Installation Issue
Installation Issue
Postby xefil » Wed Oct 10, 2012 8:36 am
Hello!
I've running subsonic 4.7beta3 on a CentOS Server and would like to test this mod.
I've stopped subsonic process, downloaded the standalone version, unzipped, installed postgres server and started the subsonic.sh before changing the paths into the script. No other steps made.
The output I obtain is:
19 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationCo
ntext@31e4457d: display name [org.springframework.context.support.ClassPathXmlApplicationContext@31e4457d]; startup date [Wed Oct 10 10:28:56 CEST 2012]; ro
ot of context hierarchy
62 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-dep
loyer.xml]
353 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.suppo
rt.ClassPathXmlApplicationContext@31e4457d]: org.springframework.beans.factory.support.DefaultListableBeanFactory@68da4b71
362 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.sup
port.DefaultListableBeanFactory@68da4b71: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
381 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: /root/software/subsonic/MusicCabinet/subsonic-installer-standalone/subsonic.war
Extracting webapp to /var/subsonic/jetty/0.7.11
409 [main] INFO org.mortbay.log - jetty-6.1.x
26711 [main] INFO / - Initializing Spring root WebApplicationContext
26711 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
26778 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing Root WebApplicationContext: startup date [Wed Oct 10 10:29:2
3 CEST 2012]; root of context hierarchy
[GC 31552K->1741K(120704K), 0.0067650 secs]
26830 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applic
ationContext-service.xml]
27089 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applic
ationContext-security.xml]
27149 [main] INFO org.springframework.security.config.SecurityNamespaceHandler - Spring Security 'config' module version is 3.1.0.RELEASE
27175 [main] INFO org.springframework.security.config.http.FilterInvocationSecurityMetadataSourceParser - Creating access control expression attribute 'perm
itAll' for /**
27189 [main] INFO org.springframework.security.config.http.HttpSecurityBeanDefinitionParser - Checking sorted filter chain: [Root bean: class [org.springfra
mework.security.web.context.SecurityContextPersistenceFilter]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=
true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null, order = 300, <restRequestParameterProcessing
Filter>, order = 601, Root bean: class [org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter]; scope=; abstract=false; lazyIn
it=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destr
oyMethodName=null, order = 1400, Root bean: class [org.springframework.security.web.authentication.AnonymousAuthenticationFilter]; scope=; abstract=false; l
azyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null;
destroyMethodName=null, order = 1700, Root bean: class [org.springframework.security.web.access.ExceptionTranslationFilter]; scope=; abstract=false; lazyIni
t=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destro
yMethodName=null, order = 1900, <org.springframework.security.web.access.intercept.FilterSecurityInterceptor#0>, order = 2000]
27196 [main] INFO org.springframework.security.config.http.FilterInvocationSecurityMetadataSourceParser - Creating access control expression attribute 'perm
itAll' for /login.view
itAll' for /accessDenied.view
itAll' for /videoPlayer.view
itAll' for /coverArt.view
itAll' for /stream/**
itAll' for /share/**
itAll' for /style/**
27197 [main] INFO org.springframework.security.config.http.FilterInvocationSecurityMetadataSourceParser - Creating access control expression attribute 'perm
itAll' for /icons/**
itAll' for /flash/**
itAll' for /script/**
itAll' for /crossdomain.xml
27197 [main] INFO org.springframework.security.config.http.FilterInvocationSecurityMetadataSourceParser - Creating access control expression attribute 'hasR
ole('ROLE_SETTINGS')' for /personalSettings.view
ole('ROLE_SETTINGS')' for /lastFmSettings.view
