Subsonic registration engine
A little external engine to register users in Subsonic
Re: Subsonic registration engine
Postby Excessive » Wed May 16, 2012 2:00 pm
OK, I've changed the redirect after change password ........... so that is fixed now ........... last thing to fix will be the users registration in subsonic ........ mabbe I'll wait for gurutech to give me the right info. BTW wamp is running on port 80 and subsonic is running on port 100.
Excessive
Postby SparkyRih » Wed May 16, 2012 2:22 pm
Excessive wrote:OK, I've changed the redirect after change password ........... so that is fixed now ........... last thing to fix will be the users registration in subsonic ........ mabbe I'll wait for gurutech to give me the right info. BTW wamp is running on port 80 and subsonic is running on port 100.
Just remove the /gbuser in the config file... that should work...
VMWare ESXi 5.5 > Ubuntu 16.04 > Subsonic 6.0 (Modded with PHP based registration feature)
SparkyRih
Postby Excessive » Wed May 16, 2012 2:39 pm
I have removed the /gbuser extension in the lib/config when you told me before. 8)
Excessive
Postby SparkyRih » Wed May 16, 2012 2:44 pm
Excessive wrote:I have removed the /gbuser extension in the lib/config when you told me before. 8)
So does it work now?
SparkyRih
Postby Excessive » Wed May 16, 2012 3:02 pm
No, still won't register users in subsonic.
It's late, 1 am and I'm going to bed, thanks for all your help today.
Last thing that needs fixing is the users registration is subsonic, might try and put my ip address in there temporarely and see how that works.
K, talk tomorrow.
:D
Excessive
Postby SparkyRih » Wed May 16, 2012 3:23 pm
Excessive wrote:No, still won't register users in subsonic.
K, talk tomorrow.
:D
Ok, let me know...
SparkyRih
Postby bushman4 » Wed May 16, 2012 4:01 pm
I editted one of your earlier posts to remove the password from the REST URL that you posted.
I would definitely change your admin password, since you just posted it here for all to see (and I checked... it does work, so if you see a connection from a weird IP, that is me...)
Glenn
Glenn Sullivan
Subsonic 5.2.1 (Standalone on Apache/Tomcat 6)
WHS 2003, Dual Core Athlon, 4 Gb RAM, 12 TB
50 regular Subsonic Users
Library as of 2016-03-21:
4,034 artists
16,595 albums
182,904 songs
4582.16 GB
21,558 hours
Postby Excessive » Thu May 17, 2012 4:17 am
Admin password changed.
YESSSSSSSSSSSSSS ............... I got it working, though I don't really know what I did to get it to work ......... I think I ran the queries wrong in the phpmyadmin in wamp. I didn't have to muck around with no-ip.com either. Just the one redirect is ok. I first coded my ip address in the domain fields in the login.jsp and in lib/config and got it to work after playing around with the queries and then put in the no-ip redirect into the domain fields and it works now. Also I'm not giving out the no-ip domain but rather the subsonic domain cause I don't want people to get to the wamp homepage by removing the port number, not that they could do anything, but ........ just no. So here's the url .... http://cooltunes.subsonic.org please feel free to sign up and play around.
One thing that I would ask Sparky is that is it possible to add a "limit quality" in the lib/config.php "set subsonic permisions" so that I won't have to manually limit users in subsonic. At the moment I'm limiting to 160kbps.
Thanks again for all you guy's help, this is great.
Excessive
Postby SparkyRih » Thu May 17, 2012 11:17 am
Nice, I've registered an acocunt and I see that everything works fine...
Setting max bitrate is not possible because this feature is not added to the API... I hope it will appear in a future update of Subsonic?
SparkyRih
Postby Excessive » Thu May 17, 2012 11:23 am
Ok, thnx :)
Excessive
Postby ddweb » Tue May 22, 2012 5:27 pm
Is it possible to make the registration connect with Facebook Login?
https://developers.facebook.com/docs/guides/web/#login
ddweb
Postby SparkyRih » Wed May 23, 2012 4:19 pm
ddweb wrote:Is it possible to make the registration connect with Facebook Login?
That's not really a bad idea to add as an optional feature... I will look into it some time...
Edit: Or even as standalone mod...
SparkyRih
Postby Excessive » Thu May 24, 2012 5:39 am
Something has happened about 2 days ago and it stuffed up my registration page and I have this as a php error
[24-May-2012 15:33:44] PHP Warning: PHP Startup: Unable to load dynamic library 'c:/wamp/bin/php/php5.2.6/ext/php_exif.dll' - The specified module could not be found.
in Unknown on line 0
I tried reinstalling wamp and windows but I still have the above error.
Excessive
Postby SparkyRih » Thu May 24, 2012 12:17 pm
Excessive wrote:Something has happened about 2 days ago and it stuffed up my registration page and I have this as a php error
When does this error accur? And have you checked if that *.dll file exists? Which version of PHP and Apache are you running?
SparkyRih
Postby Excessive » Thu May 24, 2012 2:49 pm
The error is there after I install everything and run wamp. The .dll file is there. Using wamp 2.0c now on windows Vista ultimate, but had the same error in both win7 home premium and win7 ultimate. I had it running on win7 home premium and 2 days ago it stopped working and I just realized the error today and tried different versions of windows, but all have the same error.
Excessive
Return to Subsonic Registration Engine
