Madsonic - Mashup Mod (old Support Thread)
Re: Technical Preview: Subsonic Mashup Mod 4.7
Postby MadEvil » Tue Jun 26, 2012 12:25 am
ananda96 wrote:I really would recommend a feature like "save config to ini file" or something different to restore all settings for clean reinstall and scan.
if you mean basic Subsonic settings, search for the subsonic.properties file in your subsonic folder. Backup and restore this file on clean install.
best regards
Madsonic Developer
MadEvil
Postby MadEvil » Tue Jun 26, 2012 12:42 am
tycoonbob wrote:So I am trying B3020 tonight, and a few things to note:
First off, my OS for my SubSonic device is Windows Server 2012 Release Candidate Datacenter x64.
So I uninstalled Java 1.6, and uninstalled B3016, and installed B3020...to let it install Java. B3020 installed Java v1.6u32. SubSonic didn't work, since it was compiled with 1.7...so I uninstalled the 1.6.
Downloaded the offline installer for the latest 1.7, both the x64 and x86...and installed both. With that being said, I can say that SubSonic still didn't work with on the 1.7 x64 install, as I got a popup saying it couldn't find the x32 install of JDK, but resolved itself after I installed it. All seemed to work after that, and working good so far.
thanks tycoonbob for the troubleshooting. In the new Build i resolved this in the windows installer package. Build 3022 is now bundled right with Java 1.7 Installer.
I test this with a fresh Windows Server 2012 Release Candidate Datacenter x64 installation and works well now. On this way i found many other bugs with Internet Explorer 10 and Adobe Flash Crashes, but with Google Chrome it works well on Server 2012.
Best regards
PS: @ tycoonbob & ananda96: yes my daughter is feeling better. Many thanks for your attention!
Madsonic Developer
MadEvil
Postby MadEvil » Tue Jun 26, 2012 12:55 am
New Build: 3022
NEW: Update Spring Framework 2.5.6.SEC03
NEW: Update acegi-security 1.0.7
NEW: Update Windows Installer package with JRE 1.7
NEW: Theme split: Madsonic (dark), Madsonic (black)
NEW: Updated Slovenian translation http://subsonic.svn.sourceforge.net/vie ... ision=3022
NEW: Autoimport Playlists http://subsonic.svn.sourceforge.net/vie ... ision=3023
NEW: Fixed problem with content removing and re-adding http://subsonic.svn.sourceforge.net/vie ... ision=3024
NEW: Clean-up database function http://subsonic.svn.sourceforge.net/vie ... ision=3027
Download look @ first Post -> viewtopic.php?f=8&t=9187
Best regards
Madsonic Developer
MadEvil
Postby Drefsab » Tue Jun 26, 2012 8:24 am
JW Player 5.10 just hit :)
Drefsab
Postby MadEvil » Wed Jun 27, 2012 6:13 am
New Build: 3024
NEW: Update to JWPlayer 5.10
NEW: Update to FFmpeg git-c17808c 32-bit Static (windows)
Best regards
Madsonic Developer
MadEvil
Postby tycoonbob » Sun Jul 01, 2012 3:25 am
Thanks for the continued updates! Glad you bundled the correct java build, and I can also say that I have had issues with ie10 beta. I don't use it though, so not a concern of mine. New version of FFMPEG might hopefully fix some of my transcoding issues, but will be a bit before I can test.
tycoonbob
Postby MadEvil » Sun Jul 01, 2012 7:31 am
tycoonbob wrote:Thanks for the continued updates! Glad you bundled the correct java build, and I can also say that I have had issues with ie10 beta. I don't use it though, so not a concern of mine. New version of FFMPEG might hopefully fix some of my transcoding issues, but will be a bit before I can test.
Hi tycoonbob,
All for one and one for all! :wink:
i hope allso the latest ffmpeg fix your issues, for some people the latest version fix some wma transcoding issues.
best regards
Madsonic Developer
MadEvil
Postby MadEvil » Sun Jul 01, 2012 7:33 am
New Build: 3026
NEW: Better Layoutsupport for Android Tablets
NEW: Fixed slow "Top rated" http://subsonic.svn.sourceforge.net/vie ... ision=3030
Best regards
Madsonic Developer
MadEvil
Postby tycoonbob » Tue Jul 03, 2012 5:01 pm
Uninstalled SubSonic, and all existing Java versions. Rebooted. Installed B3026, and now get this error when trying to load SubSonic.