ole('ROLE_SETTINGS')' for /passwordSettings.view
ole('ROLE_SETTINGS')' for /playerSettings.view
ole('ROLE_SETTINGS')' for /shareSettings.view
27198 [main] INFO org.springframework.security.config.http.FilterInvocationSecurityMetadataSourceParser - Creating access control expression attribute 'hasR
ole('ROLE_ADMIN')' for /generalSettings.view
ole('ROLE_ADMIN')' for /advancedSettings.view
ole('ROLE_ADMIN')' for /userSettings.view
ole('ROLE_ADMIN')' for /mediaFolderSettings.view
ole('ROLE_ADMIN')' for /networkSettings.view
ole('ROLE_ADMIN')' for /transcodingSettings.view
ole('ROLE_ADMIN')' for /internetRadioSettings.view
ole('ROLE_ADMIN')' for /searchSettings.view
ole('ROLE_ADMIN')' for /musicCabinetSettings.view
27199 [main] INFO org.springframework.security.config.http.FilterInvocationSecurityMetadataSourceParser - Creating access control expression attribute 'hasR
ole('ROLE_ADMIN')' for /podcastSettings.view
ole('ROLE_ADMIN')' for /radioSettings.view
ole('ROLE_ADMIN')' for /db.view
ole('ROLE_PLAYLIST')' for /deletePlaylist.view
ole('ROLE_PLAYLIST')' for /savePlaylist.view
ole('ROLE_DOWNLOAD')' for /download.view
ole('ROLE_UPLOAD')' for /upload.view
ole('ROLE_SHARE')' for /createShare.view
ole('ROLE_COVERART')' for /changeCoverArt.view
ole('ROLE_COVERART')' for /editTags.view
27200 [main] INFO org.springframework.security.config.http.FilterInvocationSecurityMetadataSourceParser - Creating access control expression attribute 'hasR
ole('ROLE_COVERART')' for /editArtist.view
ole('ROLE_COMMENT')' for /setMusicFileInfo.view
ole('ROLE_PODCAST')' for /podcastReceiverAdmin.view
ole('ROLE_STREAM')' for /*
27213 [main] INFO org.springframework.security.config.http.HttpSecurityBeanDefinitionParser - Checking sorted filter chain: [Root bean: class [org.springfra
true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null, order = 300, Root bean: class [org.springfra
mework.security.web.authentication.logout.LogoutFilter]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true;
primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null, order = 400, <org.springframework.security.web.aut
hentication.UsernamePasswordAuthenticationFilter#0>, order = 800, Root bean: class [org.springframework.security.web.authentication.www.BasicAuthenticationF
ilter]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMetho
dName=null; initMethodName=null; destroyMethodName=null, order = 1200, Root bean: class [org.springframework.security.web.savedrequest.RequestCacheAwareFilt
er]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodNa
me=null; initMethodName=null; destroyMethodName=null, order = 1300, Root bean: class [org.springframework.security.web.servletapi.SecurityContextHolderAware
RequestFilter]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; fact
oryMethodName=null; initMethodName=null; destroyMethodName=null, order = 1400, Root bean: class [org.springframework.security.web.authentication.rememberme.
RememberMeAuthenticationFilter]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBe
anName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null, order = 1600, Root bean: class [org.springframework.security.web.authentic
ation.AnonymousAuthenticationFilter]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; fact
oryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null, order = 1700, Root bean: class [org.springframework.security.web.sess
ion.SessionManagementFilter]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanN
ame=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null, order = 1800, Root bean: class [org.springframework.security.web.access.Excep
tionTranslationFilter]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=nu
ll; factoryMethodName=null; initMethodName=null; destroyMethodName=null, order = 1900, <org.springframework.security.web.access.intercept.FilterSecurityInte
rceptor#1>, order = 2000]
27222 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applic
ationContext-cache.xml]
27347 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.
