Madsonic - Mashup Mod [MAIN]
Re: Madsonic - Mashup Mod [MAIN]
Postby maxxh » Thu Nov 01, 2012 10:41 am
Is the source code for Madsonic in any publicly available SVN or Git server?
If not, could you provide a link to download the latest source code?
maxxh
Postby ananda96 » Fri Nov 02, 2012 6:09 pm
at first - Beta works fine and there's no error so far. thank you.
4.8.beta1 (build 3200) – 31. Oktober 2012 – (Moded by MadEvil)
Server jetty-6.1.x, java 1.7.0_09, Windows 7 (153,2 MB / 207,7 MB)
But: i still have the issue of wrong stats...
2.094 Künstler --------- This can't be true! (close to 4000 Artists in Foobar)
8.908 Alben
91.756 Songs
1000,53 GB (~ 7.969 Stunden) ---- wrong too!
I reported this several times in the mainforum, am I the only one with this lack of stats?
cleaning database als Madevil recommended and fresh installs don't change that.
ananda96
Postby Ghizmo » Tue Nov 06, 2012 11:04 am
Hi Mad,
In Settings, when i click on "Cleanup" i've this error message :
HTTP ERROR: 404
/WEB-INF/jsp/cleanupSettings.jsp
RequestURI=/WEB-INF/jsp/cleanupSettings.jsp
Powered by Jetty://
What's wrong please ?
Thanks in advance...
Ghizmo
Postby MadEvil » Wed Nov 07, 2012 1:07 am
Ghizmo wrote:Hi Mad,
HTTP ERROR: 404
sorry this was an TYPO, fixed with new Build 3210.
best regards
Madsonic Developer
MadEvil
Postby MadEvil » Wed Nov 07, 2012 1:21 am
ananda96 wrote:at first - Beta works fine and there's no error so far. thank you.
8.908 Alben
91.756 Songs
I changed/advanced the Media-Library Statistics in the new Build 3210. This should bring your Artists back.
New counting albums and albumsets:
Example
1 Albumset with 2 Disks are 2 album counts
best regards
Madsonic Developer
MadEvil
Postby henriquemaia » Wed Nov 07, 2012 7:31 am
I'm using this mod and I'm very pleased with the way subsonic now looks. Thanks for that.
Question: is there a way to properly sort files? Some albums get all their tracks completely messed up*.
Note: running subsonic on Ubuntu server 12.10 and latest build of Madsonic. I've selected the option to sort by foldernames.
EDIT: *Not completely messed up, but not properly sorted. They are sorted alphabetically, not by tracks, which is rather annoying in albums where there are continuities.
henriquemaia
Postby MadEvil » Wed Nov 07, 2012 7:04 pm
henriquemaia wrote:I'm using this mod and I'm very pleased with the way subsonic now looks. Thanks for that.
I found out not well tagged media files (example without track numbers) get sorted default alphabetically.
So i add in the Build 3216 a new Setting you can choose how the files get sorted (alphabetically or by filename if no tracknumber exist).
Best regards
Madsonic Developer
MadEvil
Postby Ghizmo » Thu Nov 08, 2012 12:30 pm
Hi Mad,
Just a question : What's Subsonic Premium Services ?
Ghizmo
Postby hairlesshobo » Thu Nov 08, 2012 1:08 pm
I just installed build 3216 last night from a previous Madsonic build (3148), and I have to say that there have been huge improvements yet again! Thank you for the split transcoders, it made a huge difference on my machine in regards to transcoding performance, especially for audio!
I know that this is a beta, but I wanted to let you know of a couple bugs that I have spotted and not sure if you are aware of.
First, when I upgraded from my previous build to this one, I had to start subsonic, stop it, then start it again, run a full media scan, and then restart it one last time. The very first time I started Madsonic after the upgrade, it upgraded the database schema successfully, but it never would respond to incoming http requests until I restarted it the first time. After that, it started but I received errors about not being able to update statistics (sorry, I don't have the exact error message - forgot to save a copy last night). After I ran a manual scan of the database and restarted it one last time, the error went away and Madsonic started up successfully.
