SubWiji Installation Fix
Windows Subsonic Client (WPF)
Postby paulodell » Tue Jan 29, 2013 2:52 pm
Hi all,
Just a post to let you know to install SubWiji please use the following link http://subwiji.paulodell.co.uk
It seems that the changes to Dropbox broke the ClickOnce setup
Thanks for using SubWiji!
Paul
SubWiji http://tinyurl.com/7sxwbfv Install http://subwiji.paulodell.co.uk
Transcode Step1 "ffmpeg -f mp3 -i %s -ab %bk -v 0 -f mp3 -"
Tremor Games http://www.tremorgames.com/?ref=59174
paulodell
Re: SubWiji Installation Fix
Postby archevision » Wed May 08, 2013 10:37 pm
Hi!
icon.ico seems to have invalid hash so installation is impossible.
Running on windows 7 pro x64
PLATFORM VERSION INFO
   Windows          : 6.1.7601.65536 (Win32NT)
   Common Language Runtime    : 4.0.30319.18034
   System.Deployment.dll       : 4.0.30319.17929 built by: FX45RTMREL
   clr.dll          : 4.0.30319.18034 built by: FX45RTMGDR
   dfdll.dll          : 4.0.30319.17929 built by: FX45RTMREL
   dfshim.dll          : 4.0.41209.0 (Main.041209-0000)
SOURCES
   Deployment url         : http://www.paulodell.co.uk/subwiji/SubWiji.application
                  Server      : Apache
   Deployment Provider url      : http://www.paulodell.co.uk/subwiji/SubWiji.application
   Application url         : http://www.paulodell.co.uk/subwiji/Application%20Files/SubWiji_1_5_5_38/SubWiji.exe.manifest
                  Server      : Apache
IDENTITIES
   Deployment Identity      : SubWiji.application, Version=1.5.5.38, Culture=neutral, PublicKeyToken=0000000000000000, processorArchitecture=x86
   Application Identity      : SubWiji.exe, Version=1.5.5.38, Culture=neutral, PublicKeyToken=0000000000000000, processorArchitecture=x86, type=win32
APPLICATION SUMMARY
   * Installable application.
ERROR SUMMARY
   Below is a summary of the errors, details of these errors are listed later in the log.
   * Activation of http://www.paulodell.co.uk/subwiji/SubWiji.application resulted in exception. Following failure messages were detected:
      + File, icon.ico, has a different computed hash than specified in manifest.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
   No transaction error was detected.
WARNINGS
   * The manifest for this application does not have a signature. Signature validation will be ignored.
OPERATION PROGRESS STATUS
   * [9.05.2013 1:25:20] : Activation of http://www.paulodell.co.uk/subwiji/SubWiji.application has started.
   * [9.05.2013 1:25:21] : Processing of deployment manifest has successfully completed.
   * [9.05.2013 1:25:21] : Installation of the application has started.
   * [9.05.2013 1:25:21] : Processing of application manifest has successfully completed.
   * [9.05.2013 1:25:27] : Found compatible runtime version 4.0.30319.
   * [9.05.2013 1:25:27] : Request of trust and detection of platform is complete.
ERROR DETAILS
   Following errors were detected during this operation.
   * [9.05.2013 1:25:40] System.Deployment.Application.InvalidDeploymentException (HashValidation)
      - File, icon.ico, has a different computed hash than specified in manifest.
      - Source: System.Deployment
      - Stack trace:
         at System.Deployment.Application.ComponentVerifier.VerifyFileHash(String filePath, Hash hash)
         at System.Deployment.Application.ComponentVerifier.VerifyFileHash(String filePath, HashCollection hashCollection)
         at System.Deployment.Application.ComponentVerifier.VerifyComponents()
         at System.Deployment.Application.DownloadManager.DownloadDependencies(SubscriptionState subState, AssemblyManifest deployManifest, AssemblyManifest appManifest, Uri sourceUriBase, String targetDirectory, String group, IDownloadNotification notification, DownloadOptions options)
         at System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
         at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
         at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
         at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
COMPONENT STORE TRANSACTION DETAILS
   No transaction information is available.
That's kindof bugger.. 'cause suwiji is so much better than periscope or webapp. And I had to do a system reinstall.. Darn.
archevision
Postby paulodell » Thu May 09, 2013 5:20 am
Hi
Sorry to hear you have issues...
Can you please confirm that you are running the installer from http:/subwiji.paulodell.co.uk and NOT the link above?
Also can you try the installation straight from IE?
Paul
paulodell
Postby Gotanius » Fri Jul 11, 2014 8:03 am
Sorry to bump this, but I'm trying to install subwiji.
I am running windows 8.1 update 1 (x64). .net framework 4 is installed (by default in OS).
When I open the site in IE and click the 'install' link, a setup.exe file is downloaded and executed, however nothing happens and windows start asking me whether the application was executed correctly.
Gotanius
Return to SubWiji
