[Solved] Registration fields not showing up
A little external engine to register users in Subsonic
Postby dr3van » Mon Jan 14, 2013 5:41 pm
My server died recently and I have put a new server back together and now am woking on getting subsonic w/ the registration engine back up and running as it was. I am facing a problem trying to get it back set up. When I changed the login.jsp file in /subsonic/jetty/3105/webapp/WEB-INF/jsp/login.jsp it is not changing anything.... I have rebooted and restarted subsonic.
Did the location of this change or am I doing something wrong?
I am running Ubuntu Server 12.10 headless with subsonic 4.7
Subsonic Server: https://dr3van.com
build
Ubuntu Server 12.10 64 bit LAMP
Subsonic 4.7 custom
dr3van
Re: Registration fields not showing up
Postby gurutech » Mon Jan 14, 2013 11:00 pm
You need to clear the cache. Should be under /subsonic/jetty/XXXX/jsp/org/apache/jsp/WEB_002dINF/ (where XXXX is your build number.)
Just stop the Subsonic service, then delete everything in that folder and restart Subsonic.
gurutech
Postby dr3van » Tue Jan 15, 2013 4:40 am
sweet deal! Worked!! Thanks!
build
Subsonic 4.7 custom
dr3van
Return to Subsonic Registration Engine
