[SOLVED] Database issue
A little external engine to register users in Subsonic
Postby XJRodzx » Fri Jan 04, 2013 7:26 pm
I saw on the OP for the reg engine that a few people were having this issue I am having which is, users get registered to mysql but not to subsonic. Ive made sure that my config had the proper credentials and that Curl was enabled and nothing...
I want to mention, I did have this 100% working prior to wiping and re-installing Ubuntu. Before I wiped, I backed up both the subregengine folder and the login.jsp and restored them on the new install. For web server I am using Xampp.
Does anyone have any ideas as to what the problem can be?
XJRodzx
Re: Database issue
Postby XJRodzx » Fri Jan 04, 2013 7:46 pm
This is my Config.php
<?php
//Database  connetion
$dbhost = "localhost";
$dbuser = "root";
$dbpass = "";
$dbname = "subsonicusers";
$usertable = "users";
$woausertable = "woausers";
$multihosttable = "multihost";
$connect = mysql_connect($dbhost, $dbuser, $dbpass) or die('Cannot connect to the database, username or password are wrong.');
mysql_select_db($dbname, $connect) or die("Cannot connect database tot '$db_name'.");
//Register settings
$dbreg = true; //Register users in Global DB.
$subsonicreg = true; //Register users in Subsonic.
$multihostreg = false; //Register users in a multihost DB
$woa = false; //Enable approval feature. This will require the admin to approve users before they can user their credentials.
$woaadmin = "Marc"; //If the previous setting is true, give the name of the user who may approve users (only 1 user possible, make sure to use lower/upper case characters).
//Set subsonic permisions
$protocol = "http"; //can be http or https... Don't foreget to CHMOD the tmp directory if you use https...
$subsonicdomain = "MyIP:Port"; //Example: example.org or mydomain.com:81
$admin = "myusername";
$pass = "mypassword";
$settingsRole = false;
$streamRole = true;
$jukeboxRole = false;
$downloadRole = false;
$uploadRole = false;
$playlistRole = false;
$coverartRole = false;
$commentRole = false;
$podcastRole = false;
$shareRole = true;
//Auto register mail & Pass reset mail
//Zie: lib/mailconf.php
XJRodzx
Re: Database issue
Postby gurutech » Sat Jan 05, 2013 6:39 pm
Can you post your register.php and signature.php files as well?
As far as I can tell, the config.php file is working fine, as it connects to the database with no issues.
gurutech
Re: Database issue
Postby XJRodzx » Sat Jan 05, 2013 6:53 pm
Register.php
<?php
session_start();
include("lib/config.php");
include("lib/functions.php");
if(isset($_POST["username"])) {
$redirect = $_POST["redirect"];
$username = mysql_real_escape_string($_POST["username"]);
$email = mysql_real_escape_string($_POST["email"]);
$password = mysql_real_escape_string(md5($_POST["password"]));
$cpassword = mysql_real_escape_string(md5($_POST["cpassword"]));
$spassword = mysql_real_escape_string($_POST['password']);
$captcha = md5($_POST['captcha']);
if($username==NULL|$email==NULL|$password==NULL|$cpassword==NULL|$captcha==NULL) {
$error = "All fields are required!";
}else{
if($password!=$cpassword) {
$error = "Both passwords must be the same.";
}else{
if(preg_match("/\\s/", $username)) {
$error = "You can't use a space in your username!";
}else{
$checkuser = mysql_query("SELECT username FROM $usertable WHERE username='$username' OR email='$email'");
$username_exist = mysql_num_rows($checkuser);
if($username_exist>0) {
$error = "This user or e-mail address already exists.";
}else{
include("lib/vmail.php");
$check = vMail($email);
if($check==FALSE) {
$error = "The field \"E-mail\" doesn't contain a valid e-mail address.";
}else{
if($captcha!=$_SESSION['captcha']) {
$error = "Veryfication code is incorrect.";
