Madsonic - Mashup Mod (old Support Thread)
Re: Final: Madsonic Mashup Mod 4.7
Postby GJ51 » Wed Sep 12, 2012 6:42 pm
But you haven't tested your phones on a known working server, or had someone else test your server availability from outside your network? Is the computer you're using to connect inside or outside your network?
You're letting us know you're having trouble, but you're not providing enough information to help pinpoint what the problem is.
My modded site is up and running and I can connect to it with my Android phone without issues. My other users are also not experiencing any issues.
If you want help, you have to be willing to do some simple tests that identify the problem.
It would also be helpful to know what OS and installation version you are running.
Postby MadEvil » Wed Sep 12, 2012 6:52 pm
N17r0us wrote:I have verified my phone has full connectivity in both Wifi & 4G, the interesting part is it was working with just plain old Subsonic however since I deleted and rebuilt using the Madsonic Mod I haven't been able to stream.
I am able to access through my web browser on my computer, just not from my mobile devices.
Well this can have several causes:
  • transcoding
  • Client App caching
  • wrong method with the wrong technique
TYI: Madsonic Mashup Mod works only with self hosted domain, the redirecting service from *.subsonic.org isn't working! (Work as Design)
I test my Mod with the standard Subsonic Android Client and it works well.
Did you replace the ffmpeg version or did you try an other version?
Did you try to wipe your Subsonic App Caches/Data on Mobile Clients?
can you give me some more details? (Server, Installation, Environment, ...)
Best regards
Madsonic Developer
MadEvil
Postby N17r0us » Wed Sep 12, 2012 7:14 pm
For my versions I am running 3112 on w Windows7 machine, my machine is accessible outside my internal home network, I am using a (no-ip.com) host redirect which has my correct and current IP for my home internet establised. I can access the web interface for the subsonic server remotely from my work or from friends houses so I know all ports are being forwarded correctly, additionally I can access the web interface from my mobile phone web browser.
I am using iSub Music Streamer for my iPhone, I have removed and re installed the program as well as reconfigured all settings.
What seems to happen is the app will connect to my subsonic server and act as if its playing however doesn't, it will however fully cache the song and I can then play the file from it being locally cached.
@GJ51 I will shoot you a PM shortly to get test credentials.
N17r0us
Postby N17r0us » Wed Sep 12, 2012 8:16 pm
Thank you Gary (GJ51) for all your help, I will find a better solution for my phone.
N17r0us
Postby MadEvil » Fri Sep 14, 2012 11:33 am
Madsonic Client Design Draft 2
Image Image Image
Show Design Gallery
Best regards
Madsonic Developer
MadEvil
Postby GJ51 » Fri Sep 14, 2012 7:17 pm
  • transcoding
Best regards
Actually, the redirect service will work if you do a few extra steps. I switched to the WAR version a while back once Bushman4 convinced me I wasn't too old to learn new tricks.
If you install Subsonic using the standard release and register the server.subsonic.org address, then change over to your modded setup and use the same port it'll work. I did that a few months ago when I started using the Mashup mod and never noticed that it was an issue.
Postby gurutech » Sun Sep 16, 2012 11:45 pm
Can someone post the link to this? The only ones I have found from the first post are gallery (pictures), or the sourceforge repository. I can't seem to find the actual mod in the first post.
gurutech
Postby GJ51 » Mon Sep 17, 2012 12:11 am
Postby gurutech » Mon Sep 17, 2012 1:15 am
Installed, and got this error:
Error
Exception    org.springframework.jdbc.BadSqlGrammarException
Message    PreparedStatementCallback; bad SQL grammar [select media_file.id,media_file.path,media_file.folder,media_file.type,media_file.override,media_file.format,media_file.title,media_file.album,media_file.album_name,media_file.artist,media_file.album_artist,media_file.disc_number,media_file.track_number,media_file.year,media_file.genre,media_file.bit_rate,media_file.variable_bit_rate,media_file.duration_seconds,media_file.file_size,media_file.width,media_file.height,media_file.cover_art_path,media_file.parent_path,media_file.play_count,media_file.last_played,media_file.comment,media_file.created,media_file.changed,media_file.last_scanned,media_file.children_last_updated,media_file.present,media_file.version from media_file, playlist_file where media_file.id = playlist_file.media_file_id and playlist_file.playlist_id = ? and media_file.present order by playlist_file.id]; nested exception is java.sql.SQLException: Column not found: MEDIA_FILE.OVERRIDE in statement [select media_file.id,media_file.path,media_file.folder,media_file.type,media_file.override,media_file.format,media_file.title,media_file.album,media_file.album_name,media_file.artist,media_file.album_artist,media_file.disc_number,media_file.track_number,media_file.year,media_file.genre,media_file.bit_rate,media_file.variable_bit_rate,media_file.duration_seconds,media_file.file_size,media_file.width,media_file.height,media_file.cover_art_path,media_file.parent_path,media_file.play_count,media_file.last_played,media_file.comment,media_file.created,media_file.changed,media_file.last_scanned,media_file.children_last_updated,media_file.present,media_file.version from media_file, playlist_file where media_file.id = playlist_file.media_file_id and playlist_file.playlist_id = ? and media_file.present order by playlist_file.id]
Java version    Oracle Corporation 1.7.0_06-icedtea
Operating system    Linux 3.5.3-1.fc17.i686
Server    jetty-6.1.x
Memory    Used 49 of 79 MB
