Madsonic - Mashup Mod (old Support Thread)
Re: Technical Preview: Subsonic Mashup Mod 4.7
Postby Drefsab » Sun Jun 03, 2012 2:13 am
I tried this last night but ended up pulling it right away, my file list on the left hand side was messed up, loads of stuff I know is there wasn't even showing up at all. Some of the names that did show up were missing the first characters such as T, O and The. I'm not sure what it was but there was that much content not even showing at all that I couldn't leave it on for long.
It was with IE 8 and and FF10 (all we have in work im afraid).
Drefsab
Postby Magica » Sun Jun 03, 2012 7:36 am
MadEvil wrote:some changes in scanning, i test the new build 3010 on an fresh install and works well.
*) Ubuntu 12.04
*) Fedora 17
do you have some logs or errors ?
best regards
I got this error:
Exception org.springframework.jdbc.BadSqlGrammarException
Message PreparedStatementCallback; bad SQL grammar [select id, path, folder, type, format, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; nested exception is java.sql.SQLException: Column not found: ALBUM_NAME in statement [select id, path, folder, type, format, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed,
This error comes in Fedora16 and Ubuntu 12.04
Is the newest build available for download?
BR
-m-
Magica
Postby hakko » Sun Jun 03, 2012 11:57 am
I encourage other people to use and modify the MusicCabinet library that I've written, and it seems like it has found it's way into the Mashup Mod. That's great!
However, I'd like to point out that both Subsonic and MusicCabinet are released under the GPL licence. That means you're free to modify the code to fit your own needs. But if you release your modifications to the public, the GPL license also demands that you make your own code available to the public. Therefore, I'm wondering where to find it?
By making your code public, you allow other people to make changes to it, just like you're doing yourself. There is a reason for having that license, and the reason is to help people build on each others work.
http://www.gnu.org/licenses/gpl-faq.htm ... stedPublic
MusicCabinet developer
hakko
Postby massiliattak » Sun Jun 03, 2012 1:57 pm
Here is my log:
Error
Exception   javax.servlet.ServletException
Message   javax.servlet.jsp.el.ELException: Unable to find a value for "id" in object of class "net.sourceforge.subsonic.domain.MusicIndex$Artist" using operator "."
Java version   Sun Microsystems Inc. 1.6.0_32
Operating system   Windows 7 6.1
Server   jetty-6.1.x
Memory   Used 12 of 26 MB
Stack trace   javax.servlet.ServletException: javax.servlet.jsp.el.ELException: Unable to find a value for "id" in object of class "net.sourceforge.subsonic.domain.MusicIndex$Artist" using operator "."
   at org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:858)
   at org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:791)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspService(org.apache.jsp.WEB_002dINF.jsp.left_jsp:343)
   at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:97)
   at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:332)
   at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314)
   at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264)
   at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:362)
   at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:268)
   at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:126)
   at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:236)
   at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:257)
   at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1183)
   at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:902)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:715)
   at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:47)
Caused by: javax.servlet.jsp.el.ELException: Unable to find a value for "id" in object of class "net.sourceforge.subsonic.domain.MusicIndex$Artist" using operator "."
   at org.apache.commons.el.Logger.logError(Logger.java:481)
   at org.apache.commons.el.Logger.logError(Logger.java:498)
   at org.apache.commons.el.Logger.logError(Logger.java:611)
   at org.apache.commons.el.ArraySuffix.evaluate(ArraySuffix.java:340)
   at org.apache.commons.el.ComplexValue.evaluate(ComplexValue.java:145)
   at org.apache.commons.el.ExpressionEvaluatorImpl.evaluate(ExpressionEvaluatorImpl.java:263)
   at org.apache.commons.el.ExpressionEvaluatorImpl.evaluate(ExpressionEvaluatorImpl.java:190)
   at org.apache.jasper.runtime.PageContextImpl.proprietaryEvaluate(PageContextImpl.java:932)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspx_meth_sub_param_2(org.apache.jsp.WEB_002dINF.jsp.left_jsp:1960)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspx_meth_c_otherwise_1(org.apache.jsp.WEB_002dINF.jsp.left_jsp:1926)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspx_meth_c_choose_1(org.apache.jsp.WEB_002dINF.jsp.left_jsp:1806)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspx_meth_sub_url_1(org.apache.jsp.WEB_002dINF.jsp.left_jsp:1769)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspx_meth_c_forEach_5(org.apache.jsp.WEB_002dINF.jsp.left_jsp:1716)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspx_meth_c_forEach_4(org.apache.jsp.WEB_002dINF.jsp.left_jsp:1646)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspService(org.apache.jsp.WEB_002dINF.jsp.left_jsp:297)
   ... 70 more
massiliattak
Postby MadEvil » Sun Jun 03, 2012 3:35 pm
massiliattak wrote:Hello,
Here is my log:
Error
Server   jetty-6.1.x
   ... 70 more
hmm, it looks you have some strange combination of diffrent subsonic versions.
