Error when running MusicCabinet...
Postby ar9 » Fri Feb 01, 2013 12:52 am
Here's my situation, I'll try to be thorough. [Running 64 Bit Windows 7]
Installed Subsonic. It worked just fine.
Intended on installing Music Cabinet, and I followed the instructions.
First, I installed PregreSQL 9.1.
I then installed Java 7 update 11 (64 bit).
I then installed Music Cabinet, over my existing Subsonic install.
When I opened my webGUI, it gave me an error (more on the error at the bottom).
From here, I uninstalled everything, cleared residual folders for Java/Subsonic/PregreSQL. Empty.
This time I let Music Cabinet choose my Java install, and so it installed version 7.
I then installed Music Cabinet+SSonic (not over any existing installation), and I got this error, again.
Error
Exception javax.servlet.jsp.JspTagException
Message Theme 'default': No message found under code 'styleSheet' for locale 'en'.
Java version Oracle Corporation 1.7.0
Server jetty/8.y.z-SNAPSHOT
Memory Used 20 of 35 MB
Stack trace javax.servlet.jsp.JspTagException: Theme 'default': No message found under code 'styleSheet' for locale 'en'.
at org.springframework.web.servlet.tags.MessageTag.doStartTagInternal(MessageTag.java:184)
at org.springframework.web.servlet.tags.RequestContextAwareTag.doStartTag(RequestContextAwareTag.java:79)
at jsp.WEB_002dINF.jsp.login_jsp._jspx_meth_spring_theme_0(login_jsp.java:201)
at jsp.WEB_002dINF.jsp.login_jsp._jspx_meth_c_set_0(login_jsp.java:173)
at jsp.WEB_002dINF.jsp.login_jsp._jspService(login_jsp.java:84)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:111)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:648)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:455)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1072)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:382)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1006)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.Dispatcher.forward(Dispatcher.java:276)
at org.eclipse.jetty.server.Dispatcher.forward(Dispatcher.java:103)
at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:238)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:262)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1157)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:927)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:827)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1336)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:101)
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:139)
at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:54)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1307)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:453)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:559)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:365)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:485)
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:926)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:988)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:635)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:627)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:51)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
at java.lang.Thread.run(Unknown Source)
I am out of ideas... I am a certified IT Tech, and I can't think of any further steps here... haven't had an installation issue like this in years! so hopefully it isn't too cumbersome to troubleshoot.
Thanks all!
ar9
Re: Error when running MusicCabinet...
Postby shadow.8 » Fri Feb 01, 2013 12:59 am
At least one other person is having a theme error (see here). I wonder if something is broken on new installs... The upgrade went well for me. Have you tried an old version? If needed, I can upload the last version for you to test.
676 artists
2,348 albums
26,738 songs
276.51 GB (~ 1,993 hours)
shadow.8
Postby ar9 » Fri Feb 01, 2013 1:02 am
I was thinking it was a theme issue.
Sure, I'll try out an old version if you have one available.
Thanks for the quick reply!
EDIT: Just uninstalled Music Cabinet, ran Subsonic, changed theme to "Back in Black", and installed Music Cabinet over it, hoping it would start up using a different non problematic theme, but no luck at all.
ar9
Postby shadow.8 » Fri Feb 01, 2013 3:01 am
hakko has removed all of the default themes (can't remember why atm) so Back in Black won't exist in Music Cabinet. :)
The previous subsonic.war file can be found here. I believe it's version 0.7.20. Try it and see if you are still having problems. If not, my guess would be your installation of Postgresql or Java. I noticed you re-installed them but I wonder if there are some lingering configuration issues in the registry. One of the many reasons I avoid Windows... :mrgreen:
676 artists
2,348 albums
26,738 songs
shadow.8
Postby ar9 » Fri Feb 01, 2013 4:05 am
Tried the 0.7.20; getting the same error.
Blargh! Super frustrating.
What can we deduce, if Subsonic works on its own, but Music Cabinet does not work?
ar9
Postby giskard41 » Fri Feb 01, 2013 6:00 am
I was the one that posted in the other thread.
I only got the message after updating to 0.7.21. 0.7.20 was OK for me.
I updated by only replacing the old subsonic.war file with new one.
giskard41
Postby ar9 » Fri Feb 01, 2013 6:19 am
giskard41 wrote:I was the one that posted in the other thread.
