SubWiji - Windows Subsonic Client (WPF)
Re: Re: Windows Subsonic Client (WPF)
Postby paulodell » Thu Mar 28, 2013 4:37 pm
ggibby wrote:Ah, no, I am using the term 'buffer' and thinking 'cache,' as some other clients I've tried take that approach, which makes backing up in a song pretty easy. Different methods, different results.
Hi Gibby,
I just wanted to let people using SubWiji know that I have finally been able to make Caching of songs work.
SubWiji will auto-cache (if you set it) into the Cache folder (you can also set this up - by default its the My Music folder).
The cached copies will be of the same quality and should play back (instead of hitting the web server).
Im also adding an option for User Management, viewing you own user permissions along with Full File Downloads, so if your user has the Download permission you will be able to download a Song, Album, Artist or Playlist all from SubWiji.
All these changes are still underway so I wont be releasing them yet but I wanted to let people know for suggestions or questions whilst im making changes.
Paul
SubWiji http://tinyurl.com/7sxwbfv Install http://subwiji.paulodell.co.uk
Transcode Step1 "ffmpeg -f mp3 -i %s -ab %bk -v 0 -f mp3 -"
Tremor Games http://www.tremorgames.com/?ref=59174
paulodell
Download Link
Postby mrburitto » Thu Jun 20, 2013 3:21 pm
Is this project still active? All of the download links (including the latest one on the previous page) are not working... I would really like to try out your app. I would be willing to host it for you on one of my servers if thats the problem... Granted that it works and if I like it of course :)
Let me know if you need a place to host it, or can provide a working download link. Thanks!
mrburitto
Re: Download Link
Postby paulodell » Thu Jun 20, 2013 3:25 pm
mrburitto wrote:Hello,
Hi yes it is still alive
As in my other thread the update and installation server method went a bit awry...
Please use link here - http://www.paulodell.co.uk/subwiji/SubWiji.htm
ALWAYS please use Internet Explorer (I hate it also).
I use Chrome usually but SubWiji uses Microsoft ClickOnce to deploy and this works best in Internet Explorer, you only need it for the initial install.
paulodell
Re: SubWiji - Windows Subsonic Client (WPF)
Postby khumbert45 » Wed Jun 26, 2013 11:41 am
I just installed the program and connected to my server. When I click the Music Library, the window pops up but nothing is shown in the window. It says "Page 1 of 100" but that's it. If I go to the Artist Cloud tab I can see all the artists, but when I click on any of them, there are no songs, albums, etc. showing up. Any help you can provide me would be great.
khumbert45
Postby paulodell » Wed Jun 26, 2013 11:45 am
khumbert45 wrote:I just installed the program and connected to my server. When I click the Music Library, the window pops up but nothing is shown in the window. It says "Page 1 of 100" but that's it. If I go to the Artist Cloud tab I can see all the artists, but when I click on any of them, there are no songs, albums, etc. showing up. Any help you can provide me would be great.
What version of subsonic do you have installed?
Also what is your music folder structure like?
Subsonic 4.8 uses id3 tags so if your music does not have this setup it won't work well.
Another note is, is your server registered (donated)?
Paul
paulodell
Postby khumbert45 » Wed Jun 26, 2013 12:03 pm
I just re-installed Subsonic v4.8 the other day. I then installed the Madsonic mod (v4.8.3360).
My folder structure is setup from my itunes, which organizes it automatically.
My server is registered (just did that this past weekend).
Thanks for the quick response.
khumbert45
Postby paulodell » Wed Jun 26, 2013 2:17 pm
khumbert45 wrote:I just re-installed Subsonic v4.8 the other day. I then installed the Madsonic mod (v4.8.3360).
Ok so your setup with the best options, can you give me a temporary login (PM it to me) or email me @ subwiji@icloud.com and I can debug your server and find out the problem :)
Paul
paulodell
Postby khumbert45 » Wed Jun 26, 2013 2:26 pm
I sent you a PM. Thanks!
khumbert45
Postby paulodell » Wed Jun 26, 2013 2:55 pm
khumbert45 wrote:I sent you a PM. Thanks!
I have found that using the API (which is what SubWiji uses to get data) from Madsonic doesn't work for getAlbumList2.view which is a new routine from subsonic 4.7 onwards, if i force getAlbumList.view (the old routine) the albums come back.
I do not want to use this old routine as its not right, I would suggest asking the Madsonic developers about this issue, also I did notice that there is a new version of Madsonic that you could install....
In the changelog of Madsonic 5 it does say
*) Update REST API
*) Update id3 REST API Calls
paulodell
Postby khumbert45 » Wed Jun 26, 2013 2:59 pm
Sounds good. I will try and update madsonic to see if that works. If not, I will post the feedback for them and go back to subsonic until they get it updated.
Thanks for taking the time to check into this.
khumbert45
Postby paulodell » Wed Jun 26, 2013 3:02 pm
khumbert45 wrote:Sounds good. I will try and update madsonic to see if that works. If not, I will post the feedback for them and go back to subsonic until they get it updated.
No problem, if you get any more problems or if Madsonic state that the API's are updated now then please come back to me and I can have another look
Paul
paulodell
Postby rvonder » Sat Aug 24, 2013 8:03 pm
Hi Paul,
I installed SubWiji and it was working fine with the default settings. I then changed a couple of the options (set the theme to Aero and the position to Bottom). When I applied the changes, SubWiji completely disappeared from the screen! I tried hiding the Windows 7 taskbar, and also moving the taskbar to the top of the screen hoping I'd be able to see SubWiji again. But neither of these helped. I even tried completely uninstalling SubWiji and then reinstalling, but it's still invisible (I'm assuming that uninstalling doesn't remove configuration info somewhere?)
Do you have any idea what's happening? Since SubWiji doesn't appear in the Program Files folder, I don't even know where to look for configuration info so I could try to manually change location back to 'top' again. Help!
Thanks...
rvonder
Postby paulodell » Sat Aug 24, 2013 8:39 pm
rvonder wrote:Hi Paul,
Thanks...
Hi
Try removing the SubWiji folder in the location below
C:\Documents and Settings\userprofile\Local Settings\Apps
That should clear the settings out
Paul
paulodell
Postby paulodell » Sun Aug 25, 2013 9:10 am
Thanks...
I have actually sent a new version of SubWiji out (1.5.5.52 -> http://www.paulodell.co.uk/subwiji/SubWiji.htm) which if the Black skin is NOT selected and Bottom Docking IS selected (your situation) it will automatically turn off Bottom Docking, hopefully this will allow you to revert the skin back.
Unfortunately Bottom Docking is a bit hit and miss as are the other skins.
Please give that a go and let me know how you get on
Paul
paulodell
Postby alinus » Thu Nov 19, 2020 4:03 pm
Hello !
How can I download this software ?
The URL put me on a Wordpress login ?
alinus
Return to SubWiji