so uninstall current version and delete also the db/jetty/lucense-folder and the subsonic.properties! file.
Then install a fresh 3012 Build, I've made also .deb and .rpm installation packages to install it on ubuntu/Fedora.
best regards
Madsonic Developer
MadEvil
Postby MadEvil » Sun Jun 03, 2012 3:51 pm
hakko wrote:I encourage other people to use and modify the MusicCabinet library that I've written, and it seems like it has found it's way into the Mashup Mod. That's great!
hi hakko,
i'm a big fan of your MusicCabinet project, it's so geat i want and also tryed it to integrate your hard work into Mashup Mod, but your Basebuild Changes of Subsonic and MusicCabinet are so diffrent to my 4.7 changes of the logic and core. But your ideas for subsonic are great and so i write it up from scratch, without postgres db and LastFM, i want it keep simple.
but my problem is, i am only a newbie doing all this tasks, therforce i don't get it to work to fork the original SVN trunk to github and make my changes
visible to a new brunch of it (like Supersonic). Can you help me with this? this screwed me up
PS: the plan to publish the whole project, is when Sindre is releasing the final subsonic 4.7 version, in the meantime I will disable the download.
best regards
Madsonic Developer
MadEvil
Postby massiliattak » Sun Jun 03, 2012 5:57 pm
Hello again,
All previous versions have been uninstalled & all concerned folders removed, fresh install of the B3012 version and...still the almost same error message:
Error
Server   jetty-6.1.x
Memory   Used 53 of 80 MB
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspService(org.apache.jsp.WEB_002dINF.jsp.left_jsp:347)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspx_meth_sub_param_2(org.apache.jsp.WEB_002dINF.jsp.left_jsp:1982)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspx_meth_c_otherwise_1(org.apache.jsp.WEB_002dINF.jsp.left_jsp:1948)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspx_meth_c_choose_1(org.apache.jsp.WEB_002dINF.jsp.left_jsp:1828)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspx_meth_sub_url_1(org.apache.jsp.WEB_002dINF.jsp.left_jsp:1791)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspx_meth_c_forEach_5(org.apache.jsp.WEB_002dINF.jsp.left_jsp:1738)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspx_meth_c_forEach_4(org.apache.jsp.WEB_002dINF.jsp.left_jsp:1668)
   at org.apache.jsp.WEB_002dINF.jsp.left_jsp._jspService(org.apache.jsp.WEB_002dINF.jsp.left_jsp:301)
   ... 70 more
Thanks for your support
massiliattak
Postby MadEvil » Sun Jun 03, 2012 6:18 pm
massiliattak wrote:Hello again,
Error
Server   jetty-6.1.x
   ... 70 more
please can you PM me your whole subsonic.log /subsonic.sh.log files.
What kind of file are in your media folder (try it with only audio files?)
best regards
Madsonic Developer
MadEvil
Postby hakko » Sun Jun 03, 2012 7:07 pm
MadEvil wrote:i'm a big fan of your MusicCabinet project, it's so geat i want and also tryed it to integrate your hard work into Mashup Mod, but your Basebuild Changes of Subsonic and MusicCabinet are so diffrent to my 4.7 changes of the logic and core. But your ideas for subsonic are great and so i write it up from scratch, without postgres db and LastFM, i want it keep simple.