DefaultListableBeanFactory@6e8f94: defining beans [passwordEncoder,saltSource,playerDao,internetRadioDao,musicFileInfoDao,mediaFolderDao,userDao,transcoding
Dao,podcastDao,avatarDao,shareDao,daoHelper,audioScrobblerService,mediaFileService,securityService,settingsService,searchService,networkService,playerServic
e,playlistService,versionService,statusService,musicInfoService,transcodingService,shareService,podcastService,jukeboxService,metaDataParserFactory,artistIn
dexService,ajaxMultiService,ajaxNowPlayingService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxTagService,ajaxTransferService,ajaxChatServi
ce,ajaxLibraryStatusService,ajaxUIStarService,propertyConfigurer,taskExecutor,channelInitializer,$autoCreateChannelCandidates,org.springframework.integratio
n.internalDefaultConfiguringBeanFactoryPostProcessor,libraryPresenceChannel,libraryMetadataChannel,libraryAdditionChannel,libraryDeletionChannel,scrobbleCha
nnel,directoryBrowserService,starService,lastFmService,scrobbleService,databaseAdministrationService,libraryScannerService,libraryPresenceService,libraryMet
adataService,libraryAdditionService,libraryBrowserService,audioTagService,libraryDeletionService,throttleService,artistInfoService,albumInfoService,artistRe
lationService,artistTopTracksService,artistTopTagsService,scrobbledTracksService,tagInfoService,userTopArtistsService,userRecommendedArtistsService,groupWee
klyArtistChartService,tagTopArtistsService,searchIndexUpdateSettingsService,webserviceHistoryService,tagService,nameSearchService,artistRecommendationServic
e,searchIndexUpdateExecutorService,playlistGeneratorService,libraryUpdateService,updateNowPlayingClient,scrobbleClient,authSessionClient,radioPlaylistClient
,artistInfoClient,albumInfoClient,artistSimilarityClient,artistTopTracksClient,artistTopTagsClient,trackSimilarityClient,scrobbledTracksClient,tagInfoClient
,userTopArtistsClient,userRecommendedArtistsClient,groupWeeklyArtistChartClient,tagTopArtistsClient,directoryBrowserDao,libraryPresenceDao,libraryAdditionDa
o,libraryDeletionDao,libraryBrowserDao,musicDao,starDao,playCountDao,trackPlayCountDao,webserviceHistoryDao,trackRelationDao,artistInfoDao,albumInfoDao,arti
stRelationDao,artistTopTracksDao,artistTopTagsDao,nameSearchDao,playlistGeneratorDao,artistRecommendationDao,tagDao,tagInfoDao,lastFmDao,userTopArtistsDao,u
serRecommendedArtistsDao,groupWeeklyArtistChartDao,functionCountDao,databaseAdministrationDao,dataSource,initialDataSource,org.springframework.security.filt
erChains,org.springframework.security.filterChainProxy,org.springframework.security.web.PortMapperImpl#0,org.springframework.security.config.authentication.
AuthenticationManagerFactoryBean#0,org.springframework.security.authentication.ProviderManager#0,org.springframework.security.web.context.NullSecurityContex
tRepository#0,org.springframework.security.web.savedrequest.NullRequestCache#0,org.springframework.security.web.access.expression.DefaultWebSecurityExpressi
onHandler#0,org.springframework.security.access.vote.AffirmativeBased#0,org.springframework.security.web.access.intercept.FilterSecurityInterceptor#0,org.sp
ringframework.security.web.access.DefaultWebInvocationPrivilegeEvaluator#0,org.springframework.security.authentication.AnonymousAuthenticationProvider#0,org
.springframework.security.userDetailsServiceFactory,org.springframework.security.web.DefaultSecurityFilterChain#0,org.springframework.security.web.PortMappe
rImpl#1,org.springframework.security.config.authentication.AuthenticationManagerFactoryBean#1,org.springframework.security.authentication.ProviderManager#1,
org.springframework.security.web.context.HttpSessionSecurityContextRepository#0,org.springframework.security.web.authentication.session.SessionFixationProte
ctionStrategy#0,org.springframework.security.web.savedrequest.HttpSessionRequestCache#0,org.springframework.security.web.access.expression.DefaultWebSecurit
yExpressionHandler#1,org.springframework.security.access.vote.AffirmativeBased#1,org.springframework.security.web.access.intercept.FilterSecurityInterceptor
#1,org.springframework.security.web.access.DefaultWebInvocationPrivilegeEvaluator#1,org.springframework.security.authentication.AnonymousAuthenticationProvi
der#1,org.springframework.security.web.authentication.rememberme.TokenBasedRememberMeServices#0,org.springframework.security.authentication.RememberMeAuthen
ticationProvider#0,org.springframework.security.web.authentication.www.BasicAuthenticationEntryPoint#0,org.springframework.security.web.authentication.Usern
amePasswordAuthenticationFilter#0,org.springframework.security.web.DefaultSecurityFilterChain#1,restRequestParameterProcessingFilter,restRequestEntryPoint,o
rg.springframework.security.authentication.dao.DaoAuthenticationProvider#0,org.springframework.security.authentication.DefaultAuthenticationEventPublisher#0
