Madsonic - Mashup Mod (old Support Thread)
Re: Technical Preview: Subsonic Mashup Mod 4.7
Postby gacopl » Thu Sep 06, 2012 12:48 am
MadEvil wrote:
Hi, at first many thanks for donation, It's always nice to get recognition for this work!
I hope i can do some things for you:
*) Android Icon Sets, do you have any suggestions how it should look like?
Something like that? Just to make it fit with black shades and not ugly not coherent green, green is good but not in this ugly shade we got in standard :)
MadEvil wrote:*) do you have any notes about what you have changed for iframe modifications?
i made a patch for you http://pastebin.com/6TSb3sTn
MadEvil wrote:
*) which standard player did you mean for video playback freezes, what should be changed?
this is how it looks in original
and how it looks in your mod
the darker player is nice but it lacks of stop button and whats the point to skin when if you click for aspect ratio you still get the standard version and there's no consistency, but thats just my opinion :)
thanks for taking interest cheers mate :)
gacopl
Postby gacopl » Thu Sep 06, 2012 1:50 am
correct patch for v 3106 is here
http://pastebin.com/pzLTxuRq
the other one would not work and made mess this works flawlessly :)
cheers
and how to get this :D :
http://imgur.com/a/roLF5/embed#6
gacopl
Postby MadEvil » Fri Sep 07, 2012 4:54 am
gacopl wrote:Man you're doing tremendous job 20E (20 is really a lot in my country so imagine my gratefulness :) ) is going out for you, as it comes to android client there were few things that always pissed me in the original:
*play pause next prev buttons they are ugly and completely do nto fit into rest of the skin
cheers and keep the coding up ;)
Hi what do you think, i optimized some render function. This is only Android 2.3.6 and so it looks not so nice as on ICS or higher.
Best regards
Image Image Image Image
Madsonic Developer
MadEvil
Postby gacopl » Fri Sep 07, 2012 9:42 am
Best regards
This is it man, it's great you're unbelivable :)
gacopl
Postby MadEvil » Fri Sep 07, 2012 10:20 am
gacopl wrote:
MadEvil wrote:Hi what do you think, i optimized some render function. This is only Android 2.3.6 and so it looks not so nice as on ICS or higher.
Best regards
On an ICS Table it looks nice, but still far from being finished. :wink:
Best regards
Madsonic Developer
MadEvil
Postby MadEvil » Fri Sep 07, 2012 11:26 am
gacopl wrote:correct patch for v 3106 is here
cheers
i will merge this into the next Build next week! Now its family weekend! 8)
PS: You get this Player if you use the share function! its the external player!
best regards
Madsonic Developer
MadEvil
Re: Final: Madsonic Mashup Mod 4.7
Postby MadEvil » Wed Sep 12, 2012 10:07 am
New Build: 3110 (Final)
NEW: Merge to latest SVN Branch http://subsonic.svn.sourceforge.net/vie ... ision=3091
NEW: Update JSP to work in IFrame
NEW: Update some Theme issues
NEW: Revert to older Linux ffmpeg (works best with flac, m4a, ...)
NEW: Revert to older Windows ffmpeg (works best with flac, m4a, ...)
Download look @ first Post -> viewtopic.php?f=8&t=9187
Madsonic Developer
MadEvil
Postby SerpensAlatus » Wed Sep 12, 2012 10:12 am
Woah... I just installed the other Version yesterday. Can i Upgrade?
SerpensAlatus
Postby MadEvil » Wed Sep 12, 2012 10:51 am
SerpensAlatus wrote:Woah... I just installed the other Version yesterday. Can i Upgrade?
Sure you can, but wait for Build 3112, i found Changes in Sources that Sindre not checked in with SVN.
Best regards
Madsonic Developer
MadEvil
Postby MadEvil » Wed Sep 12, 2012 10:59 am
New Build: 3112 (Final)
NEW: Merged uncommitted Final Changes
NEW: *) Comment delete Play-count Fix
NEW: *) Playlist-import Fix
NEW: *) Scrobble Fix
Madsonic Developer
MadEvil
Postby GJ51 » Wed Sep 12, 2012 3:32 pm
Nice job. I installed 3112 over 3106 without any issues.
I'll let you know if I see anything worth whinning about, but so far it looks very nice!
Postby jdubso » Wed Sep 12, 2012 5:50 pm
I am getting a lot of the following errors. I was not getting these on build 3106.
[9/12/12 10:44:02 AM PDT]   WARN   RESTFilter   Error in REST API: EofException
Otherwise your work on this mod is amazing.
jdubso
Postby N17r0us » Wed Sep 12, 2012 6:03 pm
Hi All,
I am running the final version of this mod, I completed a clean install and I am having a problem streaming to mobile devices, both an iPhone and Android will connect to the server, start the buffering process but never play, regardless of how many times I select play. Any ideas?
BTW, great Mod, I really love all the new features.
N17r0us
Postby GJ51 » Wed Sep 12, 2012 6:09 pm
Mine works fine using one of the mod apk's for ICS. Have you checked your phones on other known working websites to determin if it's the phone or the server.
You're welcome to test on my server if you like. Just send me a PM and I'll send you the link and creds.
Postby N17r0us » Wed Sep 12, 2012 6:22 pm
I have verified my phone has full connectivity in both Wifi & 4G, the interesting part is it was working with just plain old Subsonic however since I deleted and rebuilt using the Madsonic Mod I haven't been able to stream.
I am able to access through my web browser on my computer, just not from my mobile devices.
N17r0us
Return to Madsonic
