BKKKPewsey wrote:My first impressions are very nice![]()
BKKKPewsey wrote:However the simple click to install wasn't quite so simple in my case because I was not using IE as a browser.
Sorry that is a side effect of using .net click once, nothing I can do to change that, I could have made it clear to install using ie in the first instance, sorry.
BKKKPewsey wrote:So to test I selected a small (test) playlist and it came up with a message box
- Code: Select all
Shortcut in use
Hi this isn't related to your playlist it's actually to do with SubWiji allocating it's keyboard shortcuts (see top forum post for a list) when one is already in use (by another program or sometimes multiple instances of SubWiji) it shows that error, I will change that so its clearer.
BKKKPewsey wrote:Ok try again and this time it found an update automatically (only been installed 30 mins that was quick work)
Yes I tend to do many updates each day and the link I have provided is directly linked to the Development builds at the moment
BKKKPewsey wrote:Tried another track - still no sound but a brief pop up box came up saying something about no wave output device found
If you could send me a copy of your subsonic log I can have a look see if there is a problem transcoding to mp3, is your server on windows? My server is on OSX so it may be differences in the transcoding setup, if you could screenshot your transcoders setup screen and email me that i would be grateful.
BKKKPewsey wrote:Note there are no errors being shown in the SS log and everything seems to be working fine but quietly![]()
Sorry your having trouble I hope you can stay involved and if I can get your issues sorted then you may be able to enjoy the app!
BKKKPewsey wrote:Some other observations - I was a bit confused by the music mixer icon
I was expecting to see some form of equaliser there but instead I get a copy of my default home page - is that correct?
Yes this is there so you can find and build your playlist from within SubWiji, I made the program so I don't have to use the website at all. I am planning on changing that icon to a better one, you can also use the search to find albums and tracks.
BKKKPewsey wrote:Also it would be nice if there were shortcuts to the artist 1st letters aka SS in the artist "cloud"
The artist cloud is still in development and will be far easier to navigate, it's in the works :p
BKKKPewsey wrote:Yep for a beta a job very well done - just need it to make some noise
I will be coding tomorrow so hopefully your issues can get ironed out
Cheers
Paul
