Release notes: viewtopic.php?f=4&t=9777&start=15#p51424
Feedback goes here.
delete from music.artistinfo where artist_id in (select id from music.artist where upper(artist_name) = 'Nirvana');
delete from library.webservice_history where calltype_id = 5 and artist_id in (select id from music.artist where upper(artist_name) = 'Nirvana');
hakko wrote:As soon so you edit an artist biography, it'll never be updated from last.fm again (to not overwrite your changes). So you need to delete both your own artist info and the blocking of further lookups.
- Code: Select all
hakko wrote:On Ubuntu, you would run psql -U postgres -d musiccabinet in a terminal (don't know if psql is on your path), which provides a prompt to execute sql commands. Paste the two delete statements for your artist and press enter, then Ctrl+D to exit.
hakko wrote:Also, this (depending on where you connect from): http://stackoverflow.com/questions/2942 ... r-postgres
