SubWiji - Windows Subsonic Client (WPF)
Re: Windows Subsonic Client (WPF)
Postby paulodell » Mon Mar 12, 2012 7:31 pm
DGMayor wrote:WIndows 7 64 bit - Subsonic 4.6, Java 1.6rev31 or whatever the latest is.
Not seeing a buffer signal (?).
You've got a PM from me - If I pause for a short period of time, it's fine. If it's over a minute, it resumes but then goes quiet until the song ends.
I
I have had a look linked up to your server (thanks for that).
I can replicate the issue (the same one I get after a looooong pause) but my debug code also picks this up and re-buffers and plays the rest of the song.
Can you check that you are running build 0.1.0.142 of SubWiji.
The buffering is shown in the screenshot below...
In my tests the song will stop, buffer and then resume...instead of going on silent...
Now I am also having trouble even replicating this (by leaving it paused for 5 minutes), its not bombing out as before...you did say that you had increased the memory limit that Subsonic server can use. Maybe this was part of the issue? (viewtopic.php?t=3939)
Let me know how you get on when you can look at the version you have of SubWiji tomorrow.
Cheers
Paul
SubWiji http://tinyurl.com/7sxwbfv Install http://subwiji.paulodell.co.uk
Transcode Step1 "ffmpeg -f mp3 -i %s -ab %bk -v 0 -f mp3 -"
Tremor Games http://www.tremorgames.com/?ref=59174
paulodell
Postby DGMayor » Tue Mar 13, 2012 2:15 pm
Hey just wanted to say thanks to Paul for working with me yesterday and this morning to get this bug worked out. You don't realize how important a simple feature like pausing and resuming is until you're using it at work and have to pause to answer the phone/talk to co-workers off and on through the day. As of this morning, everything is working great!
Thanks again!
DGMayor
Postby paulodell » Tue Mar 13, 2012 3:09 pm
DGMayor wrote:Hey just wanted to say thanks to Paul for working with me yesterday and this morning to get this bug worked out. You don't realize how important a simple feature like pausing and resuming is until you're using it at work and have to pause to answer the phone/talk to co-workers off and on through the day. As of this morning, everything is working great!
Thanks again!
Cheers DGMayor,
Im glad we managed to get it fixed in the end :)
Paul
paulodell
Postby Wez1981 » Tue Mar 13, 2012 10:28 pm
paulodell wrote:Cheers DGMayor,
Paul
Like a boss!
Wez1981
Postby BKKKPewsey » Tue Mar 27, 2012 2:47 am
Latest version seems to have a few problems (Just auto-updated) :(
eg: Will not connect to server - using both my subsonic.org address or using IP:port address - reports 404 error
Also if I try to clear the cache it generates a auto crash dump so you should be getting a report.
I do like the crash report feature - nice touch!
Re: Re: Windows Subsonic Client (WPF)
Postby paulodell » Tue Mar 27, 2012 6:05 am
BKKKPewsey wrote:Latest version seems to have a few problems (Just auto-updated) :(
Are you setup as https?
If you are make sure you have it in the url somewhere, if not can you get me a temp login to test?
Cheers
Paul
paulodell
Postby paulodell » Tue Mar 27, 2012 6:09 pm
I found the issue, it doesn't resolve if you use this URL: server.subsonic.org/subsonic
BUT does if you use this URL: server.subsonic.org/subsonic/
The problem is the last / when using a sub directory to connect to Subsonic and SubWiji :oops:
Sorry about that its a bit annoying but I have added code to allow for this and if the backslash is not present then it will add it to the connection code.
I have just released the update but its unto you either you can accept the new version OR you can add the /
Cheers
Paul
paulodell
Postby paulodell » Tue Mar 27, 2012 6:11 pm
BKKKPewsey wrote:Also if I try to clear the cache it generates a auto crash dump so you should be getting a report.
As for the Clear Cache option this will only work if you have a My Music folder in Windows and permissions to edit that folder.
If you can tell me your version of Windows and if you have a Username/Libraries/Music folder setup that will help me handle the error.
Cheers
Paul
paulodell
Postby BKKKPewsey » Tue Mar 27, 2012 8:46 pm
That would explain the problem as I do not have any music on my pc - its all on my server :)
I was only trying to clear cache to try to get subwiji to connect (Monkeys hitting keys - sometimes works :D )
Postby paulodell » Tue Mar 27, 2012 9:24 pm
BKKKPewsey wrote:That would explain the problem as I do not have any music on my pc - its all on my server :)
Yes I don't mean have you got Music on your computer, I mean the default windows My Music folder (can be blank), is where SubWiji stores the Cover Art.
Cheers
Paul
paulodell
Postby dazbobaby » Thu Apr 12, 2012 10:10 pm
A big ask I know, but would it be possible to move the bar to the side of the screen?
At the top it gets in the way of my browser tabs, at the bottom it's in the way of my object dock
dazbobaby
Postby dazbobaby » Thu Apr 12, 2012 10:18 pm
and just out of sheer stupid annoyance, anychance you could post the blank cd case please, the one that displays coverart?
Thanks in advance.
dazbobaby
dazbobaby
Postby paulodell » Thu Apr 12, 2012 11:24 pm
dazbobaby wrote:A big ask I know, but would it be possible to move the bar to the side of the screen?
That has been requested before and is in the list but isn't easy to do quickly so it looks good.
I will add your "vote" to my Toro list, also you can auto hide when on the top of the screen if that helps?
Cheers
Paul
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk 2
paulodell
Postby paulodell » Thu Apr 12, 2012 11:26 pm
dazbobaby wrote:and just out of sheer stupid annoyance, anychance you could post the blank cd case please, the one that displays coverart?
Thanks in advance.
dazbobaby
Do you mean the cd case image that surrounds all the cd covers in SubWiji?
Here it is.....
Paul
paulodell
Postby dazbobaby » Thu Apr 12, 2012 11:59 pm
Thats the one, thanks a lot.
BTW, where are the files located? I looked for it but couldn't find it, and well... my current C: has about 2000 .png's to search through :)
no problem with the subwiji lock to the side, I can always work around it, but it'd help is all.
dazbobaby
Return to SubWiji