}else{
if($woa==true) {
$query = "INSERT INTO $woausertable (username, password, spassword, email) VALUES('$username','$password','$spassword','$email')";
mysql_query($query) or die(mysql_error());
require("lib/mailconf.php");
//mail for admin
mail($adminemail, $adminsubject, $adminmessage, "From: $fromname <$sender>\r\nContent-type: text/html\r\nX-Mailer:PHP/".phpversion());
echo "<center>\n";
echo "<table width=\"400\" cellspacing=\"0\" cellpadding=\"3\" border=\"0\" bgcolor=\"#FFFFFF\" style=\"border:1px solid #535353;\">\n";
echo "<tr>\n";
echo "<td colspan=\"2\" bgcolor=\"#535353\" style=\"text-align:center;padding:4px;font-size:11px;font-family:Verdana;font-weight:normal;text-decoration:none;color:#FFFFFF\"><b>Registreren</b></td>";
echo "</tr>\n";
echo "<tr><td style=\"font-size:11px;font-family:Verdana;font-weight:normal;text-decoration:none;color:#535353\" align=\"right\" width=\"30%\">\n";
echo "$username is now waiting for approval, you will receive an e-mail if the administrator activated your account.\n";
echo "</td></tr>\n";
echo "</table>\n";
echo "</center>\n";
exit();
}else{
if($dbreg==true) {
$query = "INSERT INTO $usertable (username, password, email) VALUES('$username','$password','$email')";
if($subsonicreg==true) {
$url = $protocol."://".$subsonicdomain."/rest/createUser.view?u=".$admin."&p=".$pass."&v=1.1.0&c=remoteregister&username=".$username."&password=".$spassword."&email=".$email."&settingsRole=".$settingsRole."&streamRole=".$streamRole."&jukeboxRole=".$jukeboxRole."&downloadRole=".$downloadRole."&uploadRole=".$uploadRole."&playlistRole=".$playlistRole."&coverartRole=".$coverartRole."&commentRole=".$commentRole."&podcastRole=".$podcastRole."&shareRole=".$shareRole;
open_https_url($url,"",true,"");
if($multihostreg==true) {
$time = time();
mysql_select_db($multihosttable, $connect) or die("Cannot connect database 'multihost'.");
$query2 = mysql_query("INSERT INTO `mmh_user_info` (`username`, `password`, `email_address`, `ip_address`, `private_gallery`, `time_joined`, `user_group`, `upload_type`) VALUES('$username', '$password', '$email', '0.0.0.0', '0', '$time', 'normal_user', 'standard')")or die("Error in multihost DB: ".mysql_error());
//Mail for user
mail($email, $subject, $message, "From: $fromname <$sender>\r\nContent-type: text/html\r\nX-Mailer:PHP/".phpversion());
//mail for admin
echo "<center>\n";
echo "<tr>\n";
echo "</tr>\n";
echo "$username is successfully registered.\n";
echo "</table>\n";
echo "</center>\n";
if($redirect=="1") {
echo "<meta http-equiv=Refresh content=3;url=".$protocol."://".$subsonicdomain.">";
}else{
echo "<meta http-equiv=Refresh content=3;url=http://MyIP:Port>";
exit();
<html>
<head>
<title>Register on XJRodzx Music</title>
</head>
<body>
<center>
<span style="font-size:11px;font-family:Verdana;font-weight:bold;text-decoration:none;color:#535353">Register for services on XJRodzx Music!<br><br><br></span>
<form action="<?php echo $_SERVER['PHP_SELF']; ?>" method="POST">
<table width="400" cellspacing="0" cellpadding="3" border="0" bgcolor="#FFFFFF" style="border:1px solid #535353;">
<tr>
<td colspan="2" bgcolor="#535353" style="text-align:center;padding:4px;font-size:11px;font-family:Verdana;font-weight:normal;text-decoration:none;color:#FFFFFF"><b>Registrer</b></td>
</tr>
<tr><td colspan="2" align="center" style="font-size:11px;font-family:Verdana;font-weight:normal;text-decoration:none;color:#535353">
<?php echo $error; ?>
</td></tr>
<tr><td style="font-size:11px;font-family:Verdana;font-weight:normal;text-decoration:none;color:#535353" align="right" width="30%">
Username:
</td>
<td>
<input type="hidden" name="redirect" value="0">
<input type="text" size="15" maxlength="25" name="username" style="border:1px solid #535353;width:250px;">
