As far as I can tell, you can keep scrolling forever to get new choices (when displaying large art). When not displaying large art, you can refresh by pulling the list down. What's the issue (other than the inconsistency)?ds47uk wrote:I'm sure there used to be a "refresh" button when using "random" on Dsub to get a fresh set of random titles if there is nothing takes your fancy.
mikes wrote:As far as I can tell, you can keep scrolling forever to get new choices (when displaying large art). When not displaying large art, you can refresh by pulling the list down. What's the issue (other than the inconsistency)?ds47uk wrote:I'm sure there used to be a "refresh" button when using "random" on Dsub to get a fresh set of random titles if there is nothing takes your fancy.
But you can't keep scrolling either way, hence, "inconsistency."daneren2005 wrote:You can pull to refresh either way...
mikes wrote:But you can't keep scrolling either way, hence, "inconsistency."daneren2005 wrote:You can pull to refresh either way...Not a big thing.
trvbone wrote:Hey Idk if you're familiar with the Rocki upnp media player but is there anyway it could be integrated?
USCC NOTE 3
hell yes!daneren2005 wrote:trvbone wrote:Hey Idk if you're familiar with the Rocki upnp media player but is there anyway it could be integrated?
USCC NOTE 3
If all it requires is adding UPnP casting, which I plan on adding at some point, then yes. If it requires more, probably not as I have a lot larger targets to try to push music too at this point.
