[feature request] fanart.tv integration
Postby sigel » Tue Jan 08, 2013 6:50 pm
I also suggested this to hakko over at musiccabinet, but since i'm also working on MadSonic themes I wanted to make this suggestion to you and your users as well.
Fanart.TV Music: http://fanart.tv/music-fanart/
Fanart.TV Music API: http://fanart.tv/api-docs/music-api/
Maybe also pull artist bios/info from musicbrrainz/last.fm or similar source?
Alternatively, if you didn't want to go through all the trouble with pulling images over the API, maybe allow us to put a logo.png / fanart.png in artist folders which then get replaced/loaded if they exist. and maybe an artist.nfo/xml file for bio? Dunno, just putting it out there.
Thanks for everything you do!
sigel
Re: [feature request] fanart.tv integration
Postby MadEvil » Tue Jan 08, 2013 10:11 pm
hi, looks great!
i working on an Last.FM interface that do exactly this Data synchronizations :
Bio, Images, Data, Ids, and background, ...
stay tuned :wink:
Madsonic Developer
MadEvil
Return to Madsonic
