Failed to mvn package
Postby dsync89 » Sat Dec 15, 2012 5:11 am
Hi hakko! It has been a while since I visited this forum. After seeing so many features I decided to update the version.
However, when running mvn package I encountered the following error. I'm not sure what is causing it though.
[INFO] ------------------------------------------------------------------------
[INFO] Building Subsonic stand-alone installer 0.7
[INFO]
[INFO] --- maven-assembly-plugin:2.3:single (make-assembly) @ subsonic-installer-standalone ---
[INFO] Reading assembly descriptor: src/main/assembly/zip.xml
[INFO] BUILD FAILURE
[INFO] Total time: 2.154s
[INFO] Finished at: Sat Dec 15 13:09:37 MYT 2012
[INFO] Final Memory: 9M/168M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-assembly-plugin:2.3:single (make-assembly) on project subsonic-installer-standalone: Failed to create assembly: Unable to resolve dependencies for assembly 'bin': Failed to resolve dependencies for assembly: Unable to get dependency information for net.sourceforge.subsonic:subsonic-main:war:0.7: Failed to process POM for net.sourceforge.subsonic:subsonic-main:war:0.7: Non-resolvable parent POM: Failure to find net.sourceforge.subsonic:subsonic:pom:0.7 in file:repo was cached in the local repository, resolution will not be reattempted until the update interval of local1 has elapsed or updates are forced
[ERROR] net.sourceforge.subsonic:subsonic-main:war:0.7
[ERROR]
[ERROR] from the specified remote repositories:
[ERROR] local1 (file:repo, releases=true, snapshots=true),
[ERROR] local2 (file:../repo, releases=true, snapshots=true),
[ERROR] java_net (http://download.java.net/maven/2/, releases=true, snapshots=true),
[ERROR] central (http://repo1.maven.org/maven2, releases=true, snapshots=false)
[ERROR] Path to dependency:
[ERROR] 1) net.sourceforge.subsonic:subsonic-installer-standalone:pom:0.7
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-assembly-plugin:2.3:single (make-assembly) on project subsonic-installer-standalone: Failed to create assembly: Unable to resolve dependencies for assembly 'bin'
   at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:217)
   at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
   at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
   at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84)
   at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
   at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
   at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
   at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:319)
   at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
   at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
   at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
   at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.lang.reflect.Method.invoke(Method.java:601)
   at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
   at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
   at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
   at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
Caused by: org.apache.maven.plugin.MojoExecutionException: Failed to create assembly: Unable to resolve dependencies for assembly 'bin'
   at org.apache.maven.plugin.assembly.mojos.AbstractAssemblyMojo.execute(AbstractAssemblyMojo.java:511)
   at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101)
   at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209)
   ... 19 more
Caused by: org.apache.maven.plugin.assembly.archive.ArchiveCreationException: Unable to resolve dependencies for assembly 'bin'
   at org.apache.maven.plugin.assembly.archive.DefaultAssemblyArchiver.createArchive(DefaultAssemblyArchiver.java:204)
   at org.apache.maven.plugin.assembly.mojos.AbstractAssemblyMojo.execute(AbstractAssemblyMojo.java:452)
   ... 21 more
Caused by: org.apache.maven.plugin.assembly.artifact.DependencyResolutionException: Failed to resolve dependencies for assembly:
   at org.apache.maven.plugin.assembly.artifact.DefaultDependencyResolver.resolveTransitively(DefaultDependencyResolver.java:207)
   at org.apache.maven.plugin.assembly.artifact.DefaultDependencyResolver.resolve(DefaultDependencyResolver.java:122)
   at org.apache.maven.plugin.assembly.archive.DefaultAssemblyArchiver.createArchive(DefaultAssemblyArchiver.java:176)
   ... 22 more
Caused by: org.apache.maven.artifact.resolver.ArtifactResolutionException: Unable to get dependency information for net.sourceforge.subsonic:subsonic-main:war:0.7: Failed to process POM for net.sourceforge.subsonic:subsonic-main:war:0.7: Non-resolvable parent POM: Failure to find net.sourceforge.subsonic:subsonic:pom:0.7 in file:repo was cached in the local repository, resolution will not be reattempted until the update interval of local1 has elapsed or updates are forced
Path to dependency:
   at org.apache.maven.repository.legacy.resolver.DefaultLegacyArtifactCollector.recurse(DefaultLegacyArtifactCollector.java:576)
   at org.apache.maven.repository.legacy.resolver.DefaultLegacyArtifactCollector.collect(DefaultLegacyArtifactCollector.java:144)
   at org.apache.maven.artifact.resolver.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:464)
