Missing Artists/Music
Postby KicknGuitar » Tue Feb 19, 2013 11:43 am
Just began using MusicCab and have been loving it. Unfortunately I just began having some issues with artists not being included. I double checked the folders and everything is there must MusicCab refuses to pick them up and add them to the list. I've tried re-scanning and restarting but to no luck. When I look through the subsonic.log, it doesn't even mention scanning the folder(s), as if they don't exist!
Does this sound like a Cab issue or Subsonic?
What can I do? Cheers.
I'm running:
0.7.22 on a Mac
The beauty of sharing one's work:
Subsonic • MusicCabinet • Madsonic
KicknGuitar
Re: Missing Artists/Music
Postby hakko » Tue Feb 19, 2013 11:56 am
Make sure you've spelled the Media Folders directory correctly (uppercase/lowercase matters). Go to the file tree view to see what's been found in a directory. Check Settings -> Media folders to see if some of your files are missing required tags (artist, title), then they won't be included. subsonic.log does not contain a log of what's being scanned. You could check musiccabinet.log, location found from the About view. It's also relevant if a whole folder is not being added or if just a couple of files from a certain folder are not added.
MusicCabinet developer
hakko
Postby KicknGuitar » Tue Feb 19, 2013 12:17 pm
hakko wrote:Make sure you've spelled the Media Folders directory correctly (uppercase/lowercase matters). Go to the file tree view to see what's been found in a directory. Check Settings -> Media folders to see if some of your files are missing required tags (artist, title), then they won't be included. subsonic.log does not contain a log of what's being scanned. You could check musiccabinet.log, location found from the About view. It's also relevant if a whole folder is not being added or if just a couple of files from a certain folder are not added.
My apologies for not investigating this further as I may be onto a solution. It appears all the missing artists have special characters (ie Esbjörn Svensson Trio). This realization brought me to this thread which offered this as a solution,
wowo wrote:First disable Subsonic.
Then you must add the following code to the subsonic.sh file almost at the beginning right after the line "SUBSONIC_DEFAULT_PLAYLIST_FOLDER=/var/playlists"
Mind the " !!!! they are essential otherwise it won't work.
export LANG="en_US.UTF-8"
export LC_CTYPE="en_US.UTF-8"
Finally you can see Björk :D and other artists, albums and tracks with international characters.
I had also to change the default music folder and then changed it back to the normal default music folder then it works for me. :D
Sorry for my bad English.
Here's to hoping it works smoothly. Thanks for the badass mod.
Edit: It worked. For some reason I could have sworn Subsonic read it all before, maybe I just never noticed.
KicknGuitar
Return to MusicCabinet