,org.springframework.security.authenticationManager,cacheManager,userCache,mediaFileCache,childDirCache,coverArtCache,musicFolderCache,chatCache]; root of f
actory hierarchy
27347 [main] ERROR org.springframework.web.context.ContextLoader - Context initialization failed
org.springframework.beans.factory.CannotLoadBeanClassException: Error loading class [net.sourceforge.subsonic.service.SettingsService] for bean with name 's
ettingsService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: problem with class file or dependent class; nested exception i
s java.lang.UnsupportedClassVersionError: net/sourceforge/subsonic/service/SettingsService : Unsupported major.minor version 51.0
        at org.springframework.beans.factory.support.AbstractBeanFactory.resolveBeanClass(AbstractBeanFactory.java:1265)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:433)
        at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
        at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:284)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
        at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:644)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:446)
        at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:384)
        at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:283)
        at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
        at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
        at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
        at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
        at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
        at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
Caused by: java.lang.UnsupportedClassVersionError: net/sourceforge/subsonic/service/SettingsService : Unsupported major.minor version 51.0
        at java.lang.ClassLoader.defineClass1(Native Method)
        at java.lang.ClassLoader.defineClass(ClassLoader.java:634)
        at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
        at java.net.URLClassLoader.defineClass(URLClassLoader.java:277)
        at java.net.URLClassLoader.access$000(URLClassLoader.java:73)
        at java.net.URLClassLoader$1.run(URLClassLoader.java:212)
        at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
        at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:366)
        at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:337)
        at org.springframework.util.ClassUtils.forName(ClassUtils.java:257)
        at org.springframework.beans.factory.support.AbstractBeanDefinition.resolveBeanClass(AbstractBeanDefinition.java:417)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doResolveBeanClass(AbstractBeanFactory.java:1283)
        at org.springframework.beans.factory.support.AbstractBeanFactory.resolveBeanClass(AbstractBeanFactory.java:1254)
        ... 47 more
27352 [main] ERROR org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@38ffd135{/,jar:file:/root/software/subsonic/MusicCabin
et/subsonic-installer-standalone/subsonic.war!/}
        ... 47 more
27356 [main] ERROR org.mortbay.log - Nested in org.springframework.beans.factory.CannotLoadBeanClassException: Error loading class [net.sourceforge.subsonic
.service.SettingsService] for bean with name 'settingsService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: problem with cl
ass file or dependent class; nested exception is java.lang.UnsupportedClassVersionError: net/sourceforge/subsonic/service/SettingsService : Unsupported majo
r.minor version 51.0:
27372 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
27410 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
27423 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
27447 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServe
rRef [liveRef: [endpoint:[213.21.177.146:9412](local),objID:[0:0:0, 0]]]]
[GC 32346K->1999K(120704K), 0.0067020 secs]
[Full GC 1999K->1902K(120704K), 0.0478500 secs]
And the page on port 4040 reports "Error 503 - service unavailable".
Could you help me a little?
Thank's
Simon
xefil
Re: Installation Issue
Postby hakko » Wed Oct 10, 2012 8:40 am
It looks to me as if you're running Java 6 - MusicCabinet requires Java 7, as that version introduces new features which I use for the media library scanning.
Regards
MusicCabinet developer
hakko
Postby xefil » Wed Oct 10, 2012 8:44 am
As java I obtain:
# java -version
java version "1.6.0_24"
OpenJDK Runtime Environment (IcedTea6 1.11.3) (rhel-1.48.1.11.3.el6_2-x86_64)
OpenJDK 64-Bit Server VM (build 20.0-b12, mixed mode)
Wrong?
xefil
Postby hakko » Wed Oct 10, 2012 8:47 am
Yup, that's wrong, it's Java 6. (They have a very confusing naming scheme, 1.6 = version 6. you need 1.7 = version 7)
hakko
Postby xefil » Wed Oct 10, 2012 8:53 am
OKEY! I'll istall that version. And ley you know!
