Upgrade to Lyrics Plugin version 0.4
Postby Lawman » Thu Jan 17, 2013 10:42 am
Hello Hakko, i am using 7.1.9 and i have started looking into batching my lyrics. I use mediamonkey with a plugin called Lyricator v1.1.1 #31 (2010-12-16) which works great to update the lyrics. I tested it on one one album and within mediamonkey the tags are written with the lyrics.
However, when i play the song in MC and click on the lyrics button i get a message in the pop up window "Upgrade to Lyrics Plugin version 0.4"... can u help ? greetings from snowed in Leipzig..
Lawman
Re: Upgrade to Lyrics Plugin version 0.4
Postby hakko » Thu Jan 17, 2013 11:32 am
Different software writes lyrics in different ways to tags. I would check the header of the mp3 file, you could use foobar for example to do that. Lyrics should be written using the USLT tag (unsynced lyrics). I wonder if you've used another tool that has written "Upgrade to Lyrics Plugin..." to your files. If you open the mp3 file using a text editor (or better yet a hex editor) you will probably find that text as well within them.
MusicCabinet developer
hakko
Return to MusicCabinet
