SubWiji - Update FIX
Windows Subsonic Client (WPF)
Postby paulodell » Tue Apr 02, 2013 3:23 pm
Hi Everyone,
If your using SubWiji and you get some update errors please navigate to http://www.paulodell.co.uk/subwiji/SubWiji.htm.
Please click "Launch" inside "If these components are already installed, you can launch the application now. Otherwise, click the button below to install the prerequisites and run the application."
If you have any issues please email me @ subwiji@icloud.com
Paul
SubWiji http://tinyurl.com/7sxwbfv Install http://subwiji.paulodell.co.uk
Transcode Step1 "ffmpeg -f mp3 -i %s -ab %bk -v 0 -f mp3 -"
Tremor Games http://www.tremorgames.com/?ref=59174
paulodell
Re: SubWiji - Update FIX
Postby meld0 » Thu Apr 04, 2013 8:55 am
i still have a Problem using subwiji. My Connection runs with https
and even copying the Connection string from the browser to the app
gives me 'Subsonic connection failes, please chech you Settings and retry' - 404 Error.
It works just fine in the browser.
With Regards,
meld0
meld0
Postby paulodell » Thu Apr 04, 2013 10:09 am
meld0 wrote:Hi,
With Regards,
meld0
When using https you MUST include HTTPS preceding the URL in SubWiji as this is how SubWiji sets the httpS settings.
Can you email me @ subwiji@icloud.com with a temporary login? Also the URL your using?
I will try it and then get back to you
Paul
paulodell
Postby 14all41 » Fri Apr 05, 2013 9:58 pm
Hi Paul,
I have same problems with the installation of Subwiji, your dropbox folder is empty. If you have troubles with space on web for Subwiji, you can put and share your source into our owncloud on :
http://cloud.14all-all41.net (subsonic/musiclover = user/pwd).
Cheers Tom
14all41
Postby paulodell » Sat Apr 06, 2013 12:21 pm
14all41 wrote:Hi Paul,
Cheers Tom
Yes dropbox is empty now as its no longer used, instead I'm hosting it on my own web space.
Please follow the link in my first post to get it updating again.
Let me know if you don't have it working?
Paul
paulodell
Postby Megamorf » Sat Apr 06, 2013 2:22 pm
Hey, I wanted to try SubWiji today for the first time, but I can't get it to run. I'm fairly skilled on the Microsoft side so I tried to do a bit of troubleshooting:
Powershell: Detect which .NET FW Versions are installed
function Test-Key([string]$path, [string]$key)
    if(!(Test-Path $path)) { return $false }
    if ((Get-ItemProperty $path).$key -eq $null) { return $false }
    return $true
function Get-FrameworkVersions()
    $installedFrameworks = @()
    if(Test-Key "HKLM:\Software\Microsoft\.NETFramework\Policy\v1.0" "3705") { $installedFrameworks += ".NET FW 1.0" }
    if(Test-Key "HKLM:\Software\Microsoft\NET Framework Setup\NDP\v1.1.4322" "Install") { $installedFrameworks += ".NET FW 1.1" }
    if(Test-Key "HKLM:\Software\Microsoft\NET Framework Setup\NDP\v2.0.50727" "Install") { $installedFrameworks += ".NET FW 2.0" }
    if(Test-Key "HKLM:\Software\Microsoft\NET Framework Setup\NDP\v3.0\Setup" "InstallSuccess") { $installedFrameworks += ".NET FW 3.0" }
    if(Test-Key "HKLM:\Software\Microsoft\NET Framework Setup\NDP\v3.5" "Install") { $installedFrameworks += ".NET FW 3.5" }
    if(Test-Key "HKLM:\Software\Microsoft\NET Framework Setup\NDP\v4\Client" "Install") { $installedFrameworks += ".NET FW 4.0 Client Profile" }
    if(Test-Key "HKLM:\Software\Microsoft\NET Framework Setup\NDP\v4\Full" "Install") { $installedFrameworks += ".NET FW 4.0 Full Profile" }
    return $installedFrameworks
Output:
PS C:\> Get-FrameworkVersions
.NET FW 2.0
.NET FW 3.0
.NET FW 3.5
Powershell: Operating system information
Get-WmiObject win32_operatingsystem | select Caption, CSDVersion, OSArchitecture, Version, MUILanguages
Output:
Caption : Microsoft Windows 7 Professional
CSDVersion : Service Pack 1
OSArchitecture : 64-Bit
Version : 6.1.7601
MUILanguages : {de-DE}
The error I run into is the following:
ERROR SUMMARY
   Below is a summary of the errors, details of these errors are listed later in the log.
   * Activation of C:\Users\User\Downloads\SubWiji.application resulted in exception. Following failure messages were detected:
      + File, NAudio.dll, has a different computed hash than specified in manifest.
