Feature Request: Bluetooth
Re: Feature Request: Bluetooth
Postby williamkray » Fri Feb 22, 2013 6:12 am
I'm noticing a problem with Bluetooth playback. Galaxy s3 running CyanogenMod 10.1 nightlies. My Bluetooth seems to crash during playback, usually when the third or fourth song begins. When it happens, the scrubber in DSub doesn't move, but the action button will reflect whether it would be playing or paused when pressed. After this happens, If I attempt to play music from a different program through Bluetooth, it does the same thing. If I attempt to turn off Bluetooth, the Bluetooth settings menu freezes at "turning off Bluetooth" and a reboot is necessary to turn it back on.
Other music programs do not incite this series of events. I will I include a logcat if you wish, though my untrained eye couldn't pick out any relevant information last time it happened.
williamkray
Postby daneren2005 » Fri Feb 22, 2013 5:46 pm
I would like a logcat yes, though it seems more like a issue with the ROM tbh. There should be nothing an app can do that should cause the behavior you are seeing :?
Is this a issue that started happening recently?
Postby ar9 » Sat Feb 23, 2013 4:40 am
I don't see an option to Send Log with your Bluetooth beta version.
Is it disabled for some reason?
ar9
Postby daneren2005 » Sat Feb 23, 2013 6:41 am
Well this thread is from months ago so the beta there will be old...Before I implemented the log sending feature.
Postby plastikman » Thu Feb 28, 2013 3:49 pm
How about adding the track time info to the metadata? my car always shows the track info (which i love) but for the time info it always shows 0:00/0:00 do you know how to add the position and length?
-plastikman
plastikman
Postby daneren2005 » Thu Feb 28, 2013 6:28 pm
I tried doing that before but everything I did just made the person who was testing for me not have working bluetooth at all :(
Postby plastikman » Thu Feb 28, 2013 9:46 pm
lame, no worries! the fact that i have metadata is a win in my book!
plastikman
Previous
Return to DSub for Android