HTTP ERROR: 404
NOT_FOUND
RequestURI=/index.view
Powered by Jetty://
Here is the log file from the subsonic-service.log:
Subsonic running on: http://localhost:453/
8629 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
9982 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
10292 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[172.16.1.111:9412](local),objID:[0:0:0, 0]]]]
Here is the log file from the subsonic-agent.log:
16 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@acb158: display name [org.springframework.context.support.ClassPathXmlApplicationContext@acb158]; startup date [Tue Jul 03 11:22:53 EDT 2012]; root of context hierarchy
79 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-agent.xml]
391 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@acb158]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1fd5730
407 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1fd5730: defining beans [service,agent,frame,settingsPanel,statusPanel]; root of factory hierarchy
Executing: subsonic-service.exe -stop
Executing: subsonic-service.exe -start
79115 [pool-1-thread-1] WARN org.springframework.remoting.rmi.RmiProxyFactoryBean - Could not connect to RMI service [rmi://localhost:9412/SubsonicDeployerService] - retrying
My assumption is something to do with Java? I notice two versions installed in appwiz:
-Java 7 Update 5
-JavaFX 2.1.1
I have uninstalled both, and rebooted. I reinstalled the latest JRE (1.7u5) and getting the same results ,and same logs. Ideas?
tycoonbob
Postby MadEvil » Tue Jul 03, 2012 8:04 pm
@tycoonbob
it looks like, you dont cleanup your Subsonic after uninstall. (The Uninstaller dont clean all stuff) To do so, delete also the C:\Subsonic folder to delete Database and subsonic.properties file.
Your Install use http://localhost:453 and this is not default from the installer.
If you install a "REAL" fesh install you have as default Subsonic on port 4040, so I suspect a mixed installation.
Hope this help you!
Best regards
Madsonic Developer
MadEvil
Postby Jameson » Wed Jul 04, 2012 7:21 pm
Hey MadEvil,
With the latest builds, I've been getting "Video not found or access denied" when trying to use the minute drop down box to skip ahead. Any ideas on how to fix this?
Jameson
Postby Jameson » Sun Jul 08, 2012 5:57 am
On a side note, I've manually updated ffmpeg and nothing abnormal shows up in the subsonic log..not sure whats up.
Jameson
Postby mp3sponge » Mon Jul 09, 2012 5:44 am
Not 100% sure what up , but Im having serious issues with no coverart displaying. Everything else seems good , it adds music , displays correctly and all. but I cant click on any albums from the 'home' page without that cover art being displayed. If I float the mouse over top of where the image should be , I get the 'mouse over' displayed artist - album name pop up though.
Is there something I might have missed? or does that feature not currently work?.. otherwise , its looking fantastic! I love how the mashup has release years displayed too . anyways , im running the latest java and installed the sdk as well just incase... so Im at a loss here.
if theres no info you need , let me know.
thx.
I tried chrome and everything was workin great on that , ... I dont mind keeping chrome going , but a working IE would be kinda nice. (Sorry on adding this later , but realized chrome was working after)
Jay.
mp3sponge
Postby BKKKPewsey » Mon Jul 09, 2012 11:31 am
Which version of IE are you using?
There is a problem with 4.7 not displaying cover art on IE8 which Sindre is aware of.
Postby tycoonbob » Mon Jul 09, 2012 2:43 pm
MadEvil wrote:@tycoonbob
Hope this help you!
Best regards
I am deleting the C:\Subsonic folder, just like always. I scan through the registry, %ProgramFiles%, and %ProgramFiles(x86)% as well...to delete anything that would happen to be there. Once installed, before ever opening a browser, I stop the service, set my RAM usage to 512, and change my port to 453...start the service, and load it up in a browser. I will give it another try, and make sure I didn't leave any files...and not change the default port.
tycoonbob
Return to Madsonic
