User History Logger
User History Logger
Postby vbguy2011 » Tue Mar 12, 2013 1:21 am
Hi, I understand there's a user history logger?
Could anyone explain what it is about, and how to use/access it?
Separately/additionally, is there a way to monitor user usage/statistic/activity? Would this be logged anywhere? If so, how can admin monitor/access?
Cheers
vbguy2011
Re: User History Logger
Postby MadEvil » Tue Mar 12, 2013 2:21 am
vbguy2011 wrote:Hi, I understand there's a user history logger?
Cheers
the first version was an separately log file and log all user play history, in the 4.8 branche i changed to db-loging.
So you can easy show your own history or from others.
Madsonic Developer
MadEvil
Postby vbguy2011 » Tue Mar 12, 2013 3:31 am
Awesome!!!
However, couple things I note:
1) I don't have "other" or "self" but I have "ALL" as well as non-all which I believe are mine.
2) The username don't show
Separately, is there a way to monitor user activity/usage individually, i.e. view various stats for just 1 user instead of "ALL"/"other" users combined?
cheers
vbguy2011
Postby MadEvil » Wed Mar 13, 2013 12:53 am
Hi there,
if you have simple SQL knowledge you can go to db.view and use this query
SELECT * from statistic_user, media_file where statistic_user.media_file_id = media_file.id and username = 'admin'
this query should show you all information's about played entries incl. the username.
best regards
Madsonic Developer
MadEvil
Postby vbguy2011 » Wed Mar 13, 2013 2:47 am
MadEvil wrote:Hi there,
best regards
Ah right, didn't realise I could do sql queries. that's great thanks!
that said, it would be nice to have a separate feature for monitoring user stastics/activity altogether instead of manually pulling SQL queries :)
vbguy2011
Return to Madsonic