Simon
xefil
Postby xefil » Wed Oct 10, 2012 8:59 am
Now it seems there is a problem with postgres:
[2012-10-10 10:55:05,364] WARN  com.mchange.v2.resourcepool.BasicResourcePool - com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@6b7f1316
-- Acquisition Attempt Failed!!! Clearing pending acquires. While trying to acquire a needed new resource, we failed to succeed more than the maximum number
of allowed acquisition attempts (1). Last acquisition attempt exception:
org.postgresql.util.PSQLException: FATAL: Ident authentication failed for user "postgres"
        at org.postgresql.core.v3.ConnectionFactoryImpl.doAuthentication(ConnectionFactoryImpl.java:291)
        at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:108)
        at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:66)
        at org.postgresql.jdbc2.AbstractJdbc2Connection.<init>(AbstractJdbc2Connection.java:125)
        at org.postgresql.jdbc3.AbstractJdbc3Connection.<init>(AbstractJdbc3Connection.java:30)
        at org.postgresql.jdbc3g.AbstractJdbc3gConnection.<init>(AbstractJdbc3gConnection.java:22)
        at org.postgresql.jdbc4.AbstractJdbc4Connection.<init>(AbstractJdbc4Connection.java:30)
        at org.postgresql.jdbc4.Jdbc4Connection.<init>(Jdbc4Connection.java:24)
        at org.postgresql.Driver.makeConnection(Driver.java:393)
        at org.postgresql.Driver.connect(Driver.java:267)
        at com.mchange.v2.c3p0.DriverManagerDataSource.getConnection(DriverManagerDataSource.java:134)
        at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:182)
        at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:171)
        at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool$1PooledConnectionResourcePoolManager.acquireResource(C3P0PooledConnectionPool.java:152)
        at com.mchange.v2.resourcepool.BasicResourcePool.doAcquire(BasicResourcePool.java:1074)
        at com.mchange.v2.resourcepool.BasicResourcePool.doAcquireAndDecrementPendingAcquiresWithinLockOnSuccess(BasicResourcePool.java:1061)
        at com.mchange.v2.resourcepool.BasicResourcePool.access$800(BasicResourcePool.java:32)
        at com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask.run(BasicResourcePool.java:1796)
        at com.mchange.v2.async.ThreadPoolAsynchronousRunner$PoolThread.run(ThreadPoolAsynchronousRunner.java:635)
BTW I've *not* overwritten the old subsonic folder. Should I do it? (backup boefore of course). Because I cannot log-in with my user. O do I need to setup all from the beginning?
I'm testing this from a temp folder.
Simon
xefil
Postby hakko » Wed Oct 10, 2012 9:08 am
MusicCabinet should install fine on top of a previous Subsonic 4.6 / 4.7 installation (users and settings should then get automatically imported into MusicCabinet). What Subsonic version were you running before?
You could remove your previous Subsonic directory completely, but then you'll just get a default user (user: admin / password: admin).
The postgres login failure is just normal - you haven't yet configured MusicCabinet and told it what password to use for logging in to Postgres. That'll happen after you've logged to the web interface.
hakko
Postby xefil » Wed Oct 10, 2012 9:44 am
Also, I would start all from the beginning, because now I'm obtaining again "Error 503 Service Unavailable".
I'll create a new folder i.e. /var/subsonic-musiccabinet and here I'll copy the whole content of my 4.7b3 version of subsonic (/var/subsonic). So I should maintain the previous users.
After that I'll overwrite all the content with the musiccabinet standalone files, correcting the paths in subsonic.sh script.
Then, I'll drop the database 'musiccabinet' from postgres.
Could you give me the steps to follow to set-up the database and how should the 'pg_hba.conf' looks like? I'm having some issues with users and methods (ident, md5, trusted...??)
Again, thank's for fast responses!
