images loading only about 50% of the time
Postby dsnhdiv » Tue Feb 12, 2013 3:51 pm
I am having an issue as of about 2 versions ago where the images I try to pull in from other sites are either broken and shows a while image with a broken file indicator. The other thing it does is the google image search, I find an image I like, I choose that image and it flashes to "Image was successfully downloaded." then when I go back to the image it does not have any image at all.
Is this an issue on my end or is this a bug?
Marc
8,572 artists
29,260 albums
212,737 songs
2556.54 GB
23,957 hours
dsnhdiv
Re: images loading only about 50% of the time
Postby hakko » Tue Feb 12, 2013 4:11 pm
If you scan your library after having downloaded the image from the Google image search to have it used as album art, does it appear then?
MusicCabinet developer
hakko
Postby dsnhdiv » Tue Feb 12, 2013 6:55 pm
I just did a collection refresh to verify and neither of the two issues I am having are resolved by a refresh. I loaded one with a direct image URL from www.discogs.com and one from a google image search from another website, this google image search one went really fast so it does not seem like it is actually downloading anything, and both show broken images. When I go into the folder in my file system the images are actually corrupt and will not open in windows either.
I can give you a test account to my server if you like so you can see the behavior unless you want me to try something else.
Marc
8,572 artists
29,260 albums
212,737 songs
2556.54 GB
23,957 hours
dsnhdiv
Return to MusicCabinet
