I had successfully completed all the steps mentioned in http://download.schattorie.nl/subreg/ReadMe.txt to install the "Subsonic Registration Engine". However could not complete the step 7 from installation part as i could not find the query folder on the server as mentioned on link "7. Now run the queries which are located inside the query folder, this will create tables called users and woausers."
Also, the index page came up well as seen from URL : http://198.154.98.34:4040/login.view?#
However, when i click on register link on above page, it doesn't shows the captcha picture for the verification code and then when i fill up the values and click on register it redirects me to a 404 not found page having URL : http://198.154.98.34/register.php
Also, i have extracted the SRE V2.11 under root "/root/SubRegEngine" in my server where the "register.php" file resides and subsonic is installed inside /var. Can you please suggest the resolution for this and also provide us proper steps so that i can configure the server properly to use it.
Thank You!
Chinmaya
