No lyrics found
No lyrics found
Postby rmnma » Mon Feb 04, 2013 6:51 pm
I am new to subsonic/musiccabinet. Great project!
I have one question. Some of my mp3's contains lyrics in the UNSYNCEDLYRICS field. I used mp3tag for this job. The lyrics doesn't show up in dsub on my android phone. Is that right or am I missing something?
rmnma
Re: No lyrics found
Postby daneren2005 » Mon Feb 04, 2013 7:12 pm
While the client (DSub) is requesting the lyrics from the server, I'm not sure if MusicCabinet pulls the embedded lyrics out to send or not. I know the original Subsonic server just tries to pull them from a 3d party service. That might be something the dev could add to MusicCabinet so that if the lyrics are embedded they are sent instead of trying to pull them from somewhere else.
Re: No lyrics found
Postby hakko » Mon Feb 04, 2013 8:49 pm
Mm, I use embedded lyrics in the web interface, but not for mobile apps. Should be fairly simple to add it there too.
MusicCabinet developer
hakko
Re: No lyrics found
Postby rmnma » Mon Feb 04, 2013 8:58 pm
Can you do that for me? Or should I ask it to somebody else? Thank you in advance!
rmnma
Re: No lyrics found
Postby hakko » Wed Feb 13, 2013 8:08 pm
hakko
Re: No lyrics found
Postby rmnma » Fri Feb 15, 2013 9:04 am
hakko wrote:Implemented in 0.7.22: viewtopic.php?f=4&t=9777&p=52975#p52975
Thank you!
rmnma
Return to MusicCabinet
