Roland Stone wrote:No its not really a DSub problem, I have the same issue with the official Subsonic app. I was just hoping someone might have an idea what to do or how else to troubleshoot it. I Googled the issue and I'm not the only one with the problem. It seems to be router related. But I don't know how to cure it.
daneren2005 wrote:Send me a log immediately after you get the error. It might be a server failure that I can't fix, but I should at least be able to make it fail more gracefully.
daneren2005 wrote:1) Yah this is already semi done in the new UI that I am working on.
2) I'm not sure if you understand the difference between cache and download or if I am misunderstanding you. By default songs are just downloaded and they are eligible to be deleted if you start running out of room. Download does this as well, but just in the background instead of needing to be added to the now playing list. Cache on the other hand just makes it so that it won't be deleted when running out of room. So now to be sure, you are asking for an option to make it so that everything downloaded would be cached? I'm not sure if there would be any point in that tbh. It seems like just putting the cache size to be a really high number would accomplish the same thing.
daneren2005 wrote:Can you try to remove the widget and put it back again real quick? I changed the way the buttons act in the widgets and it might have screwed with existing widgets (it didn't in testing for me, but you never know).
Andy L wrote:Ah, I always thought it was the other way round (i.e. cache = songs eligible to be deleted, download = songs not deleted). Thanks for the clarification and looking forward to seeing the new UI in action
