MiniSub - Subsonic HTML5 Web App (Archive)
Jamstash is an HTML5 Mini Player for the Subsonic streaming server
Re: Subsonic HTML5 MiniPlayer
Postby zapt0 » Wed Jan 18, 2012 10:49 pm
tsquillario wrote:@zapt0
No volume control support in the currently released version of AudioJS. It appears to be in the works however. As soon as they implement it I can too! I might look at switching HTML5 audio libraries to a more powerful one, but that will take some time.
Thanks, I didn't know AudioJS didn't provide volume control.
zapt0
Postby bobdylansdead » Thu Jan 19, 2012 3:26 pm
Man, this mod is getting better and better! Just wanted to pop in and say thanks!
bobdylansdead
Postby runagt2 » Thu Jan 19, 2012 6:16 pm
I just got started with Subsonic and I am really liking the MiniSub interface! I noticed a bug in the newest update, where if you press the "Refresh Artist List" button, it will add an extra A-Z static scroll list. I also noticed that the total time for some VBR tracks varies on the progress bar. This doesn't occur on all VBR tracks, so I can't figure out exactly how to duplicate it, but I'll keep testing it.
Would there be any way I can send a browser directly to the MiniSub interface after login, instead of going to Subsonic's /index.view page?
runagt2
Postby tsquillario » Thu Jan 19, 2012 6:31 pm
runagt2 wrote:I just got started with Subsonic and I am really liking the MiniSub interface! I noticed a bug in the newest update, where if you press the "Refresh Artist List" button, it will add an extra A-Z static scroll list. I also noticed that the total time for some VBR tracks varies on the progress bar. This doesn't occur on all VBR tracks, so I can't figure out exactly how to duplicate it, but I'll keep testing it.
Thanks for the bug, I am able to replicate.
This is something that sindre (developer of Subsonic) needs to implement. If he would capture the page referrer on the login page, then redirect after a successful login, that would work. MiniSub isn't really a theme, it just uses the Subsonic API and is being hosted by the same webserver. If you click Remember Me, you won't have to login every time. I wish MiniSub could be better integrated, but I think it's the nature of the beast at this point.
Jamstash Developer
Chrome App - https://chrome.google.com/webstore/detail/jccdpflnecheidefpofmlblgebobbloc
Beta Site - http://beta.jamstash.com
GitHub Project - https://github.com/tsquillario/Jamstash
tsquillario
Postby knibbeje » Sat Jan 21, 2012 3:18 am
Hi can you help? I downloaded the zip file and inside are several folders and files. I'm told I can put that folder (with all the other stuff inside) into my 'subsonic main folder' Which folder is that? I have a folder called subsonic under my C: drive (with folders inside called 'db' 'lucene' 'transcode' etc, and then under C:/Program Files I have a subsonic folder there as well with a bunch of files including what looks like an executable JAR file. I tried calling the folder I downloaded 'minisub' and then putting it in either place, then going to my localhost:port like I usually do and I get a 404 error. I tried typing in my localhost:port and then adding the name of that folder and that didn't work either. Help would be great! I'm using Win XP Home with Firefox.
JDK
knibbeje
Postby tsquillario » Sun Jan 22, 2012 2:41 pm
knibbeje wrote:Hi can you help? I downloaded the zip file and inside are several folders and files. I'm told I can put that folder (with all the other stuff inside) into my 'subsonic main folder' Which folder is that? I have a folder called subsonic under my C: drive (with folders inside called 'db' 'lucene' 'transcode' etc, and then under C:/Program Files I have a subsonic folder there as well with a bunch of files including what looks like an executable JAR file. I tried calling the folder I downloaded 'minisub' and then putting it in either place, then going to my localhost:port like I usually do and I get a 404 error. I tried typing in my localhost:port and then adding the name of that folder and that didn't work either. Help would be great! I'm using Win XP Home with Firefox.
JDK
C:\subsonic\jetty\2583\webapp\MiniSub
to
http://localhost:port/MiniSub
It is case sensitive.
Jamstash Developer
tsquillario
Postby runagt2 » Wed Jan 25, 2012 6:05 am
Found another strange bug, if I want to browse an artist whose name starts with a number, e.g. (I'm sorry) 50 Cent, his name is blocked by the static A-XYZ list you implemented in the last update. I typically use Chrome, but I tried Opera and Firefox too and I just can't get to the number listings.
Still, I am loving MiniSub and I've been able to share my collection with friends. Pretty cool.
runagt2
Postby tsquillario » Wed Jan 25, 2012 2:50 pm
Pushed an update to Git. Fixed both bugs with the Artist list.
1/25/2012 .020 table layout for songs, bug fixes, display tweaks
Jamstash Developer
tsquillario
Postby Munger » Mon Feb 06, 2012 4:21 pm
OK. I got this installed and it looks great, but I'm not getting any music listed. My API key is fully paid up. Any Ideas?
Munger
Postby tsquillario » Wed Feb 08, 2012 6:00 pm
Munger wrote:OK. I got this installed and it looks great, but I'm not getting any music listed. My API key is fully paid up. Any Ideas?
For anyone with a similar issue...
If your URL looks like http://host:port/subsonic/index.view you will need to specify the Subdirectory of subsonic on the Preferences tab. The "default" Subsonic install URL will look like http://host:port/index.view
I believe this is pretty typical with Tomcat setups.
Jamstash Developer
tsquillario
Postby FesterHead » Thu Feb 09, 2012 12:19 am
Great application; does exactly what I needed and easy to use!
Load a playlist, shuffle it, and play through it.
Hope you don't mind that I added a few issues to GitHub.
FesterHead
Postby mcleanap » Thu Feb 16, 2012 1:52 am
Any idea how to install this on a stand alone version of Subsonic?
mcleanap
Postby FesterHead » Thu Feb 16, 2012 4:31 pm
Copy the "MiniSub" folder to C:\subsonic\jetty\2583\webapp
FesterHead
Postby tsquillario » Thu Feb 16, 2012 4:37 pm
FesterHead wrote:Great application; does exactly what I needed and easy to use!
I saw the issues you posted. Hopefully I'll get a chance to look into them more deeply in the next week or so. Thanks ;)
Jamstash Developer
tsquillario
Postby mcleanap » Thu Feb 16, 2012 8:40 pm
FesterHead wrote:Copy the "MiniSub" folder to C:\subsonic\jetty\2583\webapp
Hmm...don't see anything like this.
The standalone version I have only has about 6 files.
I've installed this on an unRAID server with the standalone version...not sure if that matters.
mcleanap
Return to Jamstash (formerly MiniSub)
