[Solved] Video doesn't play
Postby jonnymnemo » Tue Oct 16, 2012 6:57 pm
Hi !
For the first time, I've tried to play some videos with the latest build (3158).
Each time I try a video, I have in the middle of the video box :
Video not found or access denied: /stream?id=368&maxBitrate=1000&timeOffset=0&player=5
In the log I have :
[16/10/12 20:43:51 CEST]   INFO   PlayQueueInputStream   jonnymnemo listening to "[AA] Fruits Basket 01 - 26/[AA] Fruits Basket - 01 The Strangest Day.avi"
[16/10/12 20:43:51 CEST]   DEBUG   TranscodeInputStream   Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/media/dns320/Medias/Videos/Animes/[AA] Fruits Basket 01 - 26/[AA] Fruits Basket - 01 The Strangest Day.avi] [-async] [1] [-b] [1000k] [-s] [480x360] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-vcodec] [libx264] [-preset] [superfast] [-threads] [0] [-]
I already put a chmod 777 on all my media files, and the path and name of the files are correct.
I have reset the transcoding setting to madsonic default.
The video seems to be found, because the length of the video on the bottom right is correct.
Why is it not working ?
jonnymnemo
Re: [Help request] Video doesn't play
Postby MadEvil » Thu Oct 18, 2012 10:09 am
jonnymnemo wrote:Hi !
In the log I have :
hi,
i saw this problem also on my testfiles, there is maybe a problem with the transcoding. Did you try a older or other ffmpeg version.
This fix the problem in most cases.
http://ffmpeg.org/download.html
or http://ul.to/f/sctmqc Madsonic Mashup-Mod Transcoding Packs (for standalone or war only upgrades)
since build 3158 the transcoding ist splited in /var/subsonic/transcode/Audioffmpeg for audio transcoding
and /var/subsonic/transcode/ffmpeg for video. so you could try to test other versions without impact the transcoding for your audio files.
best regards
Madsonic Developer
MadEvil
Postby jonnymnemo » Tue Oct 23, 2012 11:01 am
Thanks MadEvil, you were right.
I changed ffmpeg to the original one, and it works now !
I hope to see this problem fixed in your future builds, maybe even with subtitles support ! :wink:
jonnymnemo
Return to Madsonic