I also noticed that on the front end, it always reflects that it's scanning files in the top left corner, even when it isn't. Now the interesting part about this is that it happened when going to the front end on my Madsonic server and on my work laptop (this PC) - both running Windows 7 64 bit with Firefox 16.0.2. Now here is the kicker.. this did not happen on my Macbook running the same exact version of Firefox. I even tried clearing cache and restarting the browser, hoping that it was something caused by the browser itself and not the application, but it made no difference.
And finally, and this one is very small, when CustomScrollbars are disabled (which I do), there is always a little room to scroll on the left side. What I mean is that, even if the content in the left frame is too short to need to be scrolled, it still can be by about 4 or 5 pixels. It almost seems like the margin or padding is set incorrectly on some content in that frame or something, but I have yet to dig in deeper to the code and look at what might be causing it. If you need me to, I will be glad to do this and lend a hand.
So far, that is all I have seen. Other than that, Madsonic has been working great, especially since I upgraded to the latest build. Keep up the excellent work!!!
-Steve
hairlesshobo
Postby hairlesshobo » Thu Nov 08, 2012 1:12 pm
Someone correct me if I am wrong, but I believe that is referring to the subsonic.org subdomain you get if you donate to Sindre for the original subsonic. If you've never donated to the original subsonic, you don't have one and have no need to use it. If you choose to donate and get the license key from Sindre, then you'd have a subdomain for subsonic.org.
-Steve
hairlesshobo
Postby MediocreFred » Thu Nov 08, 2012 1:42 pm
Hi, Am on build 3210. During the daily scan of my media library, I get this in the log (error is new to this build):
[2012-11-08 02:01:28,651] ERROR MediaScannerService - Failed to scan media library.
org.springframework.dao.DataIntegrityViolationException: PreparedStatementCallback; SQL [insert into artist (id, name, cover_art_path, album_count, last_scanned, present) values (?, ?, ?, ?, ?, ?)]; Attempt to insert null into a non-nullable column: column: NAME table: ARTIST in statement [insert into artist (id, name, cover_art_path, album_count, last_scanned, present) values (?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: Attempt to insert null into a non-nullable column: column: NAME table: ARTIST in statement [insert into artist (id, name, cover_art_path, album_count, last_scanned, present) values (?, ?, ?, ?, ?, ?)]
   at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:100)
   at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:71)
   at net.sourceforge.subsonic.dao.ArtistDao.createOrUpdateArtist(ArtistDao.java:86)
   at net.sourceforge.subsonic.service.MediaScannerService.updateArtist(MediaScannerService.java:346)
   at net.sourceforge.subsonic.service.MediaScannerService.scanFile(MediaScannerService.java:235)
   at net.sourceforge.subsonic.service.MediaScannerService.scanFile(MediaScannerService.java:219)
   at net.sourceforge.subsonic.service.MediaScannerService.scanFile(MediaScannerService.java:222)
   at net.sourceforge.subsonic.service.MediaScannerService.doScanLibrary(MediaScannerService.java:170)
   at net.sourceforge.subsonic.service.MediaScannerService.access$000(MediaScannerService.java:47)
   at net.sourceforge.subsonic.service.MediaScannerService$2.run(MediaScannerService.java:146)
Caused by: java.sql.SQLException: Attempt to insert null into a non-nullable column: column: NAME table: ARTIST in statement [insert into artist (id, name, cover_art_path, album_count, last_scanned, present) values (?, ?, ?, ?, ?, ?)]
   ... 12 more
As soon as this error is encountered, scanning aborts. Since my id3 tags are pretty far from complete/perfect, will it be possible to ignore this error (skip the item) and continue scanning? Possibly, enter "Unknown" or "None" or just a space as the Artist if there is none in the id3 tag?