Simon
xefil
Postby xefil » Wed Oct 10, 2012 10:00 am
Additional informations. Starting from the beginning, now I was able to start all. The password was accepted from the MusicCabinet settings and a database upgrade was required. Pressing the button, I obtain:
Load version number 1000
295839 [btpool0-4] ERROR org.mortbay.log - Nested in org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [create or replace function load_1000() returns int as $$ begin
-- Util schema: meta functionality for database
create schema util;
create table util.musiccabinet_version (update_id integer not null, insert_time timestamp not null default now());
-- Music schema: abstract information on artist, tracks, (global) ratings and relations
create schema music;
create table music.tag (id serial primary key, tag_name text not null);
<snip>
insert into util.musiccabinet_version (update_id) values (1000);
return 0;
end; $$ language plpgsql;]; nested exception is org.postgresql.util.PSQLException: ERROR: language "plpgsql" does not exist
  Hint: Use CREATE LANGUAGE to load the language into the database.:
create schema util;
create table music.artist (id serial primary key, artist_name text);
create table music.track (artist_id integer references music.artist (id), id serial primary key, track_name text);
create table music.trackrelation (source_id integer references music.track (id) not null, target_id integer references music.track (id) not null, weight float not null);
create table music.trackrelation_import (source_id integer not null, target_id integer references music.track (id), target_artist_name text not null, target_track_name text not null, target_artist_id integer references music.artist (id), weight float not null);
create table music.artistrelation (source_id integer references music.artist (id) not null, target_id integer references music.artist (id) not null, weight float not null);
create table music.artistrelation_import (source_id integer not null, target_id integer references music.artist (id), target_artist_name text not null, weight float not null);
create table music.artisttoptrack (artist_id integer references music.artist (id) not null, track_id integer references music.track (id) not null, rank smallint not null);
create table music.artisttoptrack_import (artist_id integer references music.artist (id) not null, track_id integer references music.track (id), track_name text not null, rank smallint not null);
create table music.artisttoptag (artist_id integer references music.artist (id) not null, tag_id integer references music.tag (id) not null, tag_count smallint not null);
create table music.artisttoptag_import (artist_id integer references music.artist (id) not null, tag_id integer references music.tag (id), tag_name text not null, tag_count smallint not null);
create unique index artistrelation_sourceid_targetid on music.artistrelation (source_id, target_id);
create unique index tag_tagname_id on music.tag (tag_name, id);
create unique index artisttoptag_tagid_artistid_tagcount on music.artisttoptag (tag_id, artist_id, tag_count);
-- Library schema: personal information, such as local music files, personal ratings, invoked web service calls
create schema library;
create table library.musicfile (track_id integer references music.track (id) not null, id serial primary key, path text, created timestamp, last_modified timestamp, external_id text);
create table library.musicfile_import (artist_name text, artist_id integer references music.artist (id), track_name text, track_id integer references music.track (id), path text, created timestamp, last_modified timestamp, external_id text);
create table library.musicdirectory (artist_id integer references music.artist (id) not null, id serial primary key, path text, root boolean);
create table library.musicdirectory_import (artist_id integer references music.artist (id), artist_name text not null, path text, root boolean);
create table library.trackplaycount (track_id integer references music.track (id) not null, play_count integer);
create table library.trackplaycount_import (artist_name text, artist_id integer references music.artist (id), track_name text, track_id integer references music.track (id), play_count integer);
create table library.webservice_calltype (id smallint primary key, description text);
create table library.webservice_history (artist_id integer references music.artist (id), track_id integer references music.track (id), calltype_id smallint references library.webservice_calltype (id), page smallint, invocation_time timestamp default now());
create table library.artisttoptrackplaycount (music_file_id integer references library.musicfile (id) not null, artist_id integer not null references music.artist (id), rank smallint not null, play_count integer not null);
insert into library.webservice_calltype (id, description) values (0, 'Last.fm library.getTracks (used for track playcount)');
insert into library.webservice_calltype (id, description) values (1, 'Last.fm artist.getSimilar');
insert into library.webservice_calltype (id, description) values (2, 'Last.fm artist.getTopTracks');
insert into library.webservice_calltype (id, description) values (3, 'Last.fm track.getSimilar');
insert into library.webservice_calltype (id, description) values (4, 'Last.fm artist.getTopTags');
create unique index musicfile_path_trackid on library.musicfile (path, track_id);
create unique index musicdirectory_path_artistid on library.musicdirectory (path, artist_id);
return 0;
        at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:98)
        at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:407)
        at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:428)
        at com.github.hakko.musiccabinet.dao.jdbc.JdbcDatabaseAdministrationDao.loadDatabaseUpdate(JdbcDatabaseAdministrationDao.java:208)
        at com.github.hakko.musiccabinet.service.DatabaseAdministrationService.loadNewDatabaseUpdates(DatabaseAdministrationService.java:105)
        at net.sourceforge.subsonic.controller.MusicCabinetSettingsController.doSubmitAction(MusicCabinetSettingsController.java:68)
