Madsonic - Mashup Mod (old Support Thread)
Re: Madsonic - Mashup Mod 4.7
Postby jonnymnemo » Wed Sep 26, 2012 3:39 pm
Aktarus wrote:I use Google Chrome and Subsonic installation respond to HTTPS://******.*******.****:4041
If I try to use HTTP://******.*******.****:4040 .... error, no page to display !!!
So the answer was really in the previous page ! :wink:
Ok ok, I'm in a good mood :
The similar artist feature is a non secure content (http), whereas your subsonic is secure (https).
In the address bar, on the right, there should be a small icon sayng that the page contains insecure content. Click on it an activate the content.
Everything should be OK now !
jonnymnemo
Postby MediocreFred » Thu Sep 27, 2012 3:19 am
Long time Subsonic user, but, noobie to this mod (or any mod for that matter).
I have installed this on a brand new server running Ubuntu. So far, everything looks good. I have 2 questions that I'd appreciate help with.
1. To install newer builds, do I just download the most recent war.zip, extract the 3 files, shutdown Subsonic service, replace the 3 files and tart the service back up? Is this the recommended approach?
2. On my music server, the bulk of the users are going to be anonymous (logging in as guest/guest). So, for the guest user, I would like to disable a few of the menu options and also the whole Search bar (Search Google Wikipedia ...) that appears on the Playing page. What is the easiest way to "security-trim" the menu buttons as well as the Search Bar? Also, any way of disabling the page that shows up when clicking on the Subsonic logo (top-left) for guest users? Ideally, can some of these be added to the settings so I don't have to hack code with each new build?
MediocreFred.
MediocreFred
Postby jonnymnemo » Thu Sep 27, 2012 9:46 am
Hi MadEvil !
Your last update is very good ! No bugs encountered since I installed it. :D
Although, the thread about your mod is starting to be a little messy, with feature requests, help requests, bugs discussions, tips for installation...
I think it would be a good idea to have different sections for each topic, either in the subsonic forum, or in a dedicated forum.
What do you think ?
jonnymnemo
Re: Final: Madsonic Mashup Mod 4.7
Postby j3tblk » Thu Sep 27, 2012 12:28 pm
MadEvil wrote:
j3tblk wrote:Is there a way to turn off the sliders?
I've had two people (out of four) complain about them being too sensitive...it is hard to use even for me and I don't need custom sliders.
i know the problem, but this can be fixed in your mouse control panel - you can take back the sensitivity for scrolling with the wheel.
best regards
So I've played with my mouse settings as suggested. I've taken the scroll and adjustments levels all the way down to the point where my 90 year old Grandmother would be bored by the mouse movement speed.
It is still touchy and wonky on the left side. It's unusable like this. I just want to disable it. I have over 2TB of audio so the left side list is fairly long. Could someone poing me in the right direction to disable the custom sliders? They are a deal breaker for me. Furthermore, ALL of my users have now emailed me complaining about this too. Thanks!
j3tblk
Postby MediocreFred » Thu Sep 27, 2012 2:43 pm
To add to the below, another question - why don't all builds on this page - http://uploaded.net/f/zryfjb - have DEBs? Some builds only have setup (which I think is just for Windows) and WARs. So, I am build 3125 (on Ubuntu). To get to the latest build (3132), do I have to install the 3130 DEB on top of current installation and then download the 3132 WAR.ZIP and replace the 3 files (since there is no DEB for the 3132 build) or, do I just download the 3132 WARs and overwrite the 3 files in my 3125 build?
Request to MadEvil - For rookies like myself, can you please include brief instructions in the first post to update to newer builds (especially on Unix).
Thanks.
MediocreFred wrote:Hello,
MediocreFred.
MediocreFred
Postby jonnymnemo » Thu Sep 27, 2012 3:28 pm
Mediocrefred :
With a war package, you can easy update your madsonic.
Unzip the files in the /usr/share/subsonic folder, then in the same folder do a
chmod +x *
If you don't, subsonic won't be able to start.
