hakko wrote:Thanks for the report! What exactly were you doing when it happened? Have you recently removed files from your media library? It looks like a "dead link", as if a file that no longer exists is being references, and I'm curious how and why.
java.lang.NullPointerException
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:58)
at net.sourceforge.subsonic.controller.NowPlayingController.handleRequestInternal(NowPlayingController.java:54)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:900)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:827)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:101)
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:54)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
hakko wrote:precipitous: I can't reproduce this at the moment (I get songs to play in Foobar at work using 0.7.11). Could you try clearing cookies? Subsonic seems to store which player to use in a cookie, I'm wondering if that has borked.
precipitous wrote:I recently had to replace my hard drive, so I had to re-install everything from scratch. When I set up Subsonic/MusicCabinet everything went normally. I input my postgre password and ran the initial first use scan and again, everything went perfectly... I have been running without any problems for a few days, but now I have encountered a really weird situation. I added several new files to my music collection, but they did not show up in MusicCabinet, so I assumed I needed to run another full scan. When I went to do this I discovered that I no longer have any of the regular links available in the Settings pages to run a scan. Also, on the Settings > MusicCabinet page the display reads:
MusicCabinet configuration
The search index is being created. Depending on the size of your music library, this could take a while.
Progress:
1 directories found during search
6 new files read for meta-data
artist relations [not started]
artist top tracks [not started]
artist tags [not started]
artist biographies [not started]
album descriptions [not started]
tag descriptions [not started]
weekly group artist charts [not started]
tag top artists [not started]
user top artist periods [not started]
user recommended artists [not started]
scrobbled tracks statistics [not started]
even though I have not started a scan... Clicking the Refresh button has no effect even though it has been several hours since I logged in.
Do you know what would cause this behavior?
hakko wrote:I hope the hard drive swap was controlled so you didn't lose a lot of music!
For future reference:
(1) it is possible to backup the PostgreSQL data, or to export it from one computer to another, if you don't want to re-import everything from last.fm.
http://www.postgresql.org/docs/9.1/stat ... gdump.html
(2) I'm sure there are a few odd bugs left that haven't yet been found/reported. However, to find them, it's normally not enough to get a report saying that "the import stalled". If the system hangs like that, try gathering log files that would hold more information about it. From the About view, there's a section called "Bug reports". It gives the path to subsonic.log and musiccabinet.log. If something goes terribly wrong, include these files in your bug report! They're overwritten on system restart (to not clutter your system), so be sure to get immediately. That also helps to identify the situation where something failed.
Regards