</td>
E-mail:
</td>
<td>
<input type="text" size="15" maxlength="25" name="email" style="border:1px solid #535353;width:250px;">
</td>
</tr>
Password:
<td>
<input type="password" size="15" maxlength="25" name="password" style="border:1px solid #535353;width:250px;">
</td>
</td></tr>
Confirm password:
<td>
<input type="password" size="15" maxlength="25" name="cpassword" style="border:1px solid #535353;width:250px;">
</td>
</td></tr>
<tr><td>
Veryfication code:
</td>
<td>
<img src="lib/captcha.php" border="0"><br>
<input type="text" name="captcha" size="15" maxlength="25" style="border:1px solid #535353;width:250px;">
</td></tr>
<tr><td colspan="2" align="center">
<input type="submit" value="Register">
</td></tr>
</table>
</form>
</center>
</body>
</html>
Where is the signature.php located? I dont see that in the SubRegEngine folder?
XJRodzx
Re: Database issue
Postby gurutech » Sat Jan 05, 2013 7:44 pm
Sorry, the "signature.php" file is part of a different mod that I have (displays what music I am listening to as my signature file on this site). Others have done this mod also.
Check your register.php file for the following line:
And add:
$curl = curl_init();
curl_setopt($curl, CURLOPT_URL, $url);
curl_exec($curl);
curl_close($curl);
before the } just before the "if multihostreg=true" line.
gurutech
Re: Database issue
Postby XJRodzx » Sun Jan 06, 2013 1:10 am
You sir, are the man. That did the trick. After I added that line as you instructed, users are now being registered on both mysql and being created on subsonic as well.
Thanks so much for your help :)
XJRodzx
Re: [SOLVED] Database issue
Postby dsync89 » Sat Mar 02, 2013 7:38 am
For somewhat reason the user created does not have the Share role ($shareRole) even though it is set to 'true' in the config file. Anyone having the same problem as I did?
Besides, even after using the curl the user still only registered in the db but not subsonic itself. Sometimes it did though, but very rare.
EDIT: Well I managed to solve it. It turned out that it was the redirection fault by NO-IP.
musicScrape @ Music Cabinet Mod
http://musicscrape.zapto.org:8080
dsync89
Postby gurutech » Sun Mar 24, 2013 1:56 am
How did you resolve the redirect issue with No-IP? I think I may be having a similar issue.
gurutech
Postby suprexus » Wed Apr 17, 2013 8:40 pm
I'm having this same issue. I added the lines mentioned above but i'm still having the same problem where users are added to mysql but not to subsonic. Any other Ideas?
Thanks in advanced!!
suprexus
Postby gurutech » Wed Apr 17, 2013 9:16 pm
Wish I could help... Mine isn't working at all any more. Not adding users to MySQL or the Subsonic database... :(
gurutech
Postby suprexus » Wed Apr 17, 2013 10:30 pm
Sucksss...I'm trying it again from scratch see if I can get anywhere. Thanks though.
suprexus
Postby Excessive » Wed Nov 27, 2013 3:51 am
When I've been doin it, it did seem that if I copied the gbuser folder and the login.jsp over to some place else while formatting the machine/reinstalling from fresh, etc .......... and then trying to reinstall I worked out that for me it was the login.jsp file that played up! The gbuser folder with all ur edited files is fine! Do not touch anything in there. What I had to do is that every time I do this I have to start with a freshly unzipped subreg folder and get the fresh login.jsp and edit that from the beginning and then everything works.
In relation to ur no-ip issue it's easy to work out if it is ur no-ip service or not. Just go to whatismyipaddress.com and use ur ip assigned to u at that instance and work out if it is the no-ip service or not.
Excessive
Return to Subsonic Registration Engine
