"Could not get JDBC Connection" error on setup
Postby destria » Wed Apr 03, 2013 8:14 am
I'm attempting to install MusicCabinet over Subsonic (installed via RPM) on CentOS 6.3.
I've done the following (pretty much following these instructions: http://virtuallyhyper.com/2013/02/installing-musiccabinet-on-top-of-subsonic/, except where they varied slightly):
Installed Java 1.7
Installed Postgresql 9.2 and initialised the database
Copied the .jar and .war files over the existing files in /usr/share/subsonic
Restarted everything
When I try to enter the Settings menu once it's all fired up, I get a "Message Could not get JDBC Connection; nested exception is java.sql.SQLException: Connections could not be acquired from the underlying database!" error.
The subsonic.log file is as below:
[2013-04-03 09:04:58,113] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Wed Apr 03 09:09:58 BST 2013
[2013-04-03 09:04:58,160] WARN Util - Failed to resolve local IP address.
java.net.UnknownHostException: mediaserver.colinshouse: mediaserver.colinshouse: Name or service not known
at java.net.InetAddress.getLocalHost(InetAddress.java:1438)
at net.sourceforge.subsonic.util.Util.getLocalIpAddress(Util.java:100)
at net.sourceforge.subsonic.service.NetworkService$URLRedirectionTask.execute(NetworkService.java:232)
at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:302)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:351)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:178)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:178)
Does anyone have any suggestions?
destria
Re: "Could not get JDBC Connection" error on setup
Postby hakko » Wed Apr 03, 2013 8:23 am
Is mediaserver.colinshouse defined in your /etc/hosts?
MusicCabinet developer
hakko
Postby destria » Wed Apr 03, 2013 8:59 am
Oops. That seemed to get past that.
I'm still getting the JDBC error though, but now the log file is saying:
[2013-04-03 09:56:13,035] WARN com.mchange.v2.resourcepool.BasicResourcePool - com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@4c9a3337 -- Acquisition Attempt Failed!!! Clearing pending acquires. While trying to acquire a needed new resource, we failed to succeed more than the maximum number of allowed acquisition attempts (1). Last acquisition attempt exception:
org.postgresql.util.PSQLException: FATAL: password authentication failed for user "postgres"
I know roughly what that means, but I was under the impression that I'd use the config screen to set the password. Presumably there's something up with my Postgres setup.
destria
Postby hakko » Wed Apr 03, 2013 11:07 am
You'll get that error in the log files until you have configured/told MusicCabinet what password to use when connecting to PostgreSQL. Don't worry, it's not really an error.
hakko
Postby destria » Wed Apr 03, 2013 11:17 am
Unfortunately I can't get to that stage, 'cause I'm still getting the "Message Could not get JDBC Connection; nested exception is java.sql.SQLException: Connections could not be acquired from the underlying database!" error.
I wonder if this is trying to connect to the original Subsonic database? I notice that when I revert to the original SubSonic code I can't log in at all ("Invalid password") and have to delete the database and start over.
destria
Postby hakko » Wed Apr 03, 2013 11:21 am
The default behavior for PostgreSQL is to only accept connections from localhost. If you have a more complicated network setup, you'll have to configure PostgreSQL to accept connections from whatever other domain the connections are coming from.
hakko
Postby destria » Wed Apr 03, 2013 11:29 am
In theory it's all running on the same server. Though I guess something is trying to look for mediaserver.colinshouse rather than localhost. I'll fish around and see if I can track that down and/or open up Postgres to the whole wide world
destria
Postby hakko » Wed Apr 03, 2013 11:49 am
Easiest thing is probably to run psql -U postgres and make sure that works (and Google search eventual error messages).
hakko
Postby destria » Wed Apr 03, 2013 12:00 pm
That seems to work fine. I've had a quick poke around in postgres. There's a schema "public" set up under user "postgres".
destria
Postby hakko » Wed Apr 03, 2013 12:03 pm
So what happens when you go to localhost:4040 in a browser?
hakko
Postby destria » Wed Apr 03, 2013 1:22 pm
I get the Subsonic login, with the Media Cabinet branding.
When I log in, using the original SubSonic username/password, I get the start-up screen telling me to install Postgres etc.
And when I go to "Settings", I get the error message attached.
destria
Attachment didn't work... error message as attached below
destria
Postby hakko » Wed Apr 03, 2013 9:03 pm
What does the musiccabinet.log file say? You can find the location for it from the About view.
hakko
Postby destria » Thu Apr 04, 2013 8:19 am
Not a lot. It just says:
[2013-04-04 09:15:29] INFO PlaylistGeneratorService - MusicCabinet playlist service started at Thu Apr 04 09:15:29 BST 2013.
[2013-04-04 09:15:30] DEBUG DatabaseAdministrationService - databaseUpdated = false
[2013-04-04 09:15:30] DEBUG DatabaseAdministrationService - databaseCreated = false
[2013-04-04 09:15:31] DEBUG PlaylistGeneratorService - allowed radio song length interval (45, 600)
I've attached my subsonic.log and subsonic_sh.log. I cleared them out, started Subsonic, tried to enter the "Settings" menu, got the error, and then stopped the Subsonic service.
Thanks for taking the time to assist
destria
Postby destria » Thu Apr 04, 2013 1:32 pm
Looking at the log, this seems to be the pertinent section:
2013-04-04 09:15:36.917:WARN:oejs.ServletHandler:/mediaFolderSettings.view
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: Connections could not be acquired from the underlying database!
at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:80)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:456)
at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:464)
at com.github.hakko.musiccabinet.dao.jdbc.JdbcLibraryBrowserDao.getFilesMissingMetadata(JdbcLibraryBrowserDao.java:741)
at com.github.hakko.musiccabinet.service.LibraryBrowserService.getFilesMissingMetadata(LibraryBrowserService.java:143)
at net.sourceforge.subsonic.controller.MediaFolderSettingsController.handleRequestInternal(MediaFolderSettingsController.java:79)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:900)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:827)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:648)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1336)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:101)
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:54)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1307)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:453)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:559)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1072)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:382)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1006)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:365)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:485)
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:926)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:988)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:635)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:627)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:51)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
at java.lang.Thread.run(Thread.java:722)
Caused by:
at com.mchange.v2.sql.SqlUtils.toSQLException(SqlUtils.java:106)
at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool.checkoutPooledConnection(C3P0PooledConnectionPool.java:641)
at com.mchange.v2.c3p0.impl.AbstractPoolBackedDataSource.getConnection(AbstractPoolBackedDataSource.java:128)
at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:111)
at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:77)
Caused by:
com.mchange.v2.resourcepool.CannotAcquireResourceException: A ResourcePool could not acquire a resource from its primary factory or source.
at com.mchange.v2.resourcepool.BasicResourcePool.awaitAvailable(BasicResourcePool.java:1406)
at com.mchange.v2.resourcepool.BasicResourcePool.prelimCheckoutResource(BasicResourcePool.java:594)
at com.mchange.v2.resourcepool.BasicResourcePool.checkoutResource(BasicResourcePool.java:514)
at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool.checkoutAndMarkConnectionInUse(C3P0PooledConnectionPool.java:707)
at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool.checkoutPooledConnection(C3P0PooledConnectionPool.java:634)
destria
Return to MusicCabinet
