Similar Artists ??
Re: Similar Artists ??
Postby bushman4 » Thu Apr 04, 2013 7:29 pm
If you are using SSL you need to play something and then allow the insecure content to be loaded on the page... in chrome, that is a little shield that appears in the right side of the address bar that, when you click on it, you can say "load anyway."
It will only persist for that one session until the window is closed.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Return to Madsonic