A couple of other errors in the log that are caused while streaming mp3s (I have disabled transcoding for mp3s). Neither if these cause any noticeable issues for the listener, but, clog the log:
This is new to this build
[2012-11-07 19:23:35,248] WARN RESTFilter - Error in REST API: For input string: "6e3a5c4c2d2d4c4543545552452d2044454d4f4e5354524154494f4e532d4341524e415449432d31322e322047425c4c45432d44454d2d203732204d454c414b41525448412052414741532d532e42414c414348414e4445522d5645454e41495c564f4c554d4520315c30352033307468204d454c414b4152544841204e41414741414e414e44494e492d36746820524141474120494e204348414b524120562e6d7033"
java.lang.NumberFormatException: For input string: "6e3a5c4c2d2d4c4543545552452d2044454d4f4e5354524154494f4e532d4341524e415449432d31322e322047425c4c45432d44454d2d203732204d454c414b41525448412052414741532d532e42414c414348414e4445522d5645454e41495c564f4c554d4520315c30352033307468204d454c414b4152544841204e41414741414e414e44494e492d36746820524141474120494e204348414b524120562e6d7033"
   at java.lang.NumberFormatException.forInputString(Unknown Source)
   at java.lang.Integer.parseInt(Unknown Source)
   at java.lang.Integer.valueOf(Unknown Source)
   at org.springframework.web.bind.ServletRequestUtils$IntParser.doParse(ServletRequestUtils.java:554)
   at org.springframework.web.bind.ServletRequestUtils$ParameterParser.parse(ServletRequestUtils.java:524)
   at org.springframework.web.bind.ServletRequestUtils$IntParser.parseInt(ServletRequestUtils.java:558)
   at org.springframework.web.bind.ServletRequestUtils.getRequiredIntParameter(ServletRequestUtils.java:108)
   at org.springframework.web.bind.ServletRequestUtils.getIntParameter(ServletRequestUtils.java:62)
   at net.sourceforge.subsonic.controller.StreamController.getSingleFile(StreamController.java:241)
   at net.sourceforge.subsonic.controller.StreamController.handleRequest(StreamController.java:120)
   at net.sourceforge.subsonic.controller.RESTController.stream(RESTController.java:1141)
   at sun.reflect.GeneratedMethodAccessor114.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Unknown Source)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
   at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
   at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
   at net.sourceforge.subsonic.security.RESTRequestParameterProcessingFilter.doFilter(RESTRequestParameterProcessingFilter.java:104)
   at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
   at net.sourceforge.subsonic.filter.RESTFilter.doFilter(RESTFilter.java:51)
   at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:844)
   at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:644)
   at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:205)
while this has been there ever since I upgraded to 4.7 (Subsonic and Madsonic)
[2012-11-07 17:00:45,270] WARN RESTFilter - Error in REST API: EofException
org.mortbay.jetty.EofException
   at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:760)
   at org.mortbay.jetty.AbstractGenerator$Output.blockForOutput(AbstractGenerator.java:546)
   at org.mortbay.jetty.AbstractGenerator$Output.flush(AbstractGenerator.java:567)
   at org.mortbay.jetty.HttpConnection$Output.flush(HttpConnection.java:907)
   at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:628)
   at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:575)
   at net.sourceforge.subsonic.controller.StreamController.handleRequest(StreamController.java:221)
Caused by: java.io.IOException: An existing connection was forcibly closed by the remote host
   at sun.nio.ch.SocketDispatcher.write0(Native Method)
   at sun.nio.ch.SocketDispatcher.write(Unknown Source)
   at sun.nio.ch.IOUtil.writeFromNativeBuffer(Unknown Source)
   at sun.nio.ch.IOUtil.write(Unknown Source)
   at sun.nio.ch.SocketChannelImpl.write(Unknown Source)
   at org.mortbay.io.nio.ChannelEndPoint.flush(ChannelEndPoint.java:166)
   at org.mortbay.io.nio.SelectChannelEndPoint.flush(SelectChannelEndPoint.java:208)
   at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:693)
   ... 67 more
Are these errors that can be easily fixed or worked around in the code?
Thanks.
MediocreFred
Postby sebass » Fri Nov 09, 2012 10:51 am
Hi MadEvil,
Your mod is awesome! However i'm getting this error since one of the last builts. The statistics are also wrong eversince, 1 hour of music on 0 artists/albums etc while the list is almost complete...