Stack trace    org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select media_file.id,media_file.path,media_file.folder,media_file.type,media_file.override,media_file.format,media_file.title,media_file.album,media_file.album_name,media_file.artist,media_file.album_artist,media_file.disc_number,media_file.track_number,media_file.year,media_file.genre,media_file.bit_rate,media_file.variable_bit_rate,media_file.duration_seconds,media_file.file_size,media_file.width,media_file.height,media_file.cover_art_path,media_file.parent_path,media_file.play_count,media_file.last_played,media_file.comment,media_file.created,media_file.changed,media_file.last_scanned,media_file.children_last_updated,media_file.present,media_file.version from media_file, playlist_file where media_file.id = playlist_file.media_file_id and playlist_file.playlist_id = ? and media_file.present order by playlist_file.id]; nested exception is java.sql.SQLException: Column not found: MEDIA_FILE.OVERRIDE in statement [select media_file.id,media_file.path,media_file.folder,media_file.type,media_file.override,media_file.format,media_file.title,media_file.album,media_file.album_name,media_file.artist,media_file.album_artist,media_file.disc_number,media_file.track_number,media_file.year,media_file.genre,media_file.bit_rate,media_file.variable_bit_rate,media_file.duration_seconds,media_file.file_size,media_file.width,media_file.height,media_file.cover_art_path,media_file.parent_path,media_file.play_count,media_file.last_played,media_file.comment,media_file.created,media_file.changed,media_file.last_scanned,media_file.children_last_updated,media_file.present,media_file.version from media_file, playlist_file where media_file.id = playlist_file.media_file_id and playlist_file.playlist_id = ? and media_file.present order by playlist_file.id] at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.doTranslate(SQLErrorCodeSQLExceptionTranslator.java:220) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:72) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:607) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:641) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:670) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:678) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:710) at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83) at net.sourceforge.subsonic.dao.MediaFileDao.getFilesInPlaylist(MediaFileDao.java:82) at net.sourceforge.subsonic.service.PlaylistService.getFilesInPlaylist(PlaylistService.java:96) at net.sourceforge.subsonic.controller.LoadPlaylistController.loadPlaylistConfirm(LoadPlaylistController.java:72) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473) at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:807) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501) at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at net.sourceforge.subsonic.filter.RequestEncodingFilter.doFilter(RequestEncodingFilter.java:43) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:54) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:54) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360) at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216) at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181) at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:712) at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405) at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:139) at org.mortbay.jetty.Server.handle(Server.java:313) at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:506) at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:830) at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514) at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211) at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:381) at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:396) at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:442) Caused by: java.sql.SQLException: Column not found: MEDIA_FILE.OVERRIDE in statement [select media_file.id,media_file.path,media_file.folder,media_file.type,media_file.override,media_file.format,media_file.title,media_file.album,media_file.album_name,media_file.artist,media_file.album_artist,media_file.disc_number,media_file.track_number,media_file.year,media_file.genre,media_file.bit_rate,media_file.variable_bit_rate,media_file.duration_seconds,media_file.file_size,media_file.width,media_file.height,media_file.cover_art_path,media_file.parent_path,media_file.play_count,media_file.last_played,media_file.comment,media_file.created,media_file.changed,media_file.last_scanned,media_file.children_last_updated,media_file.present,media_file.version from media_file, playlist_file where media_file.id = playlist_file.media_file_id and playlist_file.playlist_id = ? and media_file.present order by playlist_file.id] at org.hsqldb.jdbc.Util.throwError(Unknown Source) at org.hsqldb.jdbc.jdbcPreparedStatement.(Unknown Source) at org.hsqldb.jdbc.jdbcConnection.prepareStatement(Unknown Source) at org.springframework.jdbc.core.JdbcTemplate$SimplePreparedStatementCreator.createPreparedStatement(JdbcTemplate.java:1322) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:585) ... 67 more
gurutech
Postby gurutech » Mon Sep 17, 2012 1:24 am
Found the problem... It's with how my media folders are entered into Subsonic. If I delete both of the folders from the list, the error goes away (but of course, I now have no music!).
As soon as I add a folder (which is in the format of: /media/music), the error comes back. It appears the SQL backend doesn't like that format or something... any ideas how to fix? I'm running Fedora 17, with MySQL, if that helps.
gurutech
Postby jdubso » Mon Sep 17, 2012 1:46 am
Fresh install or upgrade? If upgrade make a backup then try a fresh install. Then add media back.
Sent from my Galaxy Nexus using Tapatalk 2
jdubso
Postby gurutech » Mon Sep 17, 2012 2:35 am
Did it both ways. Same thing. As soon as a media folder is added, I get the error. If I delete (or even disable) all folders, then it's fine.
One thing I did notice was that I can click on "DB" and click on any of the options listed and click OK, it will show me the correct results.
gurutech
Postby gurutech » Mon Sep 17, 2012 2:48 am
ok, seems to be working now... removed it again, then deleted the /var/subsonic folder and reinstalled.
Had to re-do the whole "change admin password" again, but at least it's scanning everything now.
Edit: OK, seems to be working great, except for one thing - the Carousel mod. I click "Hot" and it will show me the "Loading", right, and left arrows, but fails to show any cover art. Any ideas on this? (Had similar problem before installing Mashup with the same mod...)
gurutech
Postby MadEvil » Tue Sep 18, 2012 1:46 am
gurutech wrote:ok, seems to be working now... removed it again, then deleted the /var/subsonic folder and reinstalled.
hi,
this is changed since Build 3100 viewtopic.php?f=8&t=9187&start=195#p45124
Now you can tag your own favorite albums without linked to Top Rated albums.
Hope this help you.
Best regards
Madsonic Developer
MadEvil
Postby gurutech » Tue Sep 18, 2012 3:52 am
User error... sheesh... lol
Is this new feature "per user", or is it "overall" (meaning anyone can select an album as a hot item and everyone will see it as a hot item?)
gurutech
Return to Madsonic