Interesting! I think you could create some good enhancements just using the ID3 tags. So many people are asking for that aswell.
MadEvil wrote:but my problem is, i am only a newbie doing all this tasks, therforce i don't get it to work to fork the original SVN trunk to github and make my changes
I don't know the details on how to get this running, but I think you should check out the code from the Subsonic SVN (using your IDE probably, Eclipse or IntelliJ or whatever). Don't download the code as a zip file from the Subsonic page, you need to check it out using a Subversion tool. That's the only way you'll be able to keep track of what Sindre is adding. Then create a Git repository from the same directory and push all changes from there to Github. There might be a more efficient way though, I never tried keeping two different code version systems in sync.
hakko
Postby MadEvil » Sun Jun 03, 2012 8:38 pm
Sindre did his job great for 4.7, some great enhancements to db tables and cache.
You did a great enhancement to the old 4.6 Trunk, because there was no efficient way to get the MetaData direct from files.
[*] My Vision for Subsonic is that the scan & update Process for Metadata gets more automatic & dynamical.
[*] MediaType enhancement for better detection of media files and folder structure.
[*] a little MetaData Exchanger Interface from LastFM to Update Tags to local Metadata trough (example: get genre Tags to local ID3-Comment field).
[*] a Link Community Data to local media-files for Charts, Play-count like LastFM or Spotify keep also the local ratting.
[*] enhancement to the Interface to get all this visual.
i keep trying. :wink:
best regards
:D
Madsonic Developer
MadEvil
Postby MadEvil » Mon Jun 04, 2012 1:59 am
Here is my log:
Error
Server   jetty-6.1.x
   ... 70 more
i fixed this bug temporary in Build 3014, but don't forget this is only a technical beta, this feature isn't complete, Links to the Artist must be improved.
best regards
Madsonic Developer
MadEvil
Postby massiliattak » Tue Jun 05, 2012 6:46 pm
MadEvil wrote:i fixed this bug temporary in Build 3014, but don't forget this is only a technical beta, this feature isn't complete, Links to the Artist must be improved.
best regards
It works! Thanks a lot.
About technical beta versions, I get it.
Thank you again.
Best Regards
massiliattak
Postby gigon » Wed Jun 06, 2012 5:13 pm
Wow thanks a lot for this great mod.
It works fine on My NAS (Synology Diskstation 211+) with Windows 7 x64 and Opera 11.
I am creating easy to install packages for the Synology Diskstations and would like to include this mod.
For that I have two questions:
1. What files In your stand-alone zip are different from the original subsonic zip? Is it just the subsonic.war, or the subsonic-booter-..., too.?
2. Can I publish a package containing this mod at my blog and in this forum?
Thanks again for your great work, Eric
Subsonic Package for Synology DiskStations http://eg-blog.de
gigon
Postby MadEvil » Wed Jun 06, 2012 8:23 pm
gigon wrote:Wow thanks a lot for this great mod.
Thanks again for you great work, Eric
hi, thx for your nice feedback 8)
1.) yes you need only this 3 files
subsonic.sh -> shell script
subsonic.war -> java & webfiles
subsonic-booter-jar-with-dependencies.jar -> jetty, libs, etc ..
The 4.6 Build should be stable. at the moment the 4.7 branch is very experimental.
Don't forget i use a modified data structure, so you can't go back with (User-settings, Play-count, etc), Backups will help (c;=
Use it only for testing purpose and start always a fresh installation, data-migration from 4.6 does not work well at the moment.
If you have questions maybe i can help you, or you want to get your own build system as well.
2.) ... and sure, new feedback are always welcome :wink:
best regards
Madsonic Developer
MadEvil
Postby MadEvil » Wed Jun 06, 2012 8:56 pm
New Build 3016
NEW Feature: MediaFile Type tagging from the webpage as an addition to the file tagging.
Update: jquery UI to latest
Update: Code cleanup
best regards
Madsonic Developer
MadEvil
Return to Madsonic