Where is this .war file you speak of?
I unzipped it and replaced the 0.7.21 files with the contents of the 0.7.20... didn't work for me.
ar9
Postby giskard41 » Fri Feb 01, 2013 6:25 am
I am talking about the way I always upgrade musiccabinet. So the latest subsonic.war file is found here viewtopic.php?f=4&t=9777&p=52242#p52242
giskard41
Postby ar9 » Fri Feb 01, 2013 7:21 am
Sorry, just a bit confused.
So I have the old .war file... but where do I put it/extract it?
=S
Running on Windows...
ar9
Postby giskard41 » Fri Feb 01, 2013 7:39 am
I have this in C:\Program Files\Subsonic
giskard41
Postby giskard41 » Fri Feb 01, 2013 7:46 am
I temporarily fixed this by copying the old subsonic.war posted by shadow.8. So now i'm back on 0.7.20 and it works
giskard41
Postby shadow.8 » Fri Feb 01, 2013 3:34 pm
ar9 wrote:Sorry, just a bit confused.
=S
The subsonic.war file includes all of the core files for Subsonic. Music Cabinet simply replaces the default Subsonic war file. In Windows, the directory is likely C:\Program Files (x86)\Subsonic\ or similar. You should already have the default Subsonic one, just need to replace it with the Music Cabinet war file.
EDIT: I found this link which suggests you need a properties file in the classpath folder. This folder is, apparently, C:\Program Files (x86)\Subsonic\jetty\0.7.21\webapp\WEB-INF\classes. I have a file named "log4j.properties" in my equivalent folder, do you have anything like that? The 0.7.21 folder might be for a different version number (0.7.19 or 0.7.20). The file doesn't mention anything about locale but it might be a good place to start looking. Also, do you have C:\Program Files (x86)\Subsonic\jetty\0.7.21\webapp\style folder? What's in that folder?
676 artists
2,348 albums
26,738 songs
shadow.8
Postby giskard41 » Fri Feb 01, 2013 7:35 pm
These are the contents of style folder:
sigelsonic
artistgenres.css
darksub.css
darksub_default.css
jquery.mCustomScrollbarRed.css
musiccabinet.css
musiccabinet_black.css
musiccabinet_white.css
playericonsRed.css
shadow.css
sigelsonic.css
sigelsonic_default.css
sonic.css
sonic_black.css
sonic_white.css
giskard41
Postby hakko » Fri Feb 01, 2013 11:32 pm
My fault (as usual!). I've put up a new version with the new themes that hopefully works for everyone, not just those of us who've happened to pay Sindre for a license. (that was unintentional)
viewtopic.php?f=4&t=9777&start=15#p52323
MusicCabinet developer
hakko
Postby Eluminare » Mon Feb 25, 2013 7:48 pm
Hello together,
i encounter an error after hitting the Button "upgrade Database".
Can anyone help me with this?
Error
Exception org.springframework.jdbc.BadSqlGrammarException
Message StatementCallback; bad SQL grammar [create or replace function load_1000() returns int as $$ begin -- Util schema: meta functionality for database create schema util; create table util.musiccabinet_version (update_id integer not null, insert_time timestamp not null default now()); -- Music schema: abstract information on artist, tracks, (global) ratings and relations create schema music; create table music.tag (id serial primary key, tag_name text not null); create table music.artist (id serial primary key, artist_name text); create table music.track (artist_id integer references music.artist (id), id serial primary key, track_name text); create table music.trackrelation (source_id integer references music.track (id) not null, target_id integer references music.track (id) not null, weight float not null); create table music.trackrelation_import (source_id integer not null, target_id integer references music.track (id), target_artist_name text not null, target_track_name text not null, target_artist_id integer references music.artist (id), weight float not null); create table music.artistrelation (source_id integer references music.artist (id) not null, target_id integer references music.artist (id) not null, weight float not null); create table music.artistrelation_import (source_id integer not null, target_id integer references music.artist (id), target_artist_name text not null, weight float not null); create table music.artisttoptrack (artist_id integer references music.artist (id) not null, track_id integer references music.track (id) not null, rank smallint not null); create table music.artisttoptrack_import (artist_id integer references music.artist (id) not null, track_id integer references music.track (id), track_name text not null, rank smallint not null); create table music.artisttoptag (artist_id integer references music.artist (id) not null, tag_id integer references music.tag (id) not null, tag_count smallint not null); create table music.artisttoptag_import (artist_id integer references music.artist (id) not null, tag_id integer references music.tag (id), tag_name text not null, tag_count smallint not null); create unique index artistrelation_sourceid_targetid on music.artistrelation (source_id, target_id); create unique index tag_tagname_id on