DSub for Android
Re: DSub for Android
Postby keith » Sat Jan 05, 2013 7:10 am
I downloaded alogcat, but DSub doesn't seem to produce any logs.
At any rate, it's working fine now. When it breaks, I'll try to use alogcat, but I don't have much info in there. Do I need a debug build or flag?
keith
Postby daneren2005 » Sat Jan 05, 2013 4:21 pm
keith wrote:I downloaded alogcat, but DSub doesn't seem to produce any logs.
Do you happen to be using a phone with Android 4.2 on it? Apparently they redid the permissions so apps can only collect the logs for themselves.
Postby keith » Sat Jan 05, 2013 5:01 pm
Android 4.1.2
keith
Re: Re: DSub for Android
Postby hyatari » Sat Jan 05, 2013 10:39 pm
Alogcat has to run as a system app to work correctly I think. You must have root and use something like titanium backup to change it to a system app.
hyatari
Postby mr_nobody » Sun Jan 06, 2013 12:06 am
I successfully used an app called catlog before on an unrooted gingerbread device...maybe try that instead.
mr_nobody
Postby daneren2005 » Sun Jan 06, 2013 2:58 am
That's odd I am using alogcat without root on my phone. I guess I just need to setup some way to log directly within the app.
Postby boognish43 » Sun Jan 06, 2013 4:13 am
Sorry if this has been addressed but is there any plans to add a feature to see what others are listening to on the same server?
Thanks for this app! I use it everyday
boognish43
Postby daneren2005 » Sun Jan 06, 2013 4:38 am
boognish43 wrote:Sorry if this has been addressed but is there any plans to add a feature to see what others are listening to on the same server?
While I would love to support needs to be added to the server API before I could do that.
Postby Alpione » Sun Jan 06, 2013 10:27 pm
Dumb question. How do I get the lock screen functionality going?
Thx.
A
Alpione
Postby boognish43 » Sun Jan 06, 2013 10:57 pm
Gotcha. I thought it was since isub has this function.
Thanks again for your hard work on this!
boognish43
Postby mr_nobody » Mon Jan 07, 2013 3:14 am
Erm, then the server api does support it?
mr_nobody
Postby daneren2005 » Mon Jan 07, 2013 6:07 am
Ah maybe I'm wrong then. I just looked on http://www.subsonic.org/pages/api.jsp and didn't see anything about being able to look who else is listening on the same server.
Re: Re: Re: DSub for Android
Postby boognish43 » Mon Jan 07, 2013 6:25 am
daneren2005 wrote:
boognish43 wrote:
daneren2005 wrote:[quote="boognish43"]Sorry if this has been addressed but is there any plans to add a feature to see what others are listening to on the same server?
Ah maybe I'm wrong then. I just looked on http://www.subsonic.org/pages/api.jsp and didn't see anything about being able to look who else is listening on the same server.[/quote]
Is this it? I have no clue what this stuff means or how to use it but this seems like what I was referring to.
getNowPlaying
http://your-server/rest/getNowPlaying.view
Since 1.0.0
Returns what is currently being played by all users. Takes no extra parameters.
Returns a <subsonic-response> element with a nested <nowPlaying> element on success. Example.
boognish43
Postby daneren2005 » Mon Jan 07, 2013 6:35 am
Yep that is it. I must have just missed it when I was looking.
Postby obcd » Mon Jan 07, 2013 9:53 am
I have been using different versions of subsonic andoid apps for the last few months. I was bothered with the ads. I have compiled dsub, but even with it I get some popups when I try for instance to play a playlist ("play now"). It says that the time frame for unlimited downloads is over and that I should donate to get unlimited downloads back. I am using musiccabinet on the other side.
Is this behavior normal? What should I do to remove that popup that blocks me from playing some stuff.
obcd
Return to DSub for Android