ERROR DETAILS
   Following errors were detected during this operation.
   * [06.04.2013 15:35:04] System.Deployment.Application.InvalidDeploymentException (HashValidation)
      - File, NAudio.dll, has a different computed hash than specified in manifest.
      - Source: System.Deployment
      - Stack trace:
         at System.Deployment.Application.ComponentVerifier.VerifyFileHash(String filePath, Hash hash)
         at System.Deployment.Application.ComponentVerifier.VerifyFileHash(String filePath, HashCollection hashCollection)
         at System.Deployment.Application.ComponentVerifier.VerifyComponents()
         at System.Deployment.Application.DownloadManager.DownloadDependencies(SubscriptionState subState, AssemblyManifest deployManifest, AssemblyManifest appManifest, Uri sourceUriBase, String targetDirectory, String group, IDownloadNotification notification, DownloadOptions options)
         at System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
         at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
         at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
         at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
The program itself lands in C:\Users\%Username%\AppData\Local\Temp\Deployment as expected from these ClickOnce setups. But in my case deletes itself when it runs into the error above.
Megamorf
Postby paulodell » Sat Apr 06, 2013 3:14 pm
Hi are you using the installer from the link in my first post here?
Please go to http://www.paulodell.co.uk/subwiji once there I am presuming your using the setup.exe install option?
Please use Internet explorer also see if that helps.
If that doesn't work can you try to uninstall it and then reinstall using that link?
Paul
paulodell
Postby Megamorf » Sat Apr 06, 2013 3:23 pm
paulodell wrote:Hi are you using the installer from the link in my first post here?
Paul
Hello Paul,
yes, I used the install option from your website. After the download has finished it gives me the error above. As you suggested I tried it again with the Internet Explorer but the result was the same - it aborted once the download was complete. Here's the error log: http://pastebin.com/XxBV1HV3
I cannot uninstall what is not installed ;-) When your setup runs into this error it automatically removes the downloaded files.
Is there anything else I can do to support the troubleshooting process?
Megamorf
Postby paulodell » Sat Apr 06, 2013 3:43 pm
Paul
Hello Paul,
Ah thanks for checking, so in add and remove SubWiji is not there at all?
That is strange give me 5 minutes and ill try build a new version which is hopefully fixed.
Paul
paulodell
Postby Megamorf » Sat Apr 06, 2013 3:58 pm
Paul
Hello Paul,
Paul
No. I checked the Application wizard (appwiz.cpl) again and indeed, it is not there. I am using a standard user for this with UAC enabled.
Megamorf
Postby paulodell » Sat Apr 06, 2013 4:00 pm
Right ive made a whole new rebuild, sorry about this.
For some reason the convenience of ClickOnce is causing me a headache, sometimes I wonder wether to use it or not!
Ive checked the version on one of my other machines that didn't have SubWiji installed on and it installs from this link (from IE) - http://www.paulodell.co.uk/subwiji/SubWiji.htm
Give that a try and let me know, thanks for pointing out the issues :S
Sorry everyone
Paul
paulodell
Postby Megamorf » Sat Apr 06, 2013 4:32 pm
It works now. The client loads and add itself to the application wizard. I have a sample subsonic with 4 songs but they don't show up in SubWiji. I'll try getting it to work first before I come here asking for help :-)
Megamorf
Postby paulodell » Sat Apr 06, 2013 4:34 pm
Megamorf wrote:It works now. The client loads and add itself to the application wizard. I have a sample subsonic with 4 songs but they don't show up in SubWiji. I'll try getting it to work first before I come here asking for help :-)
Ok if it works in the web ui then it should work in SubWiji but remember that depending on the subsonic version it might be your folder structure.
Subsonic pre 4.7 needs a root then in that artists then each folder a album.
Subsonic 4.7 can read using id3 data.
Paul
paulodell
Postby Megamorf » Sat Apr 06, 2013 4:37 pm
Paul
Oh, Subsonic can play the songs. I have to see how to get them to play in SubWiji is what I meant.
Edit:
My Subsonic is running in a virtual tomcat apache appliance with the music folder at /music. The folder structure is quite simple for my sample setup:
music
  \-soundcloud
     |-song1.mp3
     |-song2.mp3
     |-song3.mp3
     \-song4.wav
I can play these songs in Subsonic but they don't show up in SubWiji. I can only find (and play) them through the searchbox but not with your music library button :/
Megamorf
Postby paulodell » Sat Apr 06, 2013 4:57 pm
Also make sure subsonic has the transcoder setup as per the main SubWiji thread (it's also in my signature below)
SubWiji is an MP3 player only so all subsonic music must be transcoded to MP3.
Paul
paulodell
Return to SubWiji
