Centos upgrade from subsonic
Postby Andrusa » Tue Mar 26, 2013 6:42 am
MadEvil, could you be nice to make an easy-to-follow tutorial for upgrading from standard Subsonic instalation via YUM on Centos 6.4 x64 ?
4.7 (build 3105) – September 11, 2012
jetty-6.1.x, java 1.6.0_24, Linux (31.1 MB / 50.5 MB)
Many thanks !
Andrusa
Re: Centos upgrade from subsonic
Postby gurutech » Tue Mar 26, 2013 6:47 am
Simplest way to do it is:
Download the latest RPM version of Madsonic from here: http://uploaded.net/folder/s9nbbk
Save to your Centos desktop
Stop existing subsonic services (as "root": service subsonic stop)
UNINSTALL Java version 6
Download Java 7 from java.com and install
Uninstall Subsonic 4.7
Install the RPM version of Madsonic. (It will save your settings from 4.7)
Start new subsonic service: (as "root": service subsonic start)
The first time you start the new service, it may take a while to load, due to a database upgrade.
gurutech
Postby Andrusa » Tue Mar 26, 2013 7:47 am
Many thanks, but i am on runlevel 3...
Andrusa
Postby Andrusa » Tue Mar 26, 2013 9:37 am
Done, thanks for help !
Now, it says that is a new version of madsonic but 3360 does not have a rpm... !?
All other versions have one.
Andrusa
Postby gurutech » Wed Mar 27, 2013 8:50 pm
You will need to do a "WAR" upgrade to get to 3360...
Just stop your Subsonic service, then download the WAR file (from same site as before). Extract it to /usr/share/subsonic (overwriting the existing one), and chmod to 766 for that file, then restart the subsonic service.
You will see a new folder under /var/subsonic/jetty with the appropriate version number (3360).
gurutech
Return to Madsonic
