Disable YouTube Songsearch feature?
Postby lovebags » Tue Jan 01, 2013 11:56 pm
Have just been checking out Madsonic for the first time and really impressed! Although the YouTube Songsearch feature is great, is there a way to disable it? I'm guessing that given there is no option to toggle on/off, it would need to be done in the code.
lovebags
Re: Disable YouTube Songsearch feature?
Postby MadEvil » Wed Jan 02, 2013 6:19 pm
there is a own user role, you can set this for each user.
Madsonic Developer
MadEvil
Postby lovebags » Mon Jan 07, 2013 11:34 pm
ok thanks for the info, is there are reason this setting isn't called "User is allowed to use the YouTube Songsearch functions"? I had presumed that unchecking the user search functions would disable being able to use the search box in the main section.
lovebags
Return to Madsonic
