DSub for Android
Re: DSub for Android
Postby daneren2005 » Tue Jan 21, 2014 1:01 pm
Alright, thanks for the input. I added a few of your suggestions to the todo list.
Postby vancamp » Thu Feb 06, 2014 8:07 am
4.4 says... "Browse by ID3 Tags instead of folder structure (off by default)"
How do you turn it on? Does it allow you to browse from Genre -> Artist? Are Tags properly sorted?
Warren.
vancamp
Postby daneren2005 » Thu Feb 06, 2014 3:06 pm
It is under each individual servers settings. No it doesn't allow browsing artists by genre. I don't know what you mean by tags being sorted.
Sent from my HTC One X using Tapatalk
Postby vancamp » Fri Feb 07, 2014 4:58 pm
daneren2005 wrote:It is under each individual servers settings. No it doesn't allow browsing artists by genre. I don't know what you mean by tags being sorted.
Thanks, so it browses the ID3 Artist. Is there any way to keep it from sorting the albums by date? I'd rather all albums were then sorted by album name only.
vancamp
Postby daneren2005 » Fri Feb 07, 2014 6:02 pm
Not right now but I can add a option to sort by year or name. That shouldn't be unique to browsing by tags though.
Postby Alsaya » Wed Feb 12, 2014 3:28 pm
Is it working with Kitkat and an external sdcard?
Subsonic on Server 2012, only flac
Alsaya
Postby gremlinchief » Tue Feb 18, 2014 6:28 pm
I ended up going back to version 4.3.6 from the latest version (as of today) which fixed my "next track" issue that I've been having for the past week or so (since the 4.4 update). What happened was that whenever I skipped ahead multiple songs (within a few seconds of each other), the song that was displayed as currently playing was not the actual one that was playing. This happened with bluetooth and aux in. To get it to play the correct song, I had to go to the playlist and manually select the song (it would then restart and play the correct song). The subsonic server version I was on was initially 4.8, but upgrading to 4.9 didn't help with the issue. The only other thing to mention was that the entire playlist I had playing was cached.
gremlinchief
Postby daneren2005 » Tue Feb 18, 2014 6:43 pm
Although I can't reproduce the issue myself, I think I see the source of the problem. It should be fixed in the next update.
Postby sdct989 » Sun Feb 23, 2014 10:20 pm
Is there any way to change the behavior of DSub playback for only podcasts?
I've started trying out using podcasts through Subsonic, however, the biggest thing that I miss from more conventional podcast players is their ability to skip forward or backward by a number of seconds instead of skipping to the next or previous track. Specifically, I use my car's media buttons quite a bit while listening to podcasts. So it would be a huge improvement to me, if the media next and media previous buttons were remapped to skip forward a number of seconds or skip backwards a number of seconds inside DSub only when listening to podcasts. Obviously, while listening to music, I would want the functionality to revert back to next/previous track.
On my wishlist would also be the ability to control the number of seconds skipped by an item in the settings panel.
sdct989
Postby daneren2005 » Sun Feb 23, 2014 11:50 pm
Yeah I can add it to the todo list. I will definitely only be adding it as a option though since some would find that annoying.
Postby daneren2005 » Mon Feb 24, 2014 12:00 am
Actually I think I have a better solution. I'm guessing 99.9% of the time people are listening to one podcast at a time. What do people think of me just making skipping within the doing the default action when you only have one song in the list? They aren't good for anything else at that point anyways.
Postby sdct989 » Mon Feb 24, 2014 12:23 am
I think that could work for me if it was the way you really wanted to implement it. However, then people couldn't queue podcasts.
Sent from my Samsung Galaxy S4
sdct989
Postby daneren2005 » Mon Feb 24, 2014 1:06 am
Do you really queue up podcasts often? I was just thinking that that would also make it so that if people were playing one really long audio file (like a book) they could do the same thing. I'm not decided just brain storming.
Postby trvbone » Mon Feb 24, 2014 1:09 am
Is there anything that can be done to better the eq? I always browse and cache with dsub but listen with Gone Mad Media Player, since it offers a much better sound quality and more fine tuning options. Other than that top notch app. Would just be nice to use this as an all in one file manager and media player.
USCC NOTE 3
trvbone
Postby daneren2005 » Mon Feb 24, 2014 1:53 am
Honestly probably not. I know nothing about EQ or really how to improve it without going low level, which is far beyond my abilities without making a full time job of it. What is it that you find better about other apps EQs?
Return to DSub for Android
