smrq wrote:Awesome
Trivial last.fm support would be something like: scrobble a track as soon as it starts playing.
Standard support would be: Send a "now playing" notification as soon as it starts playing, scrobble after a certain amount has played. (Last I checked, the official last.fm client uses: scrobble after 50% of the track has played, with a minimum of 31 secs and a maximum of 8 minutes.) I'm pretty sure the JW Player API makes this possible.
The Subsonic API for sending scrobbling/now playing notifications looks really simple.
tsquillario wrote:Yea that's what I would use. IMO, sindre should include this functionality in Subsonic since the option to enable the last.fm support is in the settings. It should just scrobble and post the now playing data in the background without the API even knowing.
I'll look what I can do on my end but I think a feature request should be added for this.
phynias wrote:everything works great except no album art shows up.
when i go to an image url i get the error
Exception java.io.IOException
Message Failed to create thumbnail for D:\Stuff\!Music\J.....\Plane.mp3. Could not initialize class sun.java2d.Disposer
Java version Sun Microsystems Inc. 1.6.0_26
Server jetty-6.1.x
Memory Used 60 of 78 MB
ecleese wrote:I'm having difficulties playing a selected track within search results.
After searching, results are displayed but I cannot play any of them. If you click on one or ctrl+click or shift+click multiple, it places a check mark next to each one but I'm unsure what this is meant for. I tried using the <+ Playlist> button at the top thinking it may add the selected tracks to a new playlist but that didn't seem to create a new playlist or add to the currently playing one.
The only way I was able to play any song within search results was if I was currently playing the last song in a playlist or the only song playing and I press the keyboard shortcut for track advance it would start playing the first search result track. From there I could continue to press the keyboard shortcut for track advance and it goes down the list of search results playing each one.
Is this portion still a work in progress?
Software:
Windows 7 X64
Google Chrome (15.0.874.106 beta-m)
MiniSub (.014)
fractalsystems wrote:Came across this thread looking for a flash alternative for video...anyway, I had to say to tsquillario in the OP GRATE taste in music!![]()
Software:
Windows 7 X64
MiniSub (.014)
Return to Jamstash (formerly MiniSub)