In summary (you have to be in root):
service subsonic stop
cd /usr/share/subsonic
wget put_the_link_to_the_file -O the_name_you_want_to_give_it.zip
unzip the_name_you_want_to_give_it.zip
chmod +x *
service subsonic start
All builds don't have deb, ok, but the installation with a war package is quite as easy ! :wink:
jonnymnemo
Postby gurutech » Fri Sep 28, 2012 4:17 am
I'm running Fedora - would I put everything into /var/subsonic instead of /usr/share/subsonic for a WAR installation? I've always just done the RPM install.
gurutech
Postby jonnymnemo » Fri Sep 28, 2012 6:51 am
gurutech wrote:I'm running Fedora - would I put everything into /var/subsonic instead of /usr/share/subsonic for a WAR installation? I've always just done the RPM install.
I can't be sure about fedora, but normally it should be the same.
- one directory with the core files ( /usr/share/subsonic on ubuntu)
- one directory with the running files and the database ( /var/subsonic )
- one config file named subsonic ( /etc/default )
- the startup file subsonic.sh (/etc/init.d) which can be a symlink to the core folder
Maybe somebody with fedora could confirm ?
Edit : I just had a look in the last rpm. It is quite the same as in ubuntu, except the config file is in /etc/sysconfig (instead of /etc/default)
So yes, you have to unzip the war package in /usr/share/subsonic
jonnymnemo
Postby jonnymnemo » Fri Sep 28, 2012 11:21 am
Some users seem to have problems to upgrade madsonic, especially if it is a .war package.
To help some of them, I made a bash script for updating to the latest madsonic version.
My script works in ubuntu, but it could work for other distros.
Features :
- backup of the /var/subsonic folder in /var/subsonicYYMMDDhhmm
- java 7 install (with package list update and upgrade)
- madsonic .deb install
- madsonic .war update
- each feature is optionnal
Here is the code :
#!/bin/bash
echo "######Madsonic update utility######"
echo "This script works for ubuntu"
echo "You should be in root mode for it to work"
echo "Yes or no questions are in capital : Y or N"
# Stop subsonic deamon
echo "First, we stop subsonic deamon"
# Prompt for backup
echo "Do you want to backup your subsonic folder before continuing ? IT IS HIGHLY RECOMMENDED !!!!! (default=Y) (Y/N)"
read reply
if [ "$reply" = N ]
   then    echo "OK OK, but don't complain then..."
   else   echo "Your subsonic database (only the /var/subsonic folder) will be saved in /var/subsonicYYMMDDhhmm"
      cp -R /var/subsonic /var/subsonic"$(date +%y%m%d%k%M)"
fi
# This part makes sure java 7 is installed
echo "Your java version is :"
java -version
echo "Java 7 is needed for madsonic (your version number should be starting with 1.7). If you can't install it, make sure to install a madsonic compatible edition (SE), and answer yes to the next question."
echo "Do you hava java 7 installed ? (default=Y) (Y/N)"
read reply
if [ "$reply" = "N" ]
# Package list update
   then    apt-get update
# Prompt for package upgrades
   echo "Before installing java, do you want to upgrade your packages ? (default=Y) (Y/N)"
   read reply
      then echo "Ok, skipping package upgrade !"
      else apt-get upgrade
   fi
# Java installation
   apt-get install openjdk-7-jre
   else    echo "Ok, we skip the java install..."
fi
# Prompt for debian madsonic
echo "Do you have the latest madsonic DEBIAN package ? (default=Y) (Y/N) "
read reply
   then
# This part installs the madsonic .deb package
      echo "paste the link to the madsonic deb package"
      read deblink
      echo "which build number ?"
      read debno
      wget "$deblink" -O madsonic"$debno".deb
      dpkg -i madsonic"$debno".deb
   else echo "Ok, we skip the debian package install..."
fi
# This part makes sure this is the latest version of madsonic
echo "Is your madsonic the latest version ? (default=Y) (Y/N)"
read reply
   then
   echo "Make sure you installed a .deb package before, because the war packages doesn't contain everything !!!!!"