Info on the error:
[2012-11-09 11:14:20,971] ERROR MediaScannerService - Failed to scan media library.
org.springframework.dao.DataIntegrityViolationException: PreparedStatementCallback; SQL [insert into album (id, path, name, SetName, artist, albumartist, song_count, duration_seconds, cover_art_path, play_count, last_played, comment, created, last_scanned, present) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; Attempt to insert null into a non-nullable column: column: NAME table: ALBUM in statement [insert into album (id, path, name, SetName, artist, albumartist, song_count, duration_seconds, cover_art_path, play_count, last_played, comment, created, last_scanned, present) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: Attempt to insert null into a non-nullable column: column: NAME table: ALBUM in statement [insert into album (id, path, name, SetName, artist, albumartist, song_count, duration_seconds, cover_art_path, play_count, last_played, comment, created, last_scanned, present) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
   at net.sourceforge.subsonic.dao.AlbumDao.createOrUpdateAlbum(AlbumDao.java:148)
   at net.sourceforge.subsonic.service.MediaScannerService.updateAlbum(MediaScannerService.java:311)
   at net.sourceforge.subsonic.service.MediaScannerService.scanFile(MediaScannerService.java:234)
Caused by: java.sql.SQLException: Attempt to insert null into a non-nullable column: column: NAME table: ALBUM in statement [insert into album (id, path, name, SetName, artist, albumartist, song_count, duration_seconds, cover_art_path, play_count, last_played, comment, created, last_scanned, present) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
   ... 11 more
I've got also some errors while scanning, I think it has something to do with the "mju"-sign in the file and folder-name:
[2012-11-09 11:14:17,914] WARN JaudiotaggerParser - Error when parsing tags in D:\Music\µ-ziq\µ-Ziq - Lunatic Harness [1997] [Album][320CD](mu-ziq)\µ-Ziq - Lunatic Harness - 01 - Brace Yourself Jason.mp3
java.lang.NullPointerException
   at java.text.SimpleDateFormat.parse(Unknown Source)
   at java.text.DateFormat.parse(Unknown Source)
   at net.sourceforge.subsonic.service.metadata.JaudiotaggerParser.parseYear(JaudiotaggerParser.java:113)
   at net.sourceforge.subsonic.service.metadata.JaudiotaggerParser.getRawMetaData(JaudiotaggerParser.java:86)
   at net.sourceforge.subsonic.service.metadata.MetaDataParser.getMetaData(MetaDataParser.java:47)
   at net.sourceforge.subsonic.service.MediaFileService.createMediaFile(MediaFileService.java:647)
   at net.sourceforge.subsonic.service.MediaFileService.updateChildren(MediaFileService.java:392)
   at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:249)
   at net.sourceforge.subsonic.service.MediaScannerService.scanFile(MediaScannerService.java:218)
Keep up the good work, MadEvil!
sebass
Postby MadEvil » Fri Nov 09, 2012 12:37 pm
Hi @ all,
Hopefully fixed all scanning Errors with Build 3220 :wink:
best regards
Madsonic Developer
MadEvil
Postby henriquemaia » Sat Nov 10, 2012 1:19 pm
I've noticed that since I started using Madsonic's mod that some of the albums names are not shown. I don't know if this a bug of the mod. In any case, I wanted to point it out. I've added a screenshot with that error.
Running version 3220.
henriquemaia
Postby MadEvil » Sat Nov 10, 2012 1:46 pm
henriquemaia wrote:I've noticed that since I started using Madsonic's mod that some of the albums names are not shown. I don't know if this a bug of the mod. In any case, I wanted to point it out. I've added a screenshot with that error.
this can be if you upgrade from vanilla subsonic, the database schema in madsonic is a little diffrent, other user have this seen to.
viewtopic.php?f=15&t=9187&start=345#p46866
Solution1: restart from scratch. -> delete the whole subsonic folder. Reinstall & rescan
Solution2: make a Full rescan -> viewtopic.php?f=15&t=10463
a other problem could be a tagging issue. Give me feedback, together we find the problem. :wink:
best reagards
Madsonic Developer
MadEvil
Return to Madsonic
