last week on replacing Sindre's file scanning mechanism from scratch. I came up with a solution that seems very promising, fast and clean code. But I've only written automatic test cases for it so far, not even used it myself. It scans your whole media folder(s) and builds up a database model of present artists, albums and tracks, solely based on tags. Your folder structure is from now on only used to map folder artwork to a certain album, apart from that, you can spread your artists/albums however you want. So a double cd for example using "cd1"/"cd2" folders becomes one single album in the database. If you used to depend on "cd1"/"cd2" folders, you have to change to rely on disc number tags now.
The "Album Artist" tag (most software use id3 key TPE2) is read during scanning, and "Album artist" takes precedence over "Artist".
So, for a soundtrack, you could give each song it's correct artist tag, but enter the value "Various Artists" as "Album Artist". "Various Artists" will then be displayed as Artist name in the left column, but when you expand the album in the main window or add tracks to the playlist or scrobble songs to last.fm, the actual artist name of each song is displayed.
If you don't use "Album Artist", it would then be interpreted as if all the participating artists on the soundtrack had their own album. So "Album Artist" is highly recommended to use, I think that's the best way to group releases where multiple artists appear together.
It also reads the Composer tag by the way, I'm not sure what to do with that value yet, but it's stored for future use. And so is sort artist / sort album artist for people who prefer "Lennon, John" rather than "John Lennon".
So, basically: my current plan is to get rid of the inefficient folder/file handling, and replacing it with an elegant and fast database solution. I'm very excited about the idea actually. I like it that MusicCabinet now takes care of all logic, as it will give more possible options to radio playlists, like excluding short tracks, adding a year interval to it etc. It's a lot of work (I think I wrote 2500 lines of code over the last week) but it will be a very good base for future improvements.
hakko
Postby precipitous » Fri Jul 06, 2012 9:52 pm
hakko wrote:Looking good! I might even switch myself. I'll definitely include this in future releases so that others can benefit from your work on it. Thanks!
Thank you for the kind words. I am really glad that you like the new theme! For the most part I consider it done (for now) with the exception of one thing. I still need to set the colors for when the genre tags on the Radio screen are hovered over and/or selected, but I can't seem to find where they are set. Can you please let me know?
I am also definitely open to suggestions and requests from the Subsonic/MusicCabinet community for enhancements and changes to the theme, so if anyone has ideas let me know...
precipitous
Postby hakko » Fri Jul 06, 2012 10:02 pm
Oh, they're very hard-coded (in radio.jsp). Shame on me. I guess the best thing would be to move them from radio.jsp straight to sonic_white.css, right? And give them some understandable name, so that it can easily be changed in sonic_black.css etc and other future themes?
I think you can tell every now and then that I like back-end development and stay away from interface design...
hakko
Postby jake- » Sat Jul 07, 2012 7:30 am
hakko wrote:I've been working the last week on replacing Sindre's file scanning mechanism from scratch. I came up with a solution that seems very promising, fast and clean code. But I've only written automatic test cases for it so far, not even used it myself. It scans your whole media folder(s) and builds up a database model of present artists, albums and tracks, solely based on tags. Your folder structure is from now on only used to map folder artwork to a certain album, apart from that, you can spread your artists/albums however you want. So a double cd for example using "cd1"/"cd2" folders becomes one single album in the database. If you used to depend on "cd1"/"cd2" folders, you have to change to rely on disc number tags now.
Thanks so much for your work! I can't wait :-) This is such a big improvement *excited*
hakko wrote:The "Album Artist" tag (most software use id3 key TPE2) is read during scanning, and "Album artist" takes precedence over "Artist". So, for a soundtrack, you could give each song it's correct artist tag, but enter the value "Various Artists" as "Album Artist". "Various Artists" will then be displayed as Artist name in the left column, but when you expand the album in the main window or add tracks to the playlist or scrobble songs to last.fm, the actual artist name of each song is displayed.
This will show my bad tagging ;-) I use jaikoz for some time now but my old music will need a lot of work to get rid of different spellings and missing VA tags.
jake-
Postby calamitijo » Sun Jul 08, 2012 9:51 am
hello, it works with the musiccabinet beta (subsonic-beta) but, I don't find how it works on ios device like iphone on isub or z-subsonic? does the mod work on it? It says 'unable to stream....'.
How it is possible?
Jonathan
calamitijo
Postby hakko » Sun Jul 08, 2012 10:23 am
The beta is a bit of an experiment, sorry about that. I'm working on pretty large update right now, where that will be taken care of! But for now, the beta is web-only.
hakko
Return to MusicCabinet
