Help inserting License
Postby Stupifier » Tue Feb 26, 2013 11:25 pm
I am a new user who began with MadSonic. I have now donated to Sindre and have a license key and email address.....but I do not see anyplace to insert this information on the local madsonic gui. Where does this go? I do not see the donate button in the upper corner mentioned in the license key insertion instructions. I understand those instructions are for the original Subsonic server though.....
Stupifier
Re: Help inserting License
Postby khumbert45 » Sun Jun 23, 2013 4:29 am
I am wondering the same thing... I started with subsonic but quickly found and switched to madsonic. Now my 30 day window is up and I need to register my license key but don't see where to do that from inside of Madsonic. Hoping I don't have to re-install subsonic, insert the key, then reinstall madsonic...
Any help?
khumbert45
Postby MadEvil » Mon Jun 24, 2013 7:09 am
hi there,
sorry, main support of Madsonic has moved to http://www.madsonic.org and http://forum.madsonic.org
to your question:
go to: madsonic --> Settings --> General Settings --> Enalbe for Subsonic Premium Services --> Save
Then you should have the ability to insert your key --> Top Frame --> Icon
Best regards
Madsonic Developer
MadEvil
Return to Madsonic