        at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:449)
        at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:415)
        at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:387)
        at org.springframework.web.servlet.mvc.SimpleFormController.processFormSubmission(SimpleFormController.java:272)
        at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:268)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:900)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:827)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
        at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
        at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
        at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
        at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
        at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
        at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
        at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:101)
        at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
        at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
        at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:54)
        at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
        at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
        at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
        at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
        at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
        at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
        at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
        at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
        at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:844)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:644)
Caused by: org.postgresql.util.PSQLException: ERROR: language "plpgsql" does not exist
        at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2102)
        at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1835)
        at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
        at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:500)
        at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:374)
        at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:366)
        at com.mchange.v2.c3p0.impl.NewProxyStatement.execute(NewProxyStatement.java:108)
        at org.springframework.jdbc.core.JdbcTemplate$1ExecuteStatementCallback.doInStatement(JdbcTemplate.java:421)
        at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:396)
        ... 67 more
295843 [btpool0-4] WARN org.mortbay.log - Nested in org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [create or replace function load_1000() returns int as $$ begin
create schema util;
return 0;
295845 [btpool0-4] ERROR org.mortbay.log - /musicCabinetSettings.view
create schema util;
return 0;
        ... 67 more
295848 [btpool0-4] WARN org.mortbay.log - Nested in org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [create or replace function load_1000() returns int as $$ begin
create schema util;
return 0;
Little steps forward :)
xefil
Postby hakko » Wed Oct 10, 2012 10:02 am
You shouldn't need to change in single thing in your Postgres database (unless you want to tune it). The only thing to be aware of is, as mentioned on the installation page, that I use some extra functionality in Postgres (trigram search) which isn't distributed with default Postgres 9.1/9.2. Linux users need to get it explicitly with something like
sudo apt-get install postgresql-contrib
It shouldn't be necessary to drop the database either - MusicCabinet should detect whether it needs to be created or not.
hakko
Postby hakko » Wed Oct 10, 2012 10:03 am
Maybe your platform comes with a super minimal Postgres setup? Check this:
http://stackoverflow.com/questions/2122 ... e-language
hakko
Postby xefil » Wed Oct 10, 2012 10:28 am
Wrong postgres version was the problem... rtfm... I know, btw was extremely sure last CentOS version has postgres 9.1, but it was on version 8. Now it's scanning the files :)
Very fast support, thank you!
Simon
xefil
Postby hakko » Wed Oct 10, 2012 11:08 am
Java 7 and Postgres 9.1+, check, those were mentioned on the installation page. : )
maybe the subsonic.sh script should at least print versions of things though. Java versions can get mixed up and it's good to get a reminder if that happens.
hakko
Postby xefil » Wed Oct 10, 2012 11:17 am
Without opening a new thread, I'm using it a little bit but have some difficults.
1. Why is the genres tab empty? I've made a complete scan and I can see all my files indexed correctly. Only th egenres tab is empty.
2. on original subversion, if I try to search for a compilation, I 've always clicked on the compilation to play the content. Now seems they are all considered single songs. I.e. from the home folder, if I click on a single artist album I obtain the list of the tracks -> correct. If I click on a compilation I obtain only the single song. The same way, If I search (searchbox) for an Album of a single Artist, I obtain only one result containing all the songs. If I search for a compilation, I obtain "n" results, one per track. Seems an album containing multiple artists is handled as single albums, one per artist?
TY, Simon
xefil
Postby hakko » Wed Oct 10, 2012 11:23 am
1. You have to actively choose which genres to use, from Settings -> MusicCabinet (bottom of the page)
2. I'd guess your compilation albums lack the "Album Artist" tag. (TPE2 in MP3 id3 v2). MusicCabinet groups albums based on album artist/artist/album tag, not directories, so it'll interpret a compilation album lacking album artist as many different albums by different artists. If you use the album artist tag and set it to "Various Artists" or something similar, the album will be considered just one album by that artist. However, single songs will still be presented with their artist tag, scrobbled correctly, be searchable etc.
hakko
Return to MusicCabinet
