Country Life Dreams wrote:Was also getting the blank screen until I added a / at the end of the url after the port number then all seemed to work fine.
/ added where? In the MiniSub app? Can you please explain?
kayvee wrote:Okay, I finally got it to work - sort of.
In the MiniSub settings page, I was entering my server address as: xxx.subsonic.org Instead, I tried https://xxx.dyndns.org:1234/ and that worked. I see the albums/tracks populated. But the problem is that tracks refuse to play in Firefox on my Mac. Every time I try to play, Firefox crashes. This may be unrelated to MiniSub though because I notice the exact same behavior when I try to listen to tracks using the regular subsonic web interface on Mac Firefox.
On Safari, MiniSub works as expected. The tracks/albums list is displayed and I am able to select and play tracks. The problem here is that of the track lengths. As reported in the previous posts, I too see the NaN:NaN/00:00 for track length.
NLclothing wrote:Any chance we could see a darker contrast theme?
I love what you've done, with the exception of subsonic settings and other edit features (like tags/metadata) I am using your version of subsonic almost exclusively!
grumpwagon wrote:Not that I don't trust you, but what is the new permission for?
grumpwagon wrote:Seems to work just fine, thanks for the update!
On a different subject, it seems like you scrape the auto albums from Subsonic, correct? I'd love a previous/next page option, if that's possible. I've just turned up the number of albums for now, and that's worked fine.
Secondly, If I'm wrong about that and you don't scrape them directly, would it be possible to filter out albums based on the folder they're in? I'd like to be able to select random from a specific folder.
Slate8 wrote:New MiniSub user here. Just wanted to say I am liking MiniSub big lots, so thanks
I know it has been mentioned earlier in this thread, but has there been any progress with Jukebox mode support?
Thanks, and keep up the good work. It's appreciated.
tsquillario wrote:Slate8 wrote:New MiniSub user here. Just wanted to say I am liking MiniSub big lots, so thanks
These are the controls provided by the Subsonic API for Jukebox mode.
http://www.subsonic.org/pages/api.jsp#jukeboxControl
Tell me how you use the Jukebox mode so I can better understand it. I don't use it.
Return to Jamstash (formerly MiniSub)
