Final 5150
Final 5150
Postby ForSSUx » Tue Sep 30, 2014 6:31 am
I can't install version newer then madsonic 5.1 beta1.
First i thought something was wrong with Java so I installed a 1.7-60 I also tried with the 1.8 branch I tried the X64 and x86 versions.
When I mean install I mean delete folders clean registery as on java support site and get rid of the complete c:/madsonic folder ...
I never worked but when I take version 5.1beta1 it works.
in the logs I find this
WARNING: Could not connect to RMI service [rmi://localhost:9412/SubsonicDeployerService] - retrying
Does anybody has a clue what might be going on?
Kind regards
Guy Forssman
ForSSUx
Return to Madsonic
