Change/hide upload directory
Postby dsync89 » Sat Oct 27, 2012 1:42 pm
Hi hakko, which source code should I modify if I wanted to change the default upload directory or hide it to prevent user from specifying the path? I would like all uploaded file to be consolidate to ONE single folder. So user should not be able to view or change the path.
My temporary workaround is just prevent user from changing the upload directory by adding the 'readonly' field. I try to remove the whole code below but the Upload button say no input.
            <tr>
                <td><fmt:message key="more.upload.target"/></td>
                <td><input type="text" id="dir" name="dir" size="37" value="${model.uploadDirectory}" readonly="readonly"/></td>
                <td><input type="submit" value="<fmt:message key="more.upload.ok"/>"/></td>
            </tr>
musicScrape @ Music Cabinet Mod
http://musicscrape.zapto.org:8080
dsync89
Re: Change/hide upload directory
Postby dsync89 » Sat Oct 27, 2012 2:01 pm
Finally found a simple workaround, which is changing to type to hidden.
<td><input type="hidden" id="dir" name="dir" size="37" value="${model.uploadDirectory}" readonly="readonly"/></td>
dsync89
Postby TNRocker » Fri Jul 26, 2013 1:27 am
I wish I could help you out but I don't know the answer. The developer appears to have taken a break and it doesn't appear many are willing to offer help.
I have posted several questions and never got a response. Music Cabinet is a fantastic Mod. There is one bug I would love to fix and the patch is on the github site but I am having trouble creating the .war file. See link below. Good luck!
viewtopic.php?f=11&t=12390
TNRocker
Postby thelin » Tue Aug 06, 2013 5:19 pm
I would also really like to know how to do this.
If anyone has any hints as to how to change and then hide the upload directory please let us know!
thanks!
9,794 artists
7,125 albums
76,285 songs
1300.01 GB
thelin
Postby beehlerj » Sat Dec 14, 2013 5:34 am
...jetty/3434/webapp/WEB-INF/jsp/more.jsp is the file that needs to be changed.
<tr>
<td><input type="text" id="dir" name="dir" size="37" value="${model.uploadDirectory}"/></td>
</tr>
change to:
<tr>
<td><input type="hidden" id="dir" name="dir" size="37" value="${model.uploadDirectory}"/></td>
</tr>
this hides the text from being changed
beehlerj
Postby gwynhfar » Sat Dec 14, 2013 10:21 am
Ok I found the answer somewhere in this forum. I wanted to change my upload directory wich was pointing in the middle of my collection.
I use the following sturcture MAIN/GENRE/ARTIST/ALBUM(S)/TRACK(S). 69 Genres, +4000 artists, + 17.000 albums, + 220.000 tracks. The Incoming folder was placed as a "main/incoming" folder, it always worked but after upgrading to 4.8 The Incoming folder was placed inside the first genre (main/genre1/incoming). To manually override these settings you have to find the "more.js".
subsonic\jetty\3434\webapp\WEB-INF\jsp\more.jsp Open the more jsp in your editor and find the part (in my case rule 140)
<td><input type="text" id="dir" name="dir" readonly ="true" size="37" value="${model.uploadDirectory}"/></td>
replace ${model.uploadDirectory} with the folder within your main music folder f.e. I:\ALL MUSIC\Incoming
<td><input type="text" id="dir" name="dir" readonly ="true" size="37" value=" I:\ALL MUSIC\Incoming"/></td>
Add the Incoming folder by setting it as a media folder (settings -> media folder new folder Incoming = I:\ALL MUSIC\Incoming)
Hope this will work for you, it worked for me ;)
gwynhfar
Return to MusicCabinet