music.tag (tag_name, id); create unique index artisttoptag_tagid_artistid_tagcount on music.artisttoptag (tag_id, artist_id, tag_count); -- Library schema: personal information, such as local music files, personal ratings, invoked web service calls create schema library; create table library.musicfile (track_id integer references music.track (id) not null, id serial primary key, path text, created timestamp, last_modified timestamp, external_id text); create table library.musicfile_import (artist_name text, artist_id integer references music.artist (id), track_name text, track_id integer references music.track (id), path text, created timestamp, last_modified timestamp, external_id text); create table library.musicdirectory (artist_id integer references music.artist (id) not null, id serial primary key, path text, root boolean); create table library.musicdirectory_import (artist_id integer references music.artist (id), artist_name text not null, path text, root boolean); create table library.trackplaycount (track_id integer references music.track (id) not null, play_count integer); create table library.trackplaycount_import (artist_name text, artist_id integer references music.artist (id), track_name text, track_id integer references music.track (id), play_count integer); create table library.webservice_calltype (id smallint primary key, description text); create table library.webservice_history (artist_id integer references music.artist (id), track_id integer references music.track (id), calltype_id smallint references library.webservice_calltype (id), page smallint, invocation_time timestamp default now()); create table library.artisttoptrackplaycount (music_file_id integer references library.musicfile (id) not null, artist_id integer not null references music.artist (id), rank smallint not null, play_count integer not null); insert into library.webservice_calltype (id, description) values (0, 'Last.fm library.getTracks (used for track playcount)'); insert into library.webservice_calltype (id, description) values (1, 'Last.fm artist.getSimilar'); insert into library.webservice_calltype (id, description) values (2, 'Last.fm artist.getTopTracks'); insert into library.webservice_calltype (id, description) values (3, 'Last.fm track.getSimilar'); insert into library.webservice_calltype (id, description) values (4, 'Last.fm artist.getTopTags'); create unique index musicfile_path_trackid on library.musicfile (path, track_id); create unique index musicdirectory_path_artistid on library.musicdirectory (path, artist_id); insert into util.musiccabinet_version (update_id) values (1000); return 0; end; $$ language plpgsql;]; nested exception is org.postgresql.util.PSQLException: FEHLER: Sprache »plpgsql« existiert nicht Hinweis: Sie müssen CREATE LANGUAGE verwenden, um die Sprache in die Datenbank zu laden.
Java version Oracle Corporation 1.7.0_15
Operating system Linux 2.6.32-279.22.1.el6.x86_64
Server Apache Tomcat/7.0.37
Memory Used 56 of 109 MB
Stack trace org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [create or replace function load_1000() returns int as $$ begin
create schema util;
return 0;
at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:98)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:407)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:428)
at com.github.hakko.musiccabinet.dao.jdbc.JdbcDatabaseAdministrationDao.loadDatabaseUpdate(JdbcDatabaseAdministrationDao.java:208)
at com.github.hakko.musiccabinet.service.DatabaseAdministrationService.loadNewDatabaseUpdates(DatabaseAdministrationService.java:105)
at net.sourceforge.subsonic.controller.MusicCabinetSettingsController.doSubmitAction(MusicCabinetSettingsController.java:98)
at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:449)
at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:415)
at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:387)
at org.springframework.web.servlet.mvc.SimpleFormController.processFormSubmission(SimpleFormController.java:272)
at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:268)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:900)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:936)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1004)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: org.postgresql.util.PSQLException: FEHLER: Sprache »plpgsql« existiert nicht
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2102)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1835)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:500)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:374)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:366)
at com.mchange.v2.c3p0.impl.NewProxyStatement.execute(NewProxyStatement.java:108)
at org.springframework.jdbc.core.JdbcTemplate$1ExecuteStatementCallback.doInStatement(JdbcTemplate.java:421)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:396)
... 71 more
Eluminare
Return to MusicCabinet
