zoic21 wrote:Hi
I have a little probleme with minsub : when I play a long music, arrived at 4.18min (for apps chrome) or 4.08min (for site web) the music stop.
RRRob wrote:I'm seeing a different, mostly cosmetic problem. After songs have been playing in MiniSub for a while, the playback progress bar and elapsed/total track times disappear. Music continues to play and respond to the controls, but you can no longer see where you are in a track, or click on the progress bar to jump to another time in the currently playing track (since there's no visible progress indicator).
tsquillario wrote:RRRob wrote:I'm seeing a different, mostly cosmetic problem. After songs have been playing in MiniSub for a while, the playback progress bar and elapsed/total track times disappear. Music continues to play and respond to the controls, but you can no longer see where you are in a track, or click on the progress bar to jump to another time in the currently playing track (since there's no visible progress indicator).
Please provide the browser version you are using.
Error loading: "http://<mydomain>.subsonic.org/rest/stream.view?u=admin&p=enc:485833735a733671664d37614d45504466394a4472367a7142&v=1.7.0&c=MiniSub&f=jsonp&id=2f55736572732f726f622f4d757369632f6954756e65732f6954756e6573204d656469612f4d757369632f54686520416c616e20506172736f6e732050726f6a6563742f507972616d69642f303620496e20746865204c6170206f662074686520476f64732e6d3461"/var/subsonic/jetty/####/webapp/MiniSubtygerfish wrote:I don't seem to be able to get this working...
tygerfish wrote:tygerfish wrote:I don't seem to be able to get this working...
Ohhhh... I figured it out -- for some reason I thought I should enter the endpoint from the perspective of the server that MiniSub is sitting on. Once I put in my regular external Subsonic URL it worked fine!
Return to Jamstash (formerly MiniSub)
