SparkyRih wrote:I really would like to look into the FB connectivity, but I'm so busy with other projects lately.... If I have some time left I will dive into it, but I can't promise anything in a short period of time...
Excessive wrote:OK, so I downloaded the fix and edited out the Schattorie.nl stuff, but when I tested it with the space it worked good with the warning, though if I try to register a one word (proper) user name from there onwards I get this on the next page:
Fatal error: Call to undefined function open_https_url() in C:\wamp\www\gbuser\register.php on line 64
Using version 200_4.6 with 211_4.6 register.php.
Excessive wrote:I'm using version 200-46 with 211-46 register.php.
Version 2.00-X.X
-Added support for regestering users in multihost image hoster.
-Added feature to approve users before they can use their credentials (optional, turned off by default).
Version 2.02-X.X
-Update login script.
Version 2.05-X.X
-Added support for https protocol (default setting: http).
Version 2.10-X.X
-Fixed bugs in https support.
-Cleaned up code.
Version 2.11-X.X
-Added a check to check for space in a username (which is not properly supported by Subsonic).
Excessive wrote:OK, all fixed, everything working! Thanks again.
PS Can I pm you Sparky, I want to ask something in private?!
<iframe src="https://www.facebook.com/plugins/registration?
client_id=(my ID)&
redirect_uri=(my website)/registerfb.php&
fields=
{'name':'name'},
{'name':'Username', 'description':'Choose A Username', 'type':'text', 'no_submit':'true'}
{'name':'email'},
{'name':'password'},
{'name':'captcha'}
scrolling="auto"
frameborder="yes"
style="border:none"
allowTransparency="true"
width="500"
height="500">
</iframe>
Return to Subsonic Registration Engine
