Build 3280 and Java Exploit
Postby jdubso » Thu Nov 29, 2012 5:10 pm
With the installation of the previous two builds of MadSonic, Microsoft Security Essentials is detecting a java exploit. If left quarantined MadSonic does not run.
Any explanation of what is going on?
jdubso
Re: Build 3280 and Java Exploit
Postby gurutech » Thu Nov 29, 2012 6:31 pm
Upgrade to the latest version of Java. I'm on the same build (3280) and just completed a scan, with no errors. I'm using AVG and the most recent version of Java.
gurutech
Postby MadEvil » Thu Nov 29, 2012 7:15 pm
Madsonic is build on
*) 32bit Windows 7
*) Java JDK 1.7_09
it seams the problem isn't new to the MS scan engine --> viewtopic.php?f=2&t=10246
i look for a workaround!
best regards
PS: check your system if only the last JRE/JDK is installed and active.
Last: 1.6.37 or 1.7.09
http://javatester.org
Madsonic Developer
MadEvil
Postby muiz » Sat Dec 01, 2012 2:58 am
After 4.8.beta1 (build 3206) , subsonic gives errors, and doesnt show my music folders, only network folders.
So im back to 4.8.beta1 (build 3206) , and all works fine again.
muiz
Return to Madsonic