   echo "Are you sure you want to install the latest .war package ? (default=N) (Y/N)"
   read reply
   if [ "$reply" = "Y" ]
      then
# This part updates madsonic with the latest war package
         echo "Paste the link to the madsonic war package"
         read madlink
         echo "Which build number is it?"
         read buildno
         wget "$madlink" -O madsonic"$buildno".zip
         unzip -o madsonic"$buildno".zip -d /usr/share/subsonic
         chmod +x /usr/share/subsonic/*
         else echo "Ok, we skip the .war update..."
   fi
fi
# Start subsonic deamon
echo "Madsonic starting again..."
echo "Thank you for installing madsonic !"
exit
Link to download : http://dl.free.fr/mru6yayUZ
INSTRUCTIONS :
- copy this file to any folder
- start the script with sudo :
sudo sh madsonicupdate.sh
If you have any suggestions to make it better, don't hesitate ! :wink:
EDIT : I forgot to uncomment a line. It should be OK now !
jonnymnemo
Postby MediocreFred » Fri Sep 28, 2012 12:19 pm
jonnymnemo - THANKS so much for your detailed replies and the script!!! I sure hope MadEvil adds your instructions to the OP for others looking for this info.
One question. Is it always required/recommended to be on the latest DEB version before installing the latest WAR (assuming the WAR is a newer build than the latest DEB build)?
So, always get the latest DEB and install it. After this, If there is a newer WAR, install that too. Is this how it is supposed to be done?
Also, any thoughts on how I would go about hiding certain menu items or links on pages from certain users (either hide <certain features> from user "guest" or only show <certain features> for users with "admin" role.)? I have Sindre's Subsonic installed on another server (Windows) and there, I have edited JSP files under the jetty/nnnn/... folder to selectively hide/show menu items; have to remember to replace my tweaked files after every update. Since Madsonic has much more frequent updates, it gets cumbersone to repackage subsonic.war with tweaked files each time. Any suggestions? Is there a jetty folder in Linux too?
MediocreFred.
MediocreFred
Postby jonnymnemo » Fri Sep 28, 2012 12:26 pm
MediocreFred wrote:jonnymnemo - THANKS so much for your detailed replies and the script!!! I sure hope MadEvil adds your instructions to the OP for others looking for this info.
MediocreFred.
You're welcome ! :D
Yes, I would recommend to install the latest .deb version before, because some files not included in the .war package might have been changed (most of times they are not, but just in case).
For your menu hiding thing, I can't answer to you, I really know nothing about java. I suppose it could be a feature to add, but it doesn't seem to be implemented yet.
jonnymnemo
Postby jonnymnemo » Fri Sep 28, 2012 3:01 pm
Small bugfix for the script. One line was not working (in the .deb part). That's OK now.
jonnymnemo
Postby rixton » Sun Sep 30, 2012 9:34 am
Really love this mod, I however got some issues with loading large folders containing about ~10 000 albums, it seems to load fine, but after a while the browser just freezes (and the CPU runs up), finally I have to force-quit it
Gets the same issue in both Chrome, Firefox and Safari
The server dont get any high CPU/RAM usage at all
Have tried to do an complete re-install but always ends with the same results
I have no issue´s loading the same folder when using the original Subsonic 4.7 (even though it takes some time to load the folder)
rixton
AW: Re: Madsonic - Mashup Mod 4.7
Postby MadEvil » Sun Sep 30, 2012 11:34 am
MediocreFred.
Hi there,
In the next build i add a new role as feature to your question, so you can disable and cut down thr search functions in the interface for each user.
Best regards
Madsonic Developer
MadEvil
Postby MadEvil » Sun Sep 30, 2012 11:39 am
jonnymnemo wrote:Hi MadEvil !
What do you think ?
Yes you are right, next month i am going to start a new platform with own forum and more. :grin:
Best regards
Madsonic Developer
MadEvil
Return to Madsonic
