Jw player 6
Jw player 6
Postby chali » Mon Dec 10, 2012 2:32 pm
Hello
I wonder if it is possible to update jw player to 6.0 (for example, if I were to buy a premium account on jw player, which supports the HLS Live Streaming on iOS and Flash / html5)
But how do I install it in madsonic?
/ Chali
chali
Re: Jw player 6
Postby MadEvil » Mon Dec 10, 2012 5:06 pm
hi,
if found out, upgrade to 6 is much diffrent as before
jw player version 6 free edtion doesn't support HLS and
there is no HLS Support on android
http://www.longtailvideo.com/support/jw ... jw5-to-jw6
http://www.longtailvideo.com/support/jw ... -streaming
Madsonic Developer
MadEvil
Re: Jw player 6
Postby chali » Mon Dec 10, 2012 9:45 pm
hi
Thanks for the reply.
crap, is there any other player I can install to get rid of flash?
Do you know how to change the settings for different hardware that connects to madsonic? (thinking of different types of media players)
/ Chali
MadEvil wrote:hi,
jw player version 6 doesn't support HLS and
chali
Re: Jw player 6
Postby muiz » Tue Dec 11, 2012 6:42 pm
So this means we are stuck with 5 ?
muiz
Re: Jw player 6
Postby hairlesshobo » Tue Dec 11, 2012 6:57 pm
Have you by chance tried the mini player that is included with subsonic/madsonic 4.7 and 4.8? This is an HTML5 only player and may do what you are looking for.
Once logged in, go to More > Minisub.
Check this out (if you haven't already) and see if it does what you are looking for, or at least works for you for the time being.
-Steve
hairlesshobo
Re: Jw player 6
Postby chali » Wed Dec 12, 2012 2:32 pm
hi
but it's just for music or?
I want to stream video
/ Chali
chali
Re: Jw player 6
Postby shivan » Fri Dec 14, 2012 10:45 pm
has anyone tried using VLC in command line mode to stream?
shivan
Re: Jw player 6
Postby muiz » Sun Dec 16, 2012 5:51 pm
VLC plugin works only with online radio on my subsonic for me.
To bad it doesnt for video :(
muiz
Return to Madsonic
