Upgrade Failure
Upgrade Failure
Postby wvcs » Sat Jan 05, 2013 2:55 pm
Everytime, I upgrade to the newest release I get the following error:
java.lang.NoClassDefFoundError: Lorg/glassfish/jsp/api/ResourceInjector;
or
The requested service (Servlet jsp.WEB_002dINF.jsp.login_jsp is currently unavailable) is not currently available.
Not sure what I'm doing wrong, but I shutdown tomcat, deploy the new war file and restart tomcat. When that fails, I remove the subsonic directory under webapps, delete the db director in c:\subsonic and it still comes up with the same error.
Bill
wvcs
Re: Upgrade Failure
Postby hakko » Sun Jan 06, 2013 6:35 pm
Are you using the file that is compiled specifically for running on Tomcat? I just tried it on Tomcat7 and it seemed to work for me. http://dilerium.se/musiccabinet/subsonic-tomcat.war
MusicCabinet developer
hakko
Re: Upgrade Failure
Postby wvcs » Mon Jan 14, 2013 1:59 am
Yes, that was the war file I tried to install. Should I make any adjustments before I drop the war file in the webapps directory other than stopping tomcat?
wvcs
Re: Upgrade Failure
Postby hakko » Mon Jan 14, 2013 6:42 am
hakko
Return to MusicCabinet
