tsquillario wrote:Yea, I looked at this a while ago. The way the API is structured it wasn't so easy. I'll have to have another look at it.
Thank you for taking another look at it.
[23:28:35.686] soundManager.createSound(): Audio support is not available. @ file://[...]/tsquillario-MiniSub-0fa9a12/js/sm/soundmanager2-jsmin.js:76
[23:28:35.688] TypeError: audio.play is not a function @ file://[...]/tsquillario-MiniSub-0fa9a12/js/libs/player.js:115c0bra99 wrote:I use HTTPS to access subsonic, when I first visit in chrome I have to click Proceed on the invalid certificate warning, is it possible to make MiniSub ignore certificate errors or at least prompt to continue on cert errors? Currently when it loads it does nothing, I open my subsonic URL in another tab, accept the certificate, and then it will load in MiniSub
cellulit wrote:I'm sure a few people reported it already, but maybe not that config.
Everything works great, but playing music
subsonic 4.6 over https (no issues browsing or with the certificate)
firefox 14 on mac
and in the console:
- Code: Select all
any idea?
tsquillario wrote:dlight wrote:Trying to use Miniplayer on my google Chrome browser.
I have verified that my URL is proper, however the interface never displays any of my music. (URL is HTTPS)
This, of course, works fine when just browsing directly to my Subsonic install.
I enabled Debug in the config, but can't seem to find out where it logs to. Anyone have any ideas what might be wrong, or where I might find more data to help solve my problem?
ETA: Im running Subsonic 4.6 (build 2583) – December 6, 2011
This is most likely caused by a self-signed certificate. Are you using the Chrome App or do you have the files in your local subsonic install?
[09:06:49.691] soundManager.createSound(): Audio support is not available. @ file:///.../Desktop/tsquillario-MiniSub-ae49d25/js/sm/soundmanager2-jsmin.js:76
[09:06:49.704] TypeError: audio.play is not a function @ file:///.../Desktop/tsquillario-MiniSub-ae49d25/js/libs/player.js:115cellulit wrote:Thanks for the tweak, however... for some reason I'm still getting same message:
- Code: Select all
cellulit wrote:Argh.... RTFM
Yes, it works. Even on FF14 and with HTML5 player. Thanks!
Now it'd be great to have it as a standard, multi-user GUI.
Return to Jamstash (formerly MiniSub)