   at org.apache.maven.artifact.resolver.DefaultArtifactResolver.resolveWithExceptions(DefaultArtifactResolver.java:320)
   at org.apache.maven.artifact.resolver.DefaultArtifactResolver.resolveTransitively(DefaultArtifactResolver.java:314)
   at org.apache.maven.artifact.resolver.DefaultArtifactResolver.resolveTransitively(DefaultArtifactResolver.java:293)
   at org.apache.maven.artifact.resolver.DefaultArtifactResolver.resolveTransitively(DefaultArtifactResolver.java:271)
   at org.apache.maven.plugin.assembly.artifact.DefaultDependencyResolver.resolveTransitively(DefaultDependencyResolver.java:200)
   ... 24 more
Caused by: org.apache.maven.artifact.metadata.ArtifactMetadataRetrievalException: Failed to process POM for net.sourceforge.subsonic:subsonic-main:war:0.7: Non-resolvable parent POM: Failure to find net.sourceforge.subsonic:subsonic:pom:0.7 in file:repo was cached in the local repository, resolution will not be reattempted until the update interval of local1 has elapsed or updates are forced
   at org.apache.maven.project.artifact.MavenMetadataSource.retrieveRelocatedProject(MavenMetadataSource.java:586)
   at org.apache.maven.project.artifact.MavenMetadataSource.retrieve(MavenMetadataSource.java:192)
   at org.apache.maven.repository.legacy.resolver.DefaultLegacyArtifactCollector.recurse(DefaultLegacyArtifactCollector.java:532)
   ... 31 more
Caused by: org.apache.maven.model.resolution.UnresolvableModelException: Failure to find net.sourceforge.subsonic:subsonic:pom:0.7 in file:repo was cached in the local repository, resolution will not be reattempted until the update interval of local1 has elapsed or updates are forced
   at org.apache.maven.project.ProjectModelResolver.resolveModel(ProjectModelResolver.java:159)
   at org.apache.maven.model.building.DefaultModelBuilder.readParentExternally(DefaultModelBuilder.java:819)
   at org.apache.maven.model.building.DefaultModelBuilder.readParent(DefaultModelBuilder.java:670)
   at org.apache.maven.model.building.DefaultModelBuilder.build(DefaultModelBuilder.java:308)
   at org.apache.maven.model.building.DefaultModelBuilder.build(DefaultModelBuilder.java:232)
   at org.apache.maven.project.DefaultProjectBuilder.build(DefaultProjectBuilder.java:141)
   at org.apache.maven.project.DefaultProjectBuilder.build(DefaultProjectBuilder.java:285)
   at org.apache.maven.project.DefaultProjectBuilder.build(DefaultProjectBuilder.java:243)
   at org.apache.maven.project.artifact.MavenMetadataSource.retrieveRelocatedProject(MavenMetadataSource.java:579)
   ... 33 more
Caused by: org.sonatype.aether.resolution.ArtifactResolutionException: Failure to find net.sourceforge.subsonic:subsonic:pom:0.7 in file:repo was cached in the local repository, resolution will not be reattempted until the update interval of local1 has elapsed or updates are forced
   at org.sonatype.aether.impl.internal.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:541)
   at org.sonatype.aether.impl.internal.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:220)
   at org.sonatype.aether.impl.internal.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:197)
   at org.sonatype.aether.impl.internal.DefaultRepositorySystem.resolveArtifact(DefaultRepositorySystem.java:323)
   at org.apache.maven.project.ProjectModelResolver.resolveModel(ProjectModelResolver.java:155)
   ... 41 more
Caused by: org.sonatype.aether.transfer.ArtifactNotFoundException: Failure to find net.sourceforge.subsonic:subsonic:pom:0.7 in file:repo was cached in the local repository, resolution will not be reattempted until the update interval of local1 has elapsed or updates are forced
   at org.sonatype.aether.impl.internal.DefaultUpdateCheckManager.checkArtifact(DefaultUpdateCheckManager.java:190)
   at org.sonatype.aether.impl.internal.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:430)
   ... 45 more
musicScrape @ Music Cabinet Mod
http://musicscrape.zapto.org:8080
dsync89
Re: Failed to mvn package
Postby hakko » Sat Dec 15, 2012 8:09 am
https://github.com/hakko/subsonic#building
Looks like you're running mvn package in subsonic-installer-standalone, without running mvn install in subsonic-main before. You shouldn't even need to build subsonic-installer-standalone though as it just assembles subsonic-main and subsonic-booter into a common zip file.
MusicCabinet developer
hakko
Postby dsync89 » Sat Dec 15, 2012 8:28 am
I see. Well I did ran mvn install on the subsonic-main folder. Now I'm just copy and paste the .war file under the target folder and it works.
One thing though, why is it that the changes that I did on the more.jsp doesn't show when clicking the Upload. I tried delete the jetty folder in /var/subsonic and still nothing changes.
dsync89
Postby hakko » Sat Dec 15, 2012 8:41 am
You could always check that the version at the About page is 0.7.16b (if that's the version you're running), and that a directory called 0.7.16b has appeared in your jetty directory.
hakko
Postby dsync89 » Sat Dec 15, 2012 9:17 am
Yep I did checked it. It's very weird for it to not change. My previous version works just as fine.
dsync89
Return to MusicCabinet
