MadEvil wrote:tycoonbob wrote:Testing the 4.7 build now. I am so excited; been waiting what seems forever!
EDIT: Not working for me.
I downloaded the setup, and it installed. Configured to use HTTP, set my memory to 512 like always...restarted the service and getting a 404 when trying to browse to.
HTTP ERROR: 404
NOT_FOUND
RequestURI=/index.view
To clarify, this was a clean install after uninstall my stock 4.7b1 install, and deleting the subsonic folder on the root of my C:. After this failed, I uninstalled build 2992, reinstalled the stock 4.7b1, and installed 2992 overtop...and it's working again.
look at this http://subsonic.svn.sourceforge.net/vie ... ision=2986
i merged this changes with my build 2992.
maybe wrong port default ist now 4040?
do you found error in the subsonic.log file?
do you clean the whole subsonic folder before installation (incl. db & jetty folder and also the subsonic.properties)?
best regards
tycoonbob wrote:
EDIT: Already ran into an issue.
Every time a page loads, I get a popup warning which says:
Failed to find parameter: httpSessionId
Once I hit okay, it may popup up to another 4 times, but it seems the page is loading fine. This happens with the latest version of Chrome for me, clean install.
Try also clean your Browser cache & cookies! or try firefox ... i found also some strange bugs with crome 19.
best regards
[2012-05-25 10:00:00,746] INFO MediaScannerService - Starting to scan media library.
[2012-05-25 10:00:01,308] INFO MediaScannerService - Scanned media library with 250 entries.
[2012-05-25 10:00:01,793] INFO MediaScannerService - Scanned media library with 500 entries.
[2012-05-25 10:00:02,324] INFO MediaScannerService - Scanned media library with 750 entries.
[2012-05-25 10:00:02,777] INFO MediaScannerService - Scanned media library with 1000 entries.
[2012-05-25 10:00:03,261] INFO MediaScannerService - Scanned media library with 1250 entries.
[2012-05-25 10:00:03,730] INFO MediaScannerService - Scanned media library with 1500 entries.
[2012-05-25 10:00:04,246] INFO MediaScannerService - Scanned media library with 1750 entries.
[2012-05-25 10:00:04,730] INFO MediaScannerService - Scanned media library with 2000 entries.
[2012-05-25 10:00:05,324] INFO MediaScannerService - Scanned media library with 2250 entries.
[2012-05-25 10:00:05,824] INFO MediaScannerService - Scanned media library with 2500 entries.
[2012-05-25 10:00:06,293] INFO MediaScannerService - Scanned media library with 2750 entries.
[2012-05-25 10:00:07,027] INFO MediaScannerService - Scanned media library with 3000 entries.
[2012-05-25 10:00:07,496] INFO MediaScannerService - Scanned media library with 3250 entries.
[2012-05-25 10:00:07,980] INFO MediaScannerService - Scanned media library with 3500 entries.
[2012-05-25 10:00:08,464] INFO MediaScannerService - Scanned media library with 3750 entries.
[2012-05-25 10:00:08,949] INFO MediaScannerService - Scanned media library with 4000 entries.
[2012-05-25 10:00:09,458] INFO MediaScannerService - Scanned media library with 4250 entries.
[2012-05-25 10:00:09,942] INFO MediaScannerService - Scanned media library with 4500 entries.
[2012-05-25 10:00:10,442] INFO MediaScannerService - Scanned media library with 4750 entries.
[2012-05-25 10:00:10,911] INFO MediaScannerService - Scanned media library with 5000 entries.
[2012-05-25 10:00:11,473] INFO MediaScannerService - Scanned media library with 5250 entries.
[2012-05-25 10:00:11,958] INFO MediaScannerService - Scanned media library with 5500 entries.
[2012-05-25 10:00:12,442] INFO MediaScannerService - Scanned media library with 5750 entries.
[2012-05-25 10:00:12,911] INFO MediaScannerService - Scanned media library with 6000 entries.
[2012-05-25 10:00:13,395] INFO MediaScannerService - Scanned media library with 6250 entries.
[2012-05-25 10:00:13,864] INFO MediaScannerService - Scanned media library with 6500 entries.
[2012-05-25 10:00:14,333] INFO MediaScannerService - Scanned media library with 6750 entries.
[2012-05-25 10:00:14,801] INFO MediaScannerService - Scanned media library with 7000 entries.
[2012-05-25 10:00:15,286] INFO MediaScannerService - Scanned media library with 7250 entries.
[2012-05-25 10:00:15,754] INFO MediaScannerService - Scanned media library with 7500 entries.
[2012-05-25 10:00:16,223] INFO MediaScannerService - Scanned media library with 7750 entries.
[2012-05-25 10:00:16,879] INFO MediaScannerService - Scanned media library with 8000 entries.
[2012-05-25 10:00:17,379] INFO MediaScannerService - Scanned media library with 8250 entries.
[2012-05-25 10:00:17,848] INFO MediaScannerService - Scanned media library with 8500 entries.
[2012-05-25 10:00:18,395] INFO MediaScannerService - Scanned media library with 8750 entries.
[2012-05-25 10:00:18,926] INFO MediaScannerService - Scanned media library with 9000 entries.
[2012-05-25 10:00:19,551] INFO MediaScannerService - Scanned media library with 9250 entries.
[2012-05-25 10:00:20,036] INFO MediaScannerService - Scanned media library with 9500 entries.
[2012-05-25 10:00:20,504] INFO MediaScannerService - Scanned media library with 9750 entries.
[2012-05-25 10:00:21,286] INFO MediaScannerService - Scanned media library with 10000 entries.
[2012-05-25 10:00:21,770] INFO MediaScannerService - Scanned media library with 10250 entries.
[2012-05-25 10:00:22,270] INFO MediaScannerService - Scanned media library with 10500 entries.
[2012-05-25 10:00:22,754] INFO MediaScannerService - Scanned media library with 10750 entries.
[2012-05-25 10:00:23,004] ERROR MediaScannerService - Failed to scan media library.
java.lang.StringIndexOutOfBoundsException: String index out of range: -2
at java.lang.String.substring(Unknown Source)
at net.sourceforge.subsonic.util.StringUtil.truncateYear(StringUtil.java:239)
at net.sourceforge.subsonic.service.MediaFileService.createMediaFile(MediaFileService.java:580)
at net.sourceforge.subsonic.service.MediaFileService.updateChildren(MediaFileService.java:350)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:216)
at net.sourceforge.subsonic.service.MediaScannerService.scanFile(MediaScannerService.java:201)
at net.sourceforge.subsonic.service.MediaScannerService.scanFile(MediaScannerService.java:205)
at net.sourceforge.subsonic.service.MediaScannerService.doScanLibrary(MediaScannerService.java:165)
at net.sourceforge.subsonic.service.MediaScannerService.access$000(MediaScannerService.java:46)
at net.sourceforge.subsonic.service.MediaScannerService$2.run(MediaScannerService.java:144)
tycoonbob wrote:
- Code: Select all
This is what is happening during the scan. I know diddly squat about java, so what's going on?
- Code: Select all
i fixed this in the Build 3002.
Best regards
tycoonbob wrote:MadEvil wrote:tycoonbob wrote:
- Code: Select all
Best regards
Clean install of 3002, and my video folders scanned just like they should have. 1080p Movies with DTS audio, are streaming flawlessly at 5000kbps on my LAN, and very happy about that. The only thing I have a question about, and this may be intentional...is I don't see the bar on right side of the screen. The one that shows who is currently logged in, and what they are listening to. Did you remove this?
felldownawell wrote:Great mod.
I'm having an issue when I set it to browse by tag in build 3002.
The artist links in the left pane each link to "main.view?id=" with no actual id appended. Obviously, these links are non-functional and bring up a Java exception page if clicked.
I doubt it's important, but I have a flat directory structure with a separate folder for each album at the root of the share.
Everything looks fine in the artist table, but the query to bring up media_file where type = 'artist' gives no results.
Any idea what I screwed up?
Thanks.
MadEvil wrote:its there, but as default not enabled !
go to your personal Settings, there you can enable one of this two options and the right Frame will be displayed.
best regards
